Classes | Macros | Typedefs | Enumerations | Functions
+ Collaboration diagram for RFM95:
API declaration for RFM95.
RFM95 driver-related log messages, format: [!]SYSTEM:[SUB SYSTEM:]MESSAGE
E SYS SUB Message Comment
RFM95 INIT Initialise RFM95 radio
RFM95 INIT PIN,CS=%d,IQP=%d,IQN=%d[,RST=%d] Pin configuration: chip select (CS), IRQ pin (IQP), IRQ number (IQN), Reset (RST)
! RFM95 INIT SANCHK FAIL Sanity check failed, check wiring or replace module
! RFM95 IRH CRC FAIL Incoming packet has CRC error, skip
RFM95 RCV SEND ACK ACK request received, sending ACK back
RFM95 PTC LEVEL=%d Set TX power level
RFM95 SAC SEND ACK,TO=%d,RSSI=%d,SNR=%d Send ACK to node (TO), RSSI of received message (RSSI), SNR of message (SNR)
RFM95 ATC ADJ TXL,cR=%d,tR=%d..%d,TXL=%d Adjust TX level, current RSSI (cR), target RSSI range (tR), TX level (TXL)
RFM95 SWR SEND,TO=%d,RETRY=%d Send message to (TO), NACK retry counter (RETRY)
RFM95 SWR ACK FROM=%d,SEQ=%d,RSSI=%d,SNR=%d ACK received from node (FROM), seq ID (SEQ), (RSSI), (SNR)
! RFM95 SWR NACK No ACK received
RFM95 SPP PCT=%d,TX LEVEL=%d Set TX level percent (PCT), TX level (LEVEL)
RFM95 PWD Power down radio
RFM95 PWU Power up radio
RFM95 modem configuration
BW = Bandwidth in kHz CR = Error correction code SF = Spreading factor, chips / symbol
CONFIG BW CR SF Comment air-time (15 bytes)
BW125CR45SF128 125 4/5 128 Default, medium range 50ms
BW500CR45SF128 500 4/5 128 Fast, short range 15ms
BW31_25CR48SF512 31.25 4/8 512 Slow, long range 900ms
BW125CR48SF4096 125 4/8 4096 Slow, long range 1500ms
See here for air-time calculation: https://docs.google.com/spreadsheets/d/1voGAtQAjC1qBmaVuP1ApNKs1ekgUjavHuVQIXyYSvNc
Classes
struct  rfm95_modemConfig_t
 RFM95 modem config registers. More...
struct  __attribute__
 FW config structure, stored in eeprom. More...
struct  rfm95_internal_t
 RFM95 internal variables. More...
#define RFM95_SPI   hwSPI
 default SPI
#define DEFAULT_RFM95_IRQ_PIN   (2)
 DEFAULT_RFM95_IRQ_PIN.
#define DEFAULT_RFM95_CS_PIN   (SS)
 DEFAULT_RFM95_CS_PIN.
#define RFM95_SPI_DATA_ORDER   MSBFIRST
 SPI data order.
#define RFM95_SPI_DATA_MODE   SPI_MODE0
 SPI mode.
#define RFM95_BW125CR45SF128   RFM95_BW_125KHZ | RFM95_CODING_RATE_4_5, RFM95_SPREADING_FACTOR_128CPS | RFM95_RX_PAYLOAD_CRC_ON, RFM95_AGC_AUTO_ON
 0x72,0x74,0x04
#define RFM95_BW500CR45SF128   RFM95_BW_500KHZ | RFM95_CODING_RATE_4_5, RFM95_SPREADING_FACTOR_128CPS | RFM95_RX_PAYLOAD_CRC_ON, RFM95_AGC_AUTO_ON
 0x92,0x74,0x04
#define RFM95_BW31_25CR48SF512   RFM95_BW_31_25KHZ | RFM95_CODING_RATE_4_8, RFM95_SPREADING_FACTOR_512CPS | RFM95_RX_PAYLOAD_CRC_ON, RFM95_AGC_AUTO_ON
 0x48,0x94,0x04
#define RFM95_BW125CR48SF4096   RFM95_BW_125KHZ | RFM95_CODING_RATE_4_8, RFM95_SPREADING_FACTOR_4096CPS | RFM95_RX_PAYLOAD_CRC_ON, RFM95_AGC_AUTO_ON | RFM95_LOW_DATA_RATE_OPTIMIZE
 0x78,0xc4,0x0C
#define RFM95_RETRY_TIMEOUT_MS   (500ul)
 Timeout for ACK, adjustments needed if modem configuration changed (air time different)
#define MY_RFM95_TX_TIMEOUT_MS   (5*1000ul)
 TX timeout.
#define RFM95_169MHZ   (169000000ul)
 169 Mhz
#define RFM95_315MHZ   (315000000ul)
 315 Mhz
#define RFM95_434MHZ   (433920000ul)
 433.92 Mhz
#define RFM95_868MHZ   (868100000ul)
 868.1 Mhz
#define RFM95_915MHZ   (915000000ul)
 915 Mhz
#define RFM95_RETRIES   (5u)
 Retries in case of failed transmission.
#define RFM95_FIFO_SIZE   (0xFFu)
 Max number of bytes the LORA Rx/Tx FIFO can hold.
#define RFM95_RX_FIFO_ADDR   (0x00u)
 RX FIFO addr pointer.
#define RFM95_TX_FIFO_ADDR   (0x80u)
 TX FIFO addr pointer.
#define RFM95_MAX_PACKET_LEN   (0x40u)
 This is the maximum number of bytes that can be carried by the LORA.
#define RFM95_PREAMBLE_LENGTH   (8u)
 Preamble length, default=8.
#define RFM95_CAD_TIMEOUT_MS   (2*1000ul)
 channel activity detection timeout
#define RFM95_POWERUP_DELAY_MS   (100u)
 Power up delay, allow VCC to settle, transport to become fully operational.
#define RFM95_PACKET_HEADER_VERSION   (1u)
 RFM95 packet header version.
#define RFM95_MIN_PACKET_HEADER_VERSION   (1u)
 Minimal RFM95 packet header version.
#define RFM95_BIT_ACK_REQUESTED   (7u)
 RFM95 header, controlFlag, bit 7.
#define RFM95_BIT_ACK_RECEIVED   (6u)
 RFM95 header, controlFlag, bit 6.
#define RFM95_BIT_ACK_RSSI_REPORT   (5u)
 RFM95 header, controlFlag, bit 5.
#define RFM95_BROADCAST_ADDRESS   (255u)
 Broadcasting address.
#define RFM95_ATC_TARGET_RANGE_DBM   (2u)
 ATC target range +/- dBm.
#define RFM95_RSSI_OFFSET   (137u)
 RSSI offset.
#define RFM95_TARGET_RSSI   (-70)
 RSSI target.
#define RFM95_PROMISCUOUS   (false)
 RFM95 promiscuous mode.
#define RFM95_FXOSC   (32*1000000ul)
 The crystal oscillator frequency of the module.
#define RFM95_FSTEP   (RFM95_FXOSC / 524288.0f)
 The Frequency Synthesizer step.
#define RFM95_getACKRequested(__value)   ((bool)bitRead(__value, RFM95_BIT_ACK_REQUESTED))
 getACKRequested
#define RFM95_setACKRequested(__value, __flag)   bitWrite(__value, RFM95_BIT_ACK_REQUESTED,__flag)
 setACKRequested
#define RFM95_getACKReceived(__value)   ((bool)bitRead(__value, RFM95_BIT_ACK_RECEIVED))
 getACKReceived
#define RFM95_setACKReceived(__value, __flag)   bitWrite(__value, RFM95_BIT_ACK_RECEIVED,__flag)
 setACKReceived
#define RFM95_setACKRSSIReport(__value, __flag)   bitWrite(__value, RFM95_BIT_ACK_RSSI_REPORT,__flag)
 setACKRSSIReport
#define RFM95_getACKRSSIReport(__value)   ((bool)bitRead(__value, RFM95_BIT_ACK_RSSI_REPORT))
 getACKRSSIReport
#define RFM95_internalToSNR(__value)   ((int8_t)(__value / 4))
 Convert internal SNR to SNR.
#define RFM95_MIN_POWER_LEVEL_DBM   ((rfm95_powerLevel_t)5u)
 min. power level
#define RFM95_MAX_POWER_LEVEL_DBM   ((rfm95_powerLevel_t)23u)
 max. power level
#define RFM95_HEADER_LEN   sizeof(rfm95_header_t)
 Size header inside LoRa payload.
#define RFM95_MAX_PAYLOAD_LEN   (RFM95_MAX_PACKET_LEN - RFM95_HEADER_LEN)
 Max payload length.
#define LOCAL   static
 static
Typedefs
typedef uint16_t rfm95_sequenceNumber_t
 Sequence number data type.
typedef uint8_t rfm95_RSSI_t
 RSSI data type.
typedef int8_t rfm95_SNR_t
 SNR data type.
typedef uint8_t rfm95_controlFlags_t
 Control flag data type.
typedef int8_t rfm95_powerLevel_t
 Power level in dBm.
Enumerations
enum  rfm95_radioMode_t {
  RFM95_RADIO_MODE_RX = 0, RFM95_RADIO_MODE_TX = 1, RFM95_RADIO_MODE_CAD = 2, RFM95_RADIO_MODE_SLEEP = 3,
  RFM95_RADIO_MODE_STDBY = 4
 Radio modes. More...
LOCAL bool RFM95_initialise (const uint32_t frequencyHz)
 Initialise the driver transport hardware and software. More...
LOCAL void RFM95_setAddress (const uint8_t addr)
 Set the driver/node address. More...
LOCAL uint8_t RFM95_getAddress (void)
 Get driver/node address. More...
LOCAL void RFM95_setModemRegisters (const rfm95_modemConfig_t *config)
 Sets all the registers required to configure the data modem in the RF95/96/97/98, including the bandwidth, spreading factor etc. More...
LOCAL bool RFM95_available (void)
 Tests whether a new message is available. More...
LOCAL uint8_t RFM95_receive (uint8_t *buf, const uint8_t maxBufSize)
 If a valid message is received, copy it to buf and return length. 0 byte messages are permitted. More...
LOCAL bool RFM95_send (const uint8_t recipient, uint8_t *data, const uint8_t len, const rfm95_controlFlags_t flags, const bool increaseSequenceCounter=true)
 RFM95_send. More...
LOCAL bool RFM95_sendFrame (rfm95_packet_t *packet, const bool increaseSequenceCounter=true)
 RFM95_sendFrame. More...
LOCAL void RFM95_setPreambleLength (const uint16_t preambleLength)
 RFM95_setPreambleLength. More...
LOCAL void RFM95_setFrequency (const uint32_t frequencyHz)
 Sets the transmitter and receiver centre frequency. More...
LOCAL bool RFM95_setTxPowerLevel (rfm95_powerLevel_t newPowerLevel)
 Sets the transmitter power output level, and configures the transmitter pin. More...
LOCAL bool RFM95_setTxPowerPercent (const uint8_t newPowerPercent)
 Sets the transmitter power output percent. More...
LOCAL void RFM95_enableTCXO (void)
 Enable TCXO mode Call this immediately after init(), to force your radio to use an external frequency source, such as a Temperature Compensated Crystal Oscillator (TCXO). See the comments in the main documentation about the sensitivity of this radio to clock frequency especially when using narrow bandwidths. More...
LOCAL bool RFM95_sleep (void)
 Sets the radio into low-power sleep mode. More...
LOCAL bool RFM95_standBy (void)
 Sets the radio into standby mode. More...
LOCAL void RFM95_powerDown (void)
 Powerdown radio, if RFM95_POWER_PIN defined.
LOCAL void RFM95_powerUp (void)
 Powerup radio, if RFM95_POWER_PIN defined.
LOCAL void RFM95_sendACK (const uint8_t recipient, const rfm95_sequenceNumber_t sequenceNumber, const rfm95_RSSI_t RSSI, const rfm95_SNR_t SNR)
 RFM95_sendACK. More...
LOCAL bool RFM95_sendWithRetry (const uint8_t recipient, const void *buffer, const uint8_t bufferSize, const bool noACK)
 RFM95_sendWithRetry. More...
LOCAL bool RFM95_waitCAD (void)
 Wait until no channel activity detected. More...
LOCAL bool RFM95_setRadioMode (const rfm95_radioMode_t newRadioMode)
 RFM95_setRadioMode. More...
LOCAL void RFM95_interruptHandler (void)
 Low level interrupt handler.
LOCAL void RFM95_interruptHandling (void)
 Packet engine.
LOCAL void RFM95_handler (void)
 RFM95_handler.
LOCAL int16_t RFM95_getReceivingRSSI (void)
 RFM95_getSendingRSSI. More...
LOCAL int16_t RFM95_getSendingRSSI (void)
LOCAL int16_t RFM95_getReceivingSNR (void)
 RFM95_getReceivingSNR. More...
LOCAL int16_t RFM95_getSendingSNR (void)
 RFM95_getSendingSNR. More...
LOCAL uint8_t RFM95_getTxPowerPercent (void)
 Get transmitter power level. More...
LOCAL uint8_t RFM95_getTxPowerLevel (void)
LOCAL bool RFM95_executeATC (const rfm95_RSSI_t currentRSSI, const rfm95_RSSI_t targetRSSI)
 RFM_executeATC. More...
LOCAL void RFM95_ATCmode (const bool OnOff, const int16_t targetRSSI=RFM95_TARGET_RSSI)
 RFM95_ATCmode. More...
LOCAL bool RFM95_sanityCheck (void)
 RFM95_sanityCheck. More...
Enumeration Type Documentation
◆ rfm95_radioMode_t
Radio modes.
Enumerator
RFM95_RADIO_MODE_RX
RX mode.
RFM95_RADIO_MODE_TX
TX mode.
CAD mode.
SLEEP mode.
STDBY mode.
Definition at line 186 of file RFM95.h.
◆ RFM95_ATCmode()
LOCAL void RFM95_ATCmode ( const bool  OnOff,
const int16_t  targetRSSI = RFM95_TARGET_RSSI
RFM95_ATCmode.
targetRSSITarget RSSI for transmitter (default -60)
OnOffTrue to enable ATC
◆ RFM95_available()
LOCAL bool RFM95_available ( void  )
Returns
True if a new, complete, error-free uncollected message is available to be retreived by RFM95_receive()
◆ RFM95_enableTCXO()
LOCAL void RFM95_enableTCXO ( void  )
Note
Has to be called while radio is in sleep mode.
◆ RFM95_executeATC()
LOCAL bool RFM95_executeATC ( const rfm95_RSSI_t  currentRSSI,
RFM_executeATC.
currentRSSI
targetRSSI
Returns
True if power level adjusted
◆ RFM95_getAddress()
LOCAL uint8_t RFM95_getAddress ( void  )
Returns
Node address
◆ RFM95_getReceivingRSSI()
LOCAL int16_t RFM95_getReceivingRSSI ( void  )
Returns
RSSI Signal strength of last packet received
◆ RFM95_getReceivingSNR()
LOCAL int16_t RFM95_getReceivingSNR ( void  )
Returns
SNR
◆ RFM95_getSendingRSSI()
LOCAL int16_t RFM95_getSendingRSSI ( void  )
Returns
RSSI Signal strength of last packet sent (if ACK and ATC enabled)
◆ RFM95_getSendingSNR()
LOCAL int16_t RFM95_getSendingSNR ( void  )
Returns
SNR of last packet sent (if ACK and ATC enabled)
◆ RFM95_getTxPowerLevel()
LOCAL uint8_t RFM95_getTxPowerLevel ( void  )
Returns
Transmitter power level in dBm
◆ RFM95_getTxPowerPercent()
LOCAL uint8_t RFM95_getTxPowerPercent ( void  )
Returns
Transmitter power level in percents
◆ RFM95_initialise()
LOCAL bool RFM95_initialise ( const uint32_t  frequencyHz)
frequencyHzTransmitter frequency in Hz
Returns
True if initialisation succeeded
◆ RFM95_receive()
LOCAL uint8_t RFM95_receive ( uint8_t *  buf,
bufLocation to copy the received message
maxBufSizeMax buffer size
Returns
Number of bytes
◆ RFM95_sanityCheck()
LOCAL bool RFM95_sanityCheck ( void  )
RFM95_sanityCheck.
Returns
True if sanity check passed
◆ RFM95_send()
LOCAL bool RFM95_send ( const uint8_t  recipient,
uint8_t *  data,
const uint8_t  len,
const bool  increaseSequenceCounter = true
RFM95_send.
recipient
len
flags
Returns
True if packet sent
◆ RFM95_sendACK()
LOCAL void RFM95_sendACK ( const uint8_t  recipient,
RFM95_sendACK.
recipient
sequenceNumber
RSSI(rfm95_RSSI_t)
SNR(rfm95_SNR_t)
◆ RFM95_sendFrame()
LOCAL bool RFM95_sendFrame ( rfm95_packet_t *  packet,
RFM95_sendFrame.
packet
Returns
True if frame sent
◆ RFM95_sendWithRetry()
LOCAL bool RFM95_sendWithRetry ( const uint8_t  recipient,
const void *  buffer,
const bool  noACK
recipient
buffer
bufferSize
noACK
Returns
True if packet successfully sent
◆ RFM95_setAddress()
LOCAL void RFM95_setAddress ( const uint8_t  addr)
addr
◆ RFM95_setFrequency()
LOCAL void RFM95_setFrequency ( const uint32_t  frequencyHz)
frequencyHzFrequency in Hz
◆ RFM95_setModemRegisters()
LOCAL void RFM95_setModemRegisters ( const rfm95_modemConfig_t config)
configSee modemConfig_t and references therein
◆ RFM95_setPreambleLength()
LOCAL void RFM95_setPreambleLength ( const uint16_t  preambleLength)
preambleLength
◆ RFM95_setRadioMode()
LOCAL bool RFM95_setRadioMode ( const rfm95_radioMode_t  newRadioMode)
RFM95_setRadioMode.
newRadioMode
Returns
True if mode changed
◆ RFM95_setTxPowerLevel()
LOCAL bool RFM95_setTxPowerLevel ( rfm95_powerLevel_t  newPowerLevel)
newPowerLevelTransmitter power level in dBm (+5 to +23)
Returns
True power level adjusted
◆ RFM95_setTxPowerPercent()
LOCAL bool RFM95_setTxPowerPercent ( const uint8_t  newPowerPercent)
newPowerPercentTransmitter power level in percent
Returns
◆ RFM95_sleep()
LOCAL bool RFM95_sleep ( void  )
Returns
true if sleep mode was successfully entered
◆ RFM95_standBy()
LOCAL bool RFM95_standBy ( void  )
Returns
true if standby mode was successfully entered
◆ RFM95_waitCAD()
LOCAL bool RFM95_waitCAD ( void  )
Returns
True if no channel activity detected, False if timeout occured
