hal
transport
PJON
driver
interfaces
ARDUINO
TCPHelper_ARDUINO.h
#pragma once
#ifdef PJON_ESP
#if defined(ESP32)
#include <WiFi.h>
#else
#include <ESP8266WiFi.h>
typedef
WiFiServer
TCPHelperServer
typedef
WiFiClient
TCPHelperClient
#define min(a,b) (a<b?a:b)
#define PJON_GET_MAC WiFi.macAddress
#else
#ifdef PJON_ETHERNET2
#include <Ethernet2.h>
#else
#include <Ethernet.h>
// #include <utility/socket.h> // May be required if using outdated IDE
typedef
EthernetServer
TCPHelperServer
typedef
EthernetClient
TCPHelperClient
#define PJON_GET_MAC EthernetClass::MACAddress
// The following classes make it posssible to use the same non-blocking connect logic
// on Arduino as on POSIX. It works, allowing better communication with POSIX devices,
// but requires that the official EthernetClient and EthernetServer classes are changed
// so that private members are made protected, making it possible to add
// functionality to them.
class TCPHelperClient : public EthernetClient {
public:
bool prepare_connect(IPAddress ip, uint16_t port) {
if (_sock != MAX_SOCK_NUM)
stop();
return false;
for (int i = 0; i < MAX_SOCK_NUM; i++) {
uint8_t s = socketStatus(i);
if (s == SnSR::CLOSED || s == SnSR::FIN_WAIT || s == SnSR::CLOSE_WAIT) {
_sock = i;
break;
if (_sock == MAX_SOCK_NUM)
return false;
_srcport++;
if (_srcport == 0) _srcport = 49152; //Use IANA recommended ephemeral port range 49152-65535
socket(_sock, SnMR::TCP, _srcport, 0);
if (!::connect(_sock, rawIPAddress(ip), port)) {
_sock = MAX_SOCK_NUM;
return false;
return true;
int try_connect() {
if (status() == SnSR::ESTABLISHED) return 1;
if (status() == SnSR::CLOSED) {
return -1;
return 0;
TCPHelperClient() : EthernetClient() { }
TCPHelperClient(uint16_t sock) : EthernetClient(sock) { }
TCPHelperClient(EthernetClient client) : EthernetClient(client ){ }
class TCPHelperServer : public EthernetServer {
public:
TCPHelperServer(uint16_t sock) : EthernetServer(sock) { }
TCPHelperClient available() {
EthernetClient client = EthernetServer::available();
return TCPHelperClient(client);
EthernetClient
Definition:
EthernetClient.h:43
TCPHelperClient
Definition:
TCPHelper_POSIX.h:31
EthernetServer
EthernetServer class.
Definition:
EthernetServer.h:42
TCPHelperServer
Definition:
TCPHelper_POSIX.h:350
