2.3.2-95-g0c695e3e
MyConfig.h
* repeater and gateway builds a routing tables in RAM or EEPROM which keeps track of the
* Created by Henrik Ekblad <
[email protected]
* Copyright (C) 2013-2026 Sensnology AB
#ifndef MyConfig_h
#define MyConfig_h
//#define MY_DEBUG
//#define MY_DEBUGDEVICE
//#define MY_DEBUG_OTA (0)
//#define MY_DEBUG_OTA_DISABLE_ECHO
#if defined(MY_DEBUG_OTA_DISABLE_ACK) && !defined(DOXYGEN)
#warning MY_DEBUG_OTA_DISABLE_ACK is deprecated, please use MY_DEBUG_OTA_DISABLE_ECHO instead
//#define MY_OTA_LOG_RECEIVER_FEATURE
//#define MY_OTA_LOG_SENDER_FEATURE
134
//#define MY_SPECIAL_DEBUG
141
//#define MY_DIAGNOSTICS
150
151
159
//#define MY_DISABLED_SERIAL
160
168
//#define MY_SPLASH_SCREEN_DISABLED
169
178
#ifndef MY_BAUD_RATE
179
#define MY_BAUD_RATE (115200ul)
180
188
#ifndef MY_SERIAL_OUTPUT_SIZE
189
#define MY_SERIAL_OUTPUT_SIZE (120u)
190
// End of SerialDebugGrpPub group
192
197
//#define MY_DEBUG_VERBOSE_OTA_UPDATE
198
206
//#define MY_OTA_USE_I2C_EEPROM
207
208
#ifdef MY_OTA_USE_I2C_EEPROM
209
// I2C address of EEPROM. Wire will shift this left, i.e. 0x50->0xA0
210
#ifndef MY_OTA_I2C_ADDR
211
#define MY_OTA_I2C_ADDR 0x50
212
215
234
//#define MY_PJON
235
240
#ifndef MY_PJON_PIN
241
#define MY_PJON_PIN (12u)
242
248
//#define MY_DEBUG_VERBOSE_PJON
249
254
#ifndef MY_PJON_MAX_RETRIES
255
#define MY_PJON_MAX_RETRIES (5u)
256
258
#ifdef MY_PJON
259
260
#ifndef PJON_STRATEGY_ALL
261
#define PJON_STRATEGY_BITBANG
262
264
#define PJON_NOT_ASSIGNED (253u)
265
#define PJON_BROADCAST (255u)
266
267
#define SWBB_MAX_ATTEMPTS (50u)
268
#define PJON_INCLUDE_SWBB
269
// End of PJONSettingGrpPub group
272
284
//#define MY_RS485
285
290
#ifndef MY_RS485_BAUD_RATE
291
#define MY_RS485_BAUD_RATE (9600)
292
298
#ifndef MY_RS485_MAX_MESSAGE_LENGTH
299
#define MY_RS485_MAX_MESSAGE_LENGTH (40)
300
306
#ifndef MY_RS485_SOH_COUNT
307
#define MY_RS485_SOH_COUNT (1)
308
310
315
//#define MY_RS485_DE_PIN (2)
316
321
//#define MY_RS485_DE_INVERSE
322
329
//#define MY_RS485_HWSERIAL (Serial1) // End of RS485SettingGrpPub group
331
352
// legacy - remove for 3.0.0
358
#ifdef MY_RADIO_NRF24
359
#warning MY_RADIO_NRF24 is deprecated, use MY_RADIO_RF24 instead.
360
#undef MY_RADIO_NRF24
361
362
368
//#define MY_RADIO_RF24
369
380
//#define MY_RF24_ENABLE_ENCRYPTION
381
386
//#define MY_DEBUG_VERBOSE_RF24
387
394
#ifndef MY_RF24_SPI_SPEED
395
#define MY_RF24_SPI_SPEED (2*1000000ul)
396
402
#ifndef MY_RF24_CE_PIN
403
#define MY_RF24_CE_PIN (DEFAULT_RF24_CE_PIN)
404
410
#ifndef MY_RF24_CS_PIN
411
#define MY_RF24_CS_PIN (DEFAULT_RF24_CS_PIN)
412
418
//#define MY_RF24_IRQ_PIN (2)
419
424
//#define MY_RF24_POWER_PIN (3)
425
437
//#define MY_RX_MESSAGE_BUFFER_FEATURE
438
445
#ifdef MY_RX_MESSAGE_BUFFER_FEATURE
446
#ifndef MY_RX_MESSAGE_BUFFER_SIZE
447
#define MY_RX_MESSAGE_BUFFER_SIZE (20)
448
460
#ifndef MY_RF24_PA_LEVEL
461
#define MY_RF24_PA_LEVEL (RF24_PA_HIGH)
462
484
#ifndef MY_RF24_CHANNEL
485
#define MY_RF24_CHANNEL (76)
486
499
#ifndef MY_RF24_DATARATE
500
#define MY_RF24_DATARATE (RF24_250KBPS)
501
510
#ifndef MY_RF24_BASE_RADIO_ID
511
#define MY_RF24_BASE_RADIO_ID 0x00,0xFC,0xE1,0xA8,0xA8
512
518
#ifndef MY_RF24_ADDR_WIDTH
519
#define MY_RF24_ADDR_WIDTH (5)
520
// End of RF24SettingGrpPub group
522
544
//#define MY_RADIO_NRF5_ESB
545
556
//#define MY_NRF5_ESB_ENABLE_ENCRYPTION
557
562
//#define MY_DEBUG_VERBOSE_NRF5_ESB
563
573
#ifndef MY_NRF5_ESB_PA_LEVEL
574
#define MY_NRF5_ESB_PA_LEVEL (NRF5_PA_MAX)
575
597
#ifndef MY_NRF5_ESB_CHANNEL
598
#define MY_NRF5_ESB_CHANNEL (76)
599
610
#ifndef MY_NRF5_ESB_MODE
611
#ifdef RADIO_MODE_MODE_Nrf_250Kbit
612
#define MY_NRF5_ESB_MODE (NRF5_250KBPS)
613
#else
614
#define MY_NRF5_ESB_MODE (NRF5_1MBPS)
615
625
#ifndef MY_NRF5_ESB_BASE_RADIO_ID
626
#define MY_NRF5_ESB_BASE_RADIO_ID 0x00, 0xFC, 0xE1, 0xA8, 0xA8
627
633
#ifndef MY_NRF5_ESB_ADDR_WIDTH
634
#define MY_NRF5_ESB_ADDR_WIDTH (5)
635
641
#ifndef MY_NRF5_ESB_RX_BUFFER_SIZE
642
#define MY_NRF5_ESB_RX_BUFFER_SIZE (20)
643
649
//#define MY_NRF5_ESB_REVERSE_ACK_TX
650
655
//#define MY_NRF5_ESB_REVERSE_ACK_RX // End of NRF5SettingGrpPub group
657
674
680
//#define MY_DEBUG_VERBOSE_RFM69
681
686
//#define MY_DEBUG_VERBOSE_RFM69_REGISTERS
687
694
//#define MY_RFM69_NEW_DRIVER
695
711
#ifndef MY_RFM69_FREQUENCY
712
#define MY_RFM69_FREQUENCY (RFM69_868MHZ)
713
719
//#define MY_IS_RFM69HW
720
727
#ifdef MY_IS_RFM69HW
728
#define MY_RFM69HW true
729
#else
730
#define MY_RFM69HW false
731
737
#ifndef MY_RFM69_TX_POWER_DBM
738
#define MY_RFM69_TX_POWER_DBM (5)
739
745
#ifndef MY_RFM69_ATC_TARGET_RSSI_DBM
746
#define MY_RFM69_ATC_TARGET_RSSI_DBM (-80)
747
753
//#define MY_RFM69_ATC_MODE_DISABLED
754
766
//#define MY_RFM69_MAX_POWER_LEVEL_DBM (10u)
767
772
#ifndef MY_RFM69_NETWORKID
773
#define MY_RFM69_NETWORKID (100)
774
780
//#define MY_RFM69_RST_PIN (9)
781
782
#ifdef MY_RF69_RESET
783
#warning MY_RF69_RESET is depreciated, please use MY_RFM69_RST_PIN instead.
784
#define MY_RFM69_RST_PIN MY_RF69_RESET
785
791
//#define MY_RFM69_POWER_PIN (3)
792
797
#ifndef MY_RFM69_IRQ_PIN
798
#ifdef MY_RF69_IRQ_PIN
799
#warning MY_RF69_IRQ_PIN is depreciated, please use MY_RFM69_IRQ_PIN instead.
800
#define MY_RFM69_IRQ_PIN MY_RF69_IRQ_PIN
801
#else
802
#define MY_RFM69_IRQ_PIN DEFAULT_RFM69_IRQ_PIN
803
810
#ifndef MY_RFM69_IRQ_NUM
811
#ifdef MY_RF69_IRQ_NUM
812
#warning MY_RF69_IRQ_NUM is depreciated, please use MY_RFM69_IRQ_NUM instead.
813
#define MY_RFM69_IRQ_NUM MY_RF69_IRQ_NUM
814
#else
815
#define MY_RFM69_IRQ_NUM digitalPinToInterrupt(MY_RFM69_IRQ_PIN)
816
823
#ifndef MY_RFM69_CS_PIN
824
#ifdef MY_RF69_SPI_CS
825
#warning MY_RF69_SPI_CS is depreciated, please use MY_RFM69_CS_PIN instead.
826
#define MY_RFM69_CS_PIN MY_RF69_SPI_CS
827
#else
828
#define MY_RFM69_CS_PIN DEFAULT_RFM69_CS_PIN
829
836
#ifndef MY_RFM69_SPI_SPEED
837
#define MY_RFM69_SPI_SPEED (4*1000000ul) // datasheet says 10Mhz max.
838
848
//#define MY_RFM69_ENABLE_ENCRYPTION
849
870
//#define MY_RFM69_MODEM_CONFIGURATION (RFM69_FSK_BR55_5_FD50)
871
872
// End of RFM69SettingGrpPub group
874
889
890
895
//#define MY_DEBUG_VERBOSE_RFM95
896
907
//#define MY_RFM95_ENABLE_ENCRYPTION
908
923
#ifndef MY_RFM95_FREQUENCY
924
#define MY_RFM95_FREQUENCY (RFM95_868MHZ)
925
943
#ifndef MY_RFM95_MODEM_CONFIGRUATION
944
#define MY_RFM95_MODEM_CONFIGRUATION RFM95_BW125CR45SF128
945
951
//#define MY_RFM95_RST_PIN (9)
952
957
//#define MY_RFM95_POWER_PIN (3)
958
963
#ifndef MY_RFM95_IRQ_PIN
964
#define MY_RFM95_IRQ_PIN DEFAULT_RFM95_IRQ_PIN
965
971
#ifndef MY_RFM95_IRQ_NUM
972
#define MY_RFM95_IRQ_NUM digitalPinToInterrupt(MY_RFM95_IRQ_PIN)
973
979
#ifndef MY_RFM95_CS_PIN
980
#define MY_RFM95_CS_PIN DEFAULT_RFM95_CS_PIN
981
987
#ifndef MY_RFM95_SPI_SPEED
988
#define MY_RFM95_SPI_SPEED (4*1000000ul)
989
997
#ifndef MY_RFM95_TX_POWER_DBM
998
#define MY_RFM95_TX_POWER_DBM (13u) // 20mW
999
1005
//#define MY_RFM95_ATC_MODE_DISABLED
1006
1011
#ifndef MY_RFM95_ATC_TARGET_RSSI
1012
#define MY_RFM95_ATC_TARGET_RSSI (-70)
1013
1026
//#define MY_RFM95_MAX_POWER_LEVEL_DBM (10u)
1027
1034
//#define MY_RFM95_TCXO // End of RFM95SettingGrpPub group
1036
1052
//#define MY_RADIO_SX126x
1053
1058
#ifndef MY_SX126x_CS_PIN
1059
#define MY_SX126x_CS_PIN DEFAULT_SX126x_CS_PIN
1060
1066
#ifndef MY_SX126x_IRQ_PIN
1067
#define MY_SX126x_IRQ_PIN DEFAULT_SX126x_IRQ_PIN
1068
1074
#ifndef MY_SX126x_IRQ_NUM
1075
#define MY_SX126x_IRQ_NUM digitalPinToInterrupt(DEFAULT_SX126x_IRQ_PIN)
1076
1092
#ifndef MY_SX126x_FREQUENCY
1093
#define MY_SX126x_FREQUENCY (SX126x_868MHZ)
1094
1105
#ifndef MY_SX126x_LORA_SF
1106
#define MY_SX126x_LORA_SF LORA_SF7
1107
1129
#ifndef MY_SX126x_LORA_BW
1130
#define MY_SX126x_LORA_BW LORA_BW_125
1131
1147
#ifndef MY_SX126x_LORA_CR
1148
#define MY_SX126x_LORA_CR LORA_CR_4_5
1149
1168
//#define MY_SX126x_TCXO_VOLTAGE (SX126x_TCXO_3V3)
1169
1170
1178
#if !defined(MY_SX126c_TCXO_STARTUP_DELAY) && defined(MY_SX126x_TCXO_VOLTAGE)
1179
#define MY_SX126c_TCXO_STARTUP_DELAY (10)
1180
1188
#if !defined(MY_SX126x_USE_TCXO) && defined(MY_SX126x_TCXO_VOLTAGE)
1189
#define MY_SX126x_USE_TCXO
1190
1196
//#define MY_SX126x_USE_DIO2_ANT_SWITCH
1197
1205
//#define MY_SX126x_ANT_SWITCH_PIN (GPIO3)
1206
1215
#if !defined(MY_SX126x_VARIANT)
1216
#define MY_SX126x_VARIANT (1)
1217
1223
//#define MY_SX126x_POWER_PIN (3)
1224
1229
//#define MY_SX126x_RESET_PIN (47)
1230
1235
//#define MY_SX126x_BUSY_PIN (39)
1236
1241
//#define MY_SX126x_DISABLE_ATC
1242
1247
#ifndef MY_SX126x_ATC_TARGET_DBM
1248
#define MY_SX126x_ATC_TARGET_DBM (-70)
1249
1257
#ifndef MY_SX126x_MAX_POWER_LEVEL_DBM
1258
#define MY_SX126x_MAX_POWER_LEVEL_DBM (20)
1259
1265
#ifndef MY_SX126x_MIN_POWER_LEVEL_DBM
1266
#define MY_SX126x_MIN_POWER_LEVEL_DBM (-3)
1267
// End of SX126xSettingGrpPub group
1270
1285
//#define MY_RADIO_CC1101
1286
1291
#ifndef MY_CC1101_CS_PIN
1292
#define MY_CC1101_CS_PIN DEFAULT_CC1101_CS_PIN
1293
1299
#ifndef MY_CC1101_GD0_PIN
1300
#define MY_CC1101_GD0_PIN DEFAULT_CC1101_GD0_PIN
1301
#define MY_CC1101_GD0_NUM digitalPinToInterrupt(MY_CC1101_GD0_PIN)
1303
1316
#ifndef MY_CC1101_FREQUENCY
1317
#define MY_CC1101_FREQUENCY (CC1101_433MHZ)
1318
1330
#ifndef MY_CC1101_CHANNEL
1331
#define MY_CC1101_CHANNEL 4
1332
1343
//#define MY_CC1101_SYNC_WORD 0xF543
1344
1360
//#define MY_CC1101_MODEM_CONFIGURATION CC1101_MODEM_M_BR38_4_FD20
1361
1378
//#define MY_CC1101_POWER_LEVEL CC1101_POWER_AUTO
1379
1384
#ifndef MY_CC1101_ATC_TARGET_DBM
1385
#define MY_CC1101_ATC_TARGET_DBM (-50)
1386
1394
//#define MY_CC1101_MAX_POWER_LEVEL (7)
1395
1400
//#define MY_CC1101_MIN_POWER_LEVEL (0)
1401
// End of CC1101SettingGrpPub group
1403
1404
1405
1423
//#define MY_SOFTSPI
1424
1429
#ifndef MY_SOFT_SPI_SCK_PIN
1430
#define MY_SOFT_SPI_SCK_PIN (14)
1431
1437
#ifndef MY_SOFT_SPI_MISO_PIN
1438
#define MY_SOFT_SPI_MISO_PIN (16)
1439
1445
#ifndef MY_SOFT_SPI_MOSI_PIN
1446
#define MY_SOFT_SPI_MOSI_PIN (15)
1447
// End of SoftSpiSettingGrpPub group
1449
// End of TransportSettingGrpPub group
1451
1472
#ifndef MY_DISABLE_RAM_ROUTING_TABLE_FEATURE
1473
#define MY_RAM_ROUTING_TABLE_FEATURE
1474
1480
#ifndef MY_ROUTING_TABLE_SAVE_INTERVAL_MS
1481
#define MY_ROUTING_TABLE_SAVE_INTERVAL_MS (30*60*1000ul)
1482
1490
//#define MY_REPEATER_FEATURE
1491
1501
//#define MY_PASSIVE_NODE
1502
1507
#ifndef MY_NODE_ID
1508
#define MY_NODE_ID (AUTO)
1509
1515
#ifndef MY_PARENT_NODE_ID
1516
#define MY_PARENT_NODE_ID (AUTO)
1517
1523
//#define MY_PARENT_NODE_IS_STATIC
1524
1531
//#define MY_TRANSPORT_SANITY_CHECK
1532
1537
#ifndef MY_TRANSPORT_SANITY_CHECK_INTERVAL_MS
1538
#define MY_TRANSPORT_SANITY_CHECK_INTERVAL_MS (15*60*1000ul)
1539
1544
#ifndef MY_TRANSPORT_DISCOVERY_INTERVAL_MS
1545
#define MY_TRANSPORT_DISCOVERY_INTERVAL_MS (20*60*1000ul)
1546
1552
//#define MY_TRANSPORT_UPLINK_CHECK_DISABLED
1553
1558
//#define MY_TRANSPORT_MAX_TX_FAILURES (10u)
1559
1564
#ifndef MY_TRANSPORT_WAIT_READY_MS
1565
#define MY_TRANSPORT_WAIT_READY_MS (0)
1566
1573
//#define MY_SIGNAL_REPORT_ENABLED
1574
// End of RoutingNodeSettingGrpPub group
1576
1589
#define MY_REGISTRATION_FEATURE
1590
1596
#ifndef MY_REGISTRATION_RETRIES
1597
#define MY_REGISTRATION_RETRIES (3u)
1598
1605
#define MY_REGISTRATION_DEFAULT (true)
1606
1611
//#define MY_REGISTRATION_CONTROLLER // End of RegistrationSettingGrpPub group
1613
1624
//#define MY_CORE_ONLY
1625
1631
#define MY_CORE_COMPATIBILITY_CHECK
1632
// End of CoreSettingGrpPub group
1633
1644
#ifndef MY_SLEEP_TRANSPORT_RECONNECT_TIMEOUT_MS
1645
#define MY_SLEEP_TRANSPORT_RECONNECT_TIMEOUT_MS (10*1000ul)
1646
1655
#ifndef MY_SMART_SLEEP_WAIT_DURATION_MS
1656
#define MY_SMART_SLEEP_WAIT_DURATION_MS (500ul)
1657
1667
//#define MY_SLEEP_HANDLER // End of SleepSettingGrpPub group
1669
1685
//#define MY_OTA_FIRMWARE_FEATURE
1686
1691
#ifndef MY_OTA_FLASH_SS
1692
#define MY_OTA_FLASH_SS (8)
1693
1699
#ifndef MY_OTA_FLASH_JDECID
1700
#define MY_OTA_FLASH_JDECID (0x1F65)
1701
1707
//#define MY_DISABLE_REMOTE_RESET // End of OTASettingGrpPub group
1709
1720
#ifndef MY_GATEWAY_MAX_RECEIVE_LENGTH
1721
#define MY_GATEWAY_MAX_RECEIVE_LENGTH (100u)
1722
1728
#ifndef MY_GATEWAY_MAX_SEND_LENGTH
1729
#define MY_GATEWAY_MAX_SEND_LENGTH (120u)
1730
1736
#ifndef MY_GATEWAY_MAX_CLIENTS
1737
#define MY_GATEWAY_MAX_CLIENTS (1u)
1738
1744
1745
1752
1753
1754
// Disable inclusion mode button if inclusion mode feature is not enabled
1755
#ifndef MY_INCLUSION_MODE_FEATURE
1756
#undef MY_INCLUSION_BUTTON_FEATURE
1757
1766
//#define MY_INCLUSION_LED_PIN (7)
1767
1772
#ifndef MY_INCLUSION_MODE_BUTTON_PIN
1773
#if defined(ARDUINO_ARCH_ESP8266)
1774
#define MY_INCLUSION_MODE_BUTTON_PIN (5)
1775
#else
1776
#define MY_INCLUSION_MODE_BUTTON_PIN (3)
1777
1784
#ifndef MY_INCLUSION_MODE_DURATION
1785
#define MY_INCLUSION_MODE_DURATION (60)
1786
1798
#if defined(MY_INCLUSION_BUTTON_EXTERNAL_PULLUP)
1799
#define MY_INCLUSION_BUTTON_PRESSED (HIGH)
1800
#else
1801
#define MY_INCLUSION_BUTTON_PRESSED (LOW)
1802
1804
1805
* Ethernet Gateway Transport Defaults
1806
1827
// The gateway options available
1828
//#define MY_GATEWAY_W5100
1829
//#define MY_GATEWAY_ENC28J60
1830
//#define MY_GATEWAY_ESP8266
1831
//#define MY_GATEWAY_ESP8266_SECURE
1832
//#define MY_GATEWAY_ESP32
1833
//#define MY_GATEWAY_LINUX
1834
//#define MY_GATEWAY_TINYGSM
1835
//#define MY_GATEWAY_MQTT_CLIENT
1836
//#define MY_GATEWAY_SERIAL
1837
1838
1843
//#define MY_DEBUG_VERBOSE_GATEWAY
1844
1849
//#define MY_WIFI_SSID "MySSID"
1850
1855
#ifndef MY_WIFI_BSSID
1856
#define MY_WIFI_BSSID NULL
1857
1863
//#define MY_WIFI_PASSWORD "MyVerySecretPassword"
1864
1869
#ifndef MY_HOSTNAME
1870
#define MY_HOSTNAME "MYSENSORS_DEVICE"
1871
1877
#ifndef MY_PORT
1878
#ifdef MY_GATEWAY_MQTT_CLIENT
1879
#define MY_PORT 1883
1880
#else
1881
#define MY_PORT 5003
1882
1889
//#define MY_MQTT_CLIENT_PUBLISH_RETAIN
1890
1899
//#define MY_MQTT_PASSWORD "secretpassword"
1900
1909
1910
1918
//#define MY_MQTT_CLIENT_ID "mysensors-1"
1919
1927
//#define MY_MQTT_PUBLISH_TOPIC_PREFIX "mygateway1-out"
1928
1936
//#define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX "mygateway1-in"
1937
1973
//#define MY_MQTT_CA_CERT1
1974
1979
//#define MY_MQTT_CA_CERT2
1980
1985
//#define MY_MQTT_CA_CERT3
1986
1987
2005
//#define MY_MQTT_FINGERPRINT
2006
2024
//#define MY_MQTT_CLIENT_CERT
2025
2043
//#define MY_MQTT_CLIENT_KEY
2044
2051
//#define MY_IP_ADDRESS 192,168,178,66
2052
2059
//#define MY_IP_GATEWAY_ADDRESS 192,168,1,1
2060
2067
2068
2074
//#define MY_USE_UDP
2075
2081
#ifndef MY_MAC_ADDRESS
2082
#define MY_MAC_ADDRESS 0xDE,0xAD,0xBE,0xEF,0xFE,0xED
2083
2095
//#define MY_CONTROLLER_IP_ADDRESS 192,168,178,254
2096
2107
//#define MY_CONTROLLER_URL_ADDRESS "test.mosquitto.org"
2108
// End of GatewaySettingGrpPub group
2110
2121
//#define MY_GSM_APN
2126
//#define MY_GSM_BAUDRATE (9600u)
2131
//#define MY_GSM_PIN
2136
//#define MY_GSM_PSW
2141
//#define MY_GSM_RX
2146
//#define MY_GSM_SSID
2151
//#define MY_GSM_TX
2156
//#define MY_GSM_USR
2157
// End of GSMSettingGrpPub group
2159
2174
//#define MY_DEFAULT_ERR_LED_PIN (6)
2175
2184
//#define MY_DEFAULT_TX_LED_PIN (7)
2185
2194
//#define MY_DEFAULT_RX_LED_PIN (8)
2195
2202
//#define MY_WITH_LEDS_BLINKING_INVERSE
2203
2208
//#define MY_INDICATION_HANDLER
2209
2214
#ifndef MY_DEFAULT_LED_BLINK_PERIOD
2215
2216
// End of LEDSettingGrpPub group
2218
2259
//#define MY_SECURITY_SIMPLE_PASSWD "MyInsecurePassword"
2260
#if defined(MY_SECURITY_SIMPLE_PASSWD)
2261
#define MY_SIGNING_SIMPLE_PASSWD MY_SECURITY_SIMPLE_PASSWD
2262
#define MY_ENCRYPTION_SIMPLE_PASSWD MY_SECURITY_SIMPLE_PASSWD
2263
2277
//#define MY_DEBUG_VERBOSE_SIGNING
2278
2308
//#define MY_SIGNING_SIMPLE_PASSWD "MyInsecurePassword"
2309
#if defined(MY_SIGNING_SIMPLE_PASSWD)
2310
#define MY_SIGNING_SOFT
2311
#define MY_SIGNING_REQUEST_SIGNATURES
2312
2318
//#define MY_SIGNING_ATSHA204
2319
2324
//#define MY_SIGNING_SOFT
2325
2334
//#define MY_SIGNING_REQUEST_SIGNATURES
2335
2352
//#define MY_SIGNING_WEAK_SECURITY
2353
2365
#ifndef MY_VERIFICATION_TIMEOUT_MS
2366
#define MY_VERIFICATION_TIMEOUT_MS (5*1000ul)
2367
2385
//#define MY_SIGNING_NODE_WHITELISTING {{.nodeId = GATEWAY_ADDRESS,.serial = {0x09,0x08,0x07,0x06,0x05,0x04,0x03,0x02,0x01}}}
2386
2391
#ifndef MY_SIGNING_ATSHA204_PIN
2392
#define MY_SIGNING_ATSHA204_PIN (17)
2393
2401
#ifndef MY_SIGNING_SOFT_RANDOMSEED_PIN
2402
#define MY_SIGNING_SOFT_RANDOMSEED_PIN (7)
2403
2420
//#define MY_LOCK_DEVICE
2421
2427
#if defined(MY_SIGNING_ATSHA204) || defined(MY_SIGNING_SOFT)
2428
#define MY_SIGNING_FEATURE
2429
// End of SigningSettingGrpPub group
2431
2460
//#define MY_ENCRYPTION_SIMPLE_PASSWD "MyInsecurePassword"
2461
#if defined(MY_ENCRYPTION_SIMPLE_PASSWD)
2462
#ifndef MY_RF24_ENABLE_ENCRYPTION
2463
2464
#ifndef MY_RFM69_ENABLE_ENCRYPTION
2466
2467
#ifndef MY_NRF5_ESB_ENABLE_ENCRYPTION
2469
2470
#ifndef MY_RFM95_ENABLE_ENCRYPTION
2472
2473
2482
#if defined(MY_RF24_ENABLE_ENCRYPTION) || defined(MY_RFM69_ENABLE_ENCRYPTION) || defined(MY_NRF5_ESB_ENABLE_ENCRYPTION) || defined(MY_RFM95_ENABLE_ENCRYPTION)
2483
#define MY_ENCRYPTION_FEATURE
2484
// End of EncryptionSettingGrpPub group
2486
2526
//#define MY_NODE_LOCK_FEATURE
2527
2536
#ifndef MY_NODE_UNLOCK_PIN
2537
#define MY_NODE_UNLOCK_PIN (14)
2538
2546
#ifndef MY_NODE_LOCK_COUNTER_MAX
2547
#define MY_NODE_LOCK_COUNTER_MAX (5)
2548
// Node lock group // End of SecuritySettingGrpPub group
2551
2572
#ifndef MY_ESP8266_SERIAL_MODE
2573
#define MY_ESP8266_SERIAL_MODE SERIAL_FULL
2574
// End of ESP8266SettingGrpPub group
2576
2584
2585
// no ESP32 settings
2586
2587
// End of ESP32SettingGrpPub group
2589
2601
//#define MY_LINUX_SERIAL_PORT "/dev/ttyUSB0"
2602
2607
#ifdef MY_LINUX_SERIAL_PTY
2608
#warning MY_LINUX_SERIAL_PTY is deprecated, please use MY_LINUX_SERIAL_PORT
2609
#define MY_LINUX_SERIAL_PORT MY_LINUX_SERIAL_PTY
2610
2616
#ifdef MY_LINUX_IS_SERIAL_PTY
2617
#warning MY_LINUX_IS_SERIAL_PTY is deprecated, please use MY_LINUX_SERIAL_IS_PTY
2618
#define MY_LINUX_SERIAL_IS_PTY
2619
2628
//#define MY_LINUX_SERIAL_IS_PTY
2629
2634
//#define MY_LINUX_SERIAL_GROUPNAME "tty"
2635
2642
#ifndef MY_LINUX_CONFIG_FILE
2643
#define MY_LINUX_CONFIG_FILE "/etc/mysensors.conf"
2644
// End of LinuxSettingGrpPub group // End of PlatformSettingGrpPub group
2647
2648
2649
* "Helper" definitions
2650
2651
2652
2653
* Detect node type
2654
* MY_GATEWAY_FEATURE is set for gateway sketches.
2655
* MY_IS_GATEWAY is true when @ref MY_GATEWAY_FEATURE is set.
2656
* MY_NODE_TYPE contain a string describing the class of sketch/node (gateway/repeater/node).
2657
2658
#if defined(MY_GATEWAY_SERIAL) || defined(MY_GATEWAY_W5100) || defined(MY_GATEWAY_ENC28J60) || defined(MY_GATEWAY_ESP8266) || defined(MY_GATEWAY_ESP32)|| defined(MY_GATEWAY_LINUX) || defined(MY_GATEWAY_MQTT_CLIENT) || defined(MY_GATEWAY_TINYGSM)
2659
#define MY_GATEWAY_FEATURE
2660
#define MY_IS_GATEWAY (true)
2661
#define MY_NODE_TYPE "GW"
2662
#elif defined(MY_REPEATER_FEATURE)
2663
#define MY_IS_GATEWAY (false)
2664
#define MY_NODE_TYPE "REPEATER"
2665
#elif defined(DOXYGEN)
2666
2667
2668
#else
2669
2670
#define MY_NODE_TYPE "NODE"
2671
2673
// DEBUG
2674
#if defined(MY_DISABLED_SERIAL) && !defined(MY_DEBUG_OTA)
2675
#undef MY_DEBUG
2676
#if defined(MY_DEBUG)
2678
// standard debug output
2679
#define MY_DEBUG_VERBOSE_CORE
2680
#define MY_DEBUG_VERBOSE_TRANSPORT
2681
2682
2683
2685
#if defined(MY_DEBUG) || defined(MY_DEBUG_VERBOSE_CORE) || defined(MY_DEBUG_VERBOSE_TRANSPORT) || defined(MY_DEBUG_VERBOSE_GATEWAY) || defined(MY_DEBUG_VERBOSE_SIGNING) || defined(MY_DEBUG_VERBOSE_OTA_UPDATE) || defined(MY_DEBUG_VERBOSE_RF24) || defined(MY_DEBUG_VERBOSE_NRF5_ESB) || defined(MY_DEBUG_VERBOSE_RFM69) || defined(MY_DEBUG_VERBOSE_RFM95) || defined(MY_DEBUG_VERBOSE_SX126x) || defined(MY_DEBUG_VERBOSE_TRANSPORT_HAL)
2686
#define DEBUG_OUTPUT_ENABLED
2687
#ifndef MY_DEBUG_OTA
2688
#define DEBUG_OUTPUT(x,...) hwDebugPrint(x, ##__VA_ARGS__)
2689
#else
2690
#ifndef MY_OTA_LOG_SENDER_FEATURE
2691
2692
#ifndef MY_DEBUG_OTA_DISABLE_ECHO
2694
#define DEBUG_OUTPUT(x,...) OTALog((MY_DEBUG_OTA), true, x, ##__VA_ARGS__)
2695
#else
2696
#define DEBUG_OUTPUT(x,...) OTALog((MY_DEBUG_OTA), false, x, ##__VA_ARGS__)
2697
// disable radio related debugging messages
2699
#undef MY_DEBUG_VERBOSE_RF24
2700
#undef MY_DEBUG_VERBOSE_NRF5_ESB
2701
#undef MY_DEBUG_VERBOSE_RFM69
2702
#undef MY_DEBUG_VERBOSE_RFM69_REGISTERS
2703
#undef MY_DEBUG_VERBOSE_RFM95
2704
#undef MY_DEBUG_VERBOSE_SX126x
2705
#else
2707
2708
2710
// temp. workaround for nRF5 verifier: redirect RF24 to NRF_ESB
2711
#if defined(ARDUINO_ARCH_NRF5) && (defined(MY_RADIO_RF24) )
2712
#undef MY_RADIO_RF24
2713
2714
2716
// Enable sensor network "feature" if one of the transport types was enabled
2717
#if defined(MY_RADIO_RF24) || defined(MY_RADIO_NRF5_ESB) || defined(MY_RADIO_RFM69) || defined(MY_RADIO_RFM95) || defined(MY_RADIO_SX126x) || defined(MY_RS485) || defined(MY_PJON) || defined(MY_RADIO_CC1101)
2718
#define MY_SENSOR_NETWORK
2719
2721
// LEDS
2722
#if !defined(MY_DEFAULT_ERR_LED_PIN) && defined(MY_HW_ERR_LED_PIN)
2723
#define MY_DEFAULT_ERR_LED_PIN MY_HW_ERR_LED_PIN
2724
2726
#if !defined(MY_DEFAULT_TX_LED_PIN) && defined(MY_HW_TX_LED_PIN)
2727
#define MY_DEFAULT_TX_LED_PIN MY_HW_TX_LED_PIN
2728
2730
#if !defined(MY_DEFAULT_RX_LED_PIN) && defined(MY_HW_TX_LED_PIN)
2731
#define MY_DEFAULT_RX_LED_PIN MY_HW_TX_LED_PIN
2732
2734
#endif // MyConfig_h
2735
2736
// Doxygen specific constructs, not included when built normally
2737
// This is used to enable disabled macros/definitions to be included in the documentation as well.
2738
#if DOXYGEN
2739
2743
#define ARDUINO_ARCH_SAMD
2744
2749
#define ARDUINO_ARCH_NRF5
2750
2755
#define ARDUINO_ARCH_ESP8266
2756
2761
#define ARDUINO_ARCH_ESP32
2762
2767
#define ARDUINO_ARCH_AVR
2768
2773
#define ARDUINO_ARCH_MEGAAVR
2774
2779
#define ARDUINO_ARCH_STM32
2780
2785
#define TEENSYDUINO
2786
2787
// debug
2788
2790
2791
2792
2793
2794
2795
2796
#define MY_DIAGNOSTICS_CRYPTO
2797
// linux
2798
2799
2800
2801
#define MY_LINUX_SERIAL_PTY
2802
#define MY_LINUX_IS_SERIAL_PTY
2803
// inclusion mode
2804
2805
2806
// OTA logging and debug
2807
2808
2809
// transport
2810
2811
2812
2813
2814
2815
2816
2817
2818
2819
2820
2821
2822
2823
2824
2825
2826
2827
2828
2829
2830
// general
2831
2832
2833
2834
#define MY_DISABLE_RAM_ROUTING_TABLE_FEATURE
2835
2836
2837
// core
2838
2839
// GW
2840
2841
#define MY_INCLUSION_BUTTON_EXTERNAL_PULLUP
2842
2843
2844
2845
2846
2847
2848
2849
2850
2851
2852
2853
2854
2855
2856
2857
#define MY_USE_UDP
2858
2859
2860
// TinyGSM
2861
#define MY_GSM_APN
2862
2863
#define MY_GSM_PIN
2864
#define MY_GSM_PSW
2865
#define MY_GSM_RX
2866
#define MY_GSM_SSID
2867
#define MY_GSM_TX
2868
#define MY_GSM_USR
2869
// LED
2870
2871
2872
2873
// signing
2874
2875
2876
2877
2878
2879
2880
2881
2882
2883
2884
2885
// FOTA update
2886
2887
2888
// RS485
2889
#define MY_RS485
2890
2891
2892
2893
// PJON
2894
#define MY_PJON
2895
2896
// RF24
2897
2898
#define MY_RADIO_NRF24 //deprecated
2899
2900
2901
2902
2903
2904
2905
// NRF5_ESB
2906
2907
2908
2909
2910
2911
// RFM69
2912
#define MY_RADIO_RFM69
2913
2914
2915
2916
2917
2918
2919
2920
2921
2922
2923
// RFM95
2924
2925
2926
2927
2928
2929
2930
2931
2932
2933
// SX126x
2934
2935
2936
2937
2938
2939
2940
2941
2942
2943
2944
2945
2946
// SOFT-SPI
2947
#define MY_SOFTSPI
2948
2953
#define MY_ROUTES_SIZE
2954
2955
// End of MyConfig group
