2.3.2-92-ga053224b
Collaboration diagram for RF24:These options are specific to the RF24 family of wireless transport modules.
| Vendor | Chip |
| Nordic Semiconductor | nRF24L01 |
| nRF24L01+ | |
| Beken Corporation | BK2401 |
| BK2421 | |
| BK2491 | |
| Hope Microelectronics | RFM70 |
| RFM73 | |
| Panchip Microelectronics | XN297 |
| Silicon Labs(?) | SI24R1 |
| #define | MY_RADIO_NRF24 |
| Define this to use a RF24-based radio transport for sensor network communication. More... | |
| #define | MY_RADIO_RF24 |
| Define this to use a RF24-based radio transport for sensor network communication. | |
| #define | MY_RF24_ENABLE_ENCRYPTION |
| Define this to enable software based AES encryption. More... | |
| #define | MY_DEBUG_VERBOSE_RF24 |
| Define this for verbose debug prints related to the RF24 driver. | |
| #define | MY_RF24_SPI_SPEED (2*1000000ul) |
| Define this if you need to run the SPI clock at a different frequency than the default. More... | |
| #define | MY_RF24_CE_PIN (DEFAULT_RF24_CE_PIN) |
| Define this to change the chip enable pin from the default. | |
| #define | MY_RF24_CS_PIN (DEFAULT_RF24_CS_PIN) |
| Define this to change the chip select pin from the default. | |
| #define | MY_RF24_IRQ_PIN |
| Define this to use the IRQ pin of the RF24 module (optional). | |
| #define | MY_RF24_POWER_PIN |
| Define this to use the RF24 power pin (optional). | |
| #define | MY_RX_MESSAGE_BUFFER_FEATURE |
| This enables the receiving buffer feature. More... | |
| #define | MY_RX_MESSAGE_BUFFER_SIZE |
| Define this to change the incoming message buffer size from the default. More... | |
| #define | MY_RF24_PA_LEVEL (RF24_PA_HIGH) |
| Default RF24 PA level. Override in sketch if needed. More... | |
| #define | MY_RF24_CHANNEL (76) |
| RF channel for the sensor net, 0-125. More... | |
| #define | MY_RF24_DATARATE (RF24_250KBPS) |
| RF24 data rate. More... | |
| #define | MY_RF24_BASE_RADIO_ID 0x00,0xFC,0xE1,0xA8,0xA8 |
| RF24 radio network identifier. More... | |
| #define | MY_RF24_ADDR_WIDTH (5) |
| RF24 base address width. | |
| #define MY_RADIO_NRF24 |
Definition at line 2763 of file MyConfig.h.
| #define MY_RF24_BASE_RADIO_ID 0x00,0xFC,0xE1,0xA8,0xA8 |
This acts as base value for sensor nodeId addresses. Change this (or channel) if you have more than one sensor network.
Definition at line 511 of file MyConfig.h.
| #define MY_RF24_CHANNEL (76) |
Frequencies: 2400 Mhz - 2525 Mhz
Channels: 126
In some countries there might be limitations, in Germany for example only the range 2400,0 - 2483,5 Mhz is allowed.
Definition at line 485 of file MyConfig.h.
| #define MY_RF24_DATARATE (RF24_250KBPS) |
RF24 data rate.
Definition at line 500 of file MyConfig.h.
| #define MY_RF24_ENABLE_ENCRYPTION |
Definition at line 2767 of file MyConfig.h.
| #define MY_RF24_PA_LEVEL (RF24_PA_HIGH) |
Definition at line 461 of file MyConfig.h.
| #define MY_RF24_SPI_SPEED (2*1000000ul) |
Default nRF24L01+ SPI speed, 2MHz should be safe for nRF24L01+ clones.
Definition at line 395 of file MyConfig.h.
| #define MY_RX_MESSAGE_BUFFER_FEATURE |
This feature is currently not supported for anything but RF24. Require MY_RF24_IRQ_PIN to be set.
Note: Not supported on ESP8266, ESP32, STM32, nRF5 and sketches that use SoftSPI. See below issue for details https://github.com/mysensors/MySensors/issues/1128
Definition at line 2768 of file MyConfig.h.
| #define MY_RX_MESSAGE_BUFFER_SIZE |
Require MY_RX_MESSAGE_BUFFER_FEATURE to be set.
Definition at line 2769 of file MyConfig.h.
