+ Collaboration diagram for Node locking:
These options control node lock related configurations.
This feature locks a node that suspect itself for being under some form of attack.
This is achieved by having a counter stored in EEPROM which decrements when suspicious activity is detected.
If the counter reaches 0, the node will not work anymore and will transmit a I_LOCKED message to the gateway/controller with 30 minute intervals. Payload is a string with a reason for the locking.
The string is abbreviated to accommodate a signature. The following abbreviations exist at the moment:
Typically, the counter only decrements when suspicious activity happens in a row. It is reset if legit traffic is present.
Examples of malicious activity are:
If counter reaches zero, node locks down and EEPROM has to be erased/reset to reactivate node. Node can also be unlocked by grounding a pin.
See also
MY_NODE_UNLOCK_PIN
The size of the counter can be adjusted using MY_NODE_LOCK_COUNTER_MAX.
#define MY_NODE_LOCK_FEATURE
 Enable this to activate intrusion prevention mechanisms on the node.
#define MY_NODE_UNLOCK_PIN   (14)
 By grounding this pin during reset of a locked node, the node will unlock. More...
#define MY_NODE_LOCK_COUNTER_MAX   (5)
 Maximum accepted occurrences of suspected malicious activity in a node. More...
◆ MY_NODE_LOCK_COUNTER_MAX
Counter decrements on reoccurring incidents but resets if legitimate behaviour is identified.
Definition at line 2612 of file MyConfig.h.
◆ MY_NODE_UNLOCK_PIN
If using a secure bootloader, grounding the pin is the only option to reactivate the node. If using stock Android bootloader or a DualOptiBoot it is also possible to download a sketch using serial protocol to erase EEPROM to unlock the node.
Definition at line 2602 of file MyConfig.h.
