+ Collaboration diagram for Routing and node:
These options control message routing and node configurations.
#define MY_RAM_ROUTING_TABLE_FEATURE
 If enabled, the routing table is kept in RAM (if memory allows) and saved in regular intervals. More...
#define MY_ROUTING_TABLE_SAVE_INTERVAL_MS   (30*60*1000ul)
 Interval to dump content of routing table to EEPROM.
#define MY_REPEATER_FEATURE
 Enables repeater functionality (relays messages from other nodes) More...
#define MY_PASSIVE_NODE
 If enabled, the node operates fully autonomously, i.e. messages are sent without ACKing. More...
#define MY_NODE_ID   (AUTO)
 Node id defaults to AUTO (tries to fetch id from controller).
#define MY_PARENT_NODE_ID   (AUTO)
 Node parent defaults to AUTO (tries to find a parent automatically).
#define MY_PARENT_NODE_IS_STATIC
 Define MY_PARENT_NODE_IS_STATIC to disable fall back if parent node fails.
#define MY_TRANSPORT_SANITY_CHECK
 If defined, will cause node to check transport in regular intervals to detect HW issues and re-initialize in case of failure. More...
#define MY_TRANSPORT_SANITY_CHECK_INTERVAL_MS   (15*60*1000ul)
 Interval (in ms) for transport sanity checks.
#define MY_TRANSPORT_DISCOVERY_INTERVAL_MS   (20*60*1000ul)
 This is a gateway-only feature: Interval (in ms) to issue network discovery checks.
#define MY_TRANSPORT_UPLINK_CHECK_DISABLED
 If defined, disables uplink check to GW during transport initialisation.
#define MY_TRANSPORT_WAIT_READY_MS   (0)
 Timeout in ms until transport is ready during startup, set to 0 for no timeout.
#define MY_SIGNAL_REPORT_ENABLED
 Enables signal report functionality. More...
◆ MY_PASSIVE_NODE
Note
All transport-related checks and safety-mechanisms are disabled.
Requires that MY_NODE_ID is set, MY_PARENT_NODE_ID and MY_PARENT_NODE_IS_STATIC are optional.
Singing, registration, and OTA FW update are disabled.
Definition at line 2816 of file MyConfig.h.
◆ MY_RAM_ROUTING_TABLE_FEATURE
Note
Enabled by default on most platforms, but on AVR only for atmega1280, atmega1284 and atmega2560.
See also
MY_DISABLE_RAM_ROUTING_TABLE_FEATURE
Definition at line 1473 of file MyConfig.h.
◆ MY_REPEATER_FEATURE
Note
Repeaters need to be constantly kept awake to be useful. They are therefore not suitable for battery powered operation.
Definition at line 2815 of file MyConfig.h.
◆ MY_SIGNAL_REPORT_ENABLED
Note
This feature adds ~1kB code to the sketch.
Definition at line 2829 of file MyConfig.h.
◆ MY_TRANSPORT_SANITY_CHECK
Note
This feature is enabled for all repeater nodes (incl. GW)
Definition at line 2813 of file MyConfig.h.
