+ Collaboration diagram for RS485:
These options are specific to the RS485 wired transport.
#define MY_RS485
 Define this to use the RS485 wired transport for sensor network communication.
#define MY_RS485_BAUD_RATE   (9600)
 The RS485 BAUD rate.
#define MY_RS485_MAX_MESSAGE_LENGTH   (40)
 The maximum message length used for RS485.
#define MY_RS485_SOH_COUNT   (1)
 Use this in case of collisions on the bus. 3 might be a good setting.
#define MY_RS485_DE_PIN
 RS485 driver enable pin.
#define MY_RS485_DE_INVERSE
 Define this if RS485 driver enable pin polarity is inverted (low-active).
#define MY_RS485_HWSERIAL
 Define this if RS485 is connected to a hardware serial port. More...
◆ MY_RS485_HWSERIAL
Example:
#define MY_RS485_HWSERIAL Serial1
Definition at line 2957 of file MyConfig.h.
