2.3.2-115-ge413c938
Collaboration diagram for RFM69:These options are specific to the RFM69 family of wireless transport modules.
If using the HW variant of the RFM69 module, define MY_IS_RFM69HW.
| #define | MY_RADIO_RFM69 |
| Define this to use RFM69 based radios for sensor network communication. | |
| #define | MY_DEBUG_VERBOSE_RFM69 |
| Define this for verbose debug prints related to the RFM69 driver. | |
| #define | MY_DEBUG_VERBOSE_RFM69_REGISTERS |
| Define this for verbose dumping of the RFM69 registers. | |
| #define | MY_RFM69_NEW_DRIVER |
| Define this to enable the improved RFM69 driver. More... | |
| #define | MY_RFM69_FREQUENCY (RFM69_868MHZ) |
| The frequency to use. More... | |
| #define | MY_IS_RFM69HW |
| Define this if you are using the RFM69HW model. | |
| #define | MY_RFM69HW false |
| Set to true if MY_IS_RFM69HW is set. More... | |
| #define | MY_RFM69_TX_POWER_DBM (5) |
| Set TX power level, default 5dBm (overridden if ATC mode enabled). | |
| #define | MY_RFM69_ATC_TARGET_RSSI_DBM (-80) |
| Target RSSI level (in dBm) for RFM69 ATC mode. | |
| #define | MY_RFM69_ATC_MODE_DISABLED |
| Define to disable ATC mode of RFM69 driver. | |
| #define | MY_RFM69_MAX_POWER_LEVEL_DBM |
| Set max TX power in dBm if local legislation requires this. More... | |
| #define | MY_RFM69_NETWORKID (100) |
| RFM69 Network ID. Use the same for all nodes that will talk to each other. | |
| #define | MY_RFM69_RST_PIN |
| Define this to use the RFM69 reset pin (optional). | |
| #define | MY_RFM69_POWER_PIN |
| Define this to use the RFM69 power pin (optional). | |
| #define | MY_RFM69_IRQ_PIN DEFAULT_RFM69_IRQ_PIN |
| Define this to override the default RFM69 IRQ pin assignment. | |
| #define | MY_RFM69_IRQ_NUM digitalPinToInterrupt(MY_RFM69_IRQ_PIN) |
| RFM69 IRQ number. | |
| #define | MY_RFM69_CS_PIN DEFAULT_RFM69_CS_PIN |
| RFM69 SPI chip select pin. | |
| #define | MY_RFM69_SPI_SPEED (4*1000000ul) |
| Set to overrule default RFM69 SPI speed. | |
| #define | MY_RFM69_ENABLE_ENCRYPTION |
| Define this to enable AES encryption in the RFM69 module. More... | |
| #define | MY_RFM69_MODEM_CONFIGURATION |
| RFM69 modem configuration, default is RFM69_FSK_BR55_5_FD50 More... | |
| #define MY_RFM69_ENABLE_ENCRYPTION |
Definition at line 2976 of file MyConfig.h.
| #define MY_RFM69_FREQUENCY (RFM69_868MHZ) |
Definition at line 754 of file MyConfig.h.
| #define MY_RFM69_MAX_POWER_LEVEL_DBM |
See here: https://en.wikipedia.org/wiki/Short_Range_Devices
Definition at line 2978 of file MyConfig.h.
| #define MY_RFM69_MODEM_CONFIGURATION |
| Configuration | Modulation (xxx) | Bit rate | FD | RXBW | Additional settings |
| RFM69_xxx_BR2_FD5 | FSK/GFSK/OOK | 2000 | 5000 | 111_24_4 | Whitening |
| RFM69_xxx_BR2_4_FD4_8 | FSK/GFSK/OOK | 2400 | 4800 | 111_24_4 | Whitening |
| RFM69_xxx_BR4_8_FD9_6 | FSK/GFSK/OOK | 4800 | 9600 | 111_24_4 | Whitening |
| RFM69_xxx_BR9_6_FD19_2 | FSK/GFSK/OOK | 9600 | 19200 | 111_24_4 | Whitening |
| RFM69_xxx_BR19_2_FD38_4 | FSK/GFSK/OOK | 19200 | 38400 | 111_24_3 | Whitening |
| RFM69_xxx_BR38_4_FD76_8 | FSK/GFSK/OOK | 38400 | 76800 | 111_24_2 | Whitening |
| RFM69_xxx_BR55_5_FD50 | FSK/GFSK/OOK | 55555 | 50000 | 111_16_2 | Whitening |
| RFM69_xxx_BR57_6_FD120 | FSK/GFSK/OOK | 57600 | 120000 | 111_16_1 | Whitening |
| RFM69_xxx_BR125_FD125 | FSK/GFSK/OOK | 125000 | 125000 | 010_16_2 | Whitening |
| RFM69_xxx_BR250_FD250 | FSK/GFSK/OOK | 250000 | 250000 | 111_16_0 | Whitening |
https://www.semtech.com/uploads/documents/sx1231.pdf
Definition at line 2975 of file MyConfig.h.
| #define MY_RFM69_NEW_DRIVER |
Definition at line 2973 of file MyConfig.h.
| #define MY_RFM69HW false |
Definition at line 772 of file MyConfig.h.
