RFM69_RFM95_ATC_SignalReport.ino
21  * REVISION HISTORY
22  * Version 1.1 - tekka
23  *
24  * DESCRIPTION
25  * ATC mode settings and signal report functions, on RFM69 and RFM95 nodes
26  *
27  */
29 // Enable debug prints
30 #define MY_DEBUG
32 // Enable signal report functionalities
33 #define MY_SIGNAL_REPORT_ENABLED
35 // Enable and select radio type attached
37 // RFM69
38 //#define MY_RADIO_RFM69
39 //#define MY_RFM69_NEW_DRIVER // ATC on RFM69 works only with the new driver (not compatible with old=default driver)
40 //#define MY_RFM69_ATC_TARGET_RSSI_DBM (-70) // target RSSI -70dBm
41 //#define MY_RFM69_MAX_POWER_LEVEL_DBM (10) // max. TX power 10dBm = 10mW
43 // RFM95
44 #define MY_RADIO_RFM95
45 #define MY_RFM95_ATC_TARGET_RSSI_DBM (-70) // target RSSI -70dBm
46 #define MY_RFM95_MAX_POWER_LEVEL_DBM (10) // max. TX power 10dBm = 10mW
48 #include <MySensors.h>
50 // ID of the sensor child
51 #define CHILD_ID_UPLINK_QUALITY (0)
52 #define CHILD_ID_TX_LEVEL (1)
53 #define CHILD_ID_TX_PERCENT (2)
54 #define CHILD_ID_TX_RSSI (3)
55 #define CHILD_ID_RX_RSSI (4)
56 #define CHILD_ID_TX_SNR (5)
57 #define CHILD_ID_RX_SNR (6)
60 // Initialize general message
61 MyMessage msgTxRSSI(CHILD_ID_TX_RSSI, V_CUSTOM);
62 MyMessage msgRxRSSI(CHILD_ID_RX_RSSI, V_CUSTOM);
63 MyMessage msgTxSNR(CHILD_ID_TX_SNR, V_CUSTOM);
64 MyMessage msgRxSNR(CHILD_ID_RX_SNR, V_CUSTOM);
65 MyMessage msgTxLevel(CHILD_ID_TX_LEVEL, V_CUSTOM);
66 MyMessage msgTxPercent(CHILD_ID_TX_PERCENT, V_CUSTOM);
67 MyMessage msgUplinkQuality(CHILD_ID_UPLINK_QUALITY, V_CUSTOM);
69 void setup()
70 {
71 }
75 {
76  // Send the sketch version information to the gateway and controller
77  sendSketchInfo("ATC", "1.1");
79  // Register all sensors to gw (they will be created as child devices)
80  present(CHILD_ID_UPLINK_QUALITY, S_CUSTOM, "UPLINK QUALITY RSSI");
81  present(CHILD_ID_TX_LEVEL, S_CUSTOM, "TX LEVEL DBM");
82  present(CHILD_ID_TX_PERCENT, S_CUSTOM, "TX LEVEL PERCENT");
83  present(CHILD_ID_TX_RSSI, S_CUSTOM, "TX RSSI");
84  present(CHILD_ID_RX_RSSI, S_CUSTOM, "RX RSSI");
85  present(CHILD_ID_TX_SNR, S_CUSTOM, "TX SNR");
86  present(CHILD_ID_RX_SNR, S_CUSTOM, "RX SNR");
87 }
89 void loop()
90 {
91  // send messages to GW
92  send(msgUplinkQuality.set(transportGetSignalReport(SR_UPLINK_QUALITY)));
93  send(msgTxLevel.set(transportGetSignalReport(SR_TX_POWER_LEVEL)));
94  send(msgTxPercent.set(transportGetSignalReport(SR_TX_POWER_PERCENT)));
95  // retrieve RSSI / SNR reports from incoming ACK
96  send(msgTxRSSI.set(transportGetSignalReport(SR_TX_RSSI)));
97  send(msgRxRSSI.set(transportGetSignalReport(SR_RX_RSSI)));
98  send(msgTxSNR.set(transportGetSignalReport(SR_TX_SNR)));
99  send(msgRxSNR.set(transportGetSignalReport(SR_RX_SNR)));
100  // wait a bit
101  wait(5000);
102 }
Definition: RFM69_RFM95_ATC_SignalReport.ino:89
int16_t transportGetSignalReport(const signalReport_t signalReport) __attribute__((unused))
Get transport signal report.
Definition: RFM69_RFM95_ATC_SignalReport.ino:74
MyMessage::set
send
present
Definition: RFM69_RFM95_ATC_SignalReport.ino:69
wait
void wait(const uint32_t waitingMS)
Definition: MyMessage.h:291
