Low level register access
These functions provide low level register access, and should not generally need to be used.
uint32_t * bcm2835_regbase (uint8_t regbase)
uint32_t bcm2835_peri_read (volatile uint32_t *paddr)
uint32_t bcm2835_peri_read_nb (volatile uint32_t *paddr)
void bcm2835_peri_write (volatile uint32_t *paddr, uint32_t value)
void bcm2835_peri_write_nb (volatile uint32_t *paddr, uint32_t value)
void bcm2835_peri_set_bits (volatile uint32_t *paddr, uint32_t value, uint32_t mask)
◆ bcm2835_peri_read()
uint32_t bcm2835_peri_read ( volatile uint32_t *  paddr)
Reads 32 bit value from a peripheral address WITH a memory barrier before and after each read. This is safe, but slow. The MB before protects this read from any in-flight reads that didn't use a MB. The MB after protects subsequent reads from another peripheral.
[in]paddrPhysical address to read from. See BCM2835_GPIO_BASE etc.
Returns
the value read from the 32 bit register
See also
Physical Addresses
◆ bcm2835_peri_read_nb()
uint32_t bcm2835_peri_read_nb ( volatile uint32_t *  paddr)
Reads 32 bit value from a peripheral address WITHOUT the read barriers You should only use this when: o your code has previously called bcm2835_peri_read() for a register within the same peripheral, and no read or write to another peripheral has occurred since. o your code has called bcm2835_memory_barrier() since the last access to ANOTHER peripheral.
Returns
See also
Physical Addresses
◆ bcm2835_peri_set_bits()
void bcm2835_peri_set_bits ( volatile uint32_t *  paddr,
uint32_t  value,
uint32_t  mask
Alters a number of bits in a 32 peripheral regsiter. It reads the current valu and then alters the bits defines as 1 in mask, according to the bit value in value. All other bits that are 0 in the mask are unaffected. Use this to alter a subset of the bits in a register. Memory barriers are used. Note that this is not atomic; an interrupt routine can cause unexpected results.
[in]valueThe 32 bit value to write, masked in by mask.
[in]maskBitmask that defines the bits that will be altered in the register.
See also
Physical Addresses
◆ bcm2835_peri_write()
void bcm2835_peri_write ( volatile uint32_t *  paddr,
uint32_t  value
Writes 32 bit value from a peripheral address WITH a memory barrier before and after each write This is safe, but slow. The MB before ensures that any in-flight write to another peripheral completes before this write is issued. The MB after ensures that subsequent reads and writes to another peripheral will see the effect of this write.
This is a tricky optimization; if you aren't sure, use the barrier version.
See also
Physical Addresses
◆ bcm2835_peri_write_nb()
void bcm2835_peri_write_nb ( volatile uint32_t *  paddr,
uint32_t  value
Writes 32 bit value from a peripheral address without the write barrier You should only use this when: o your code has previously called bcm2835_peri_write() for a register within the same peripheral, and no other peripheral access has occurred since. o your code has called bcm2835_memory_barrier() since the last access to ANOTHER peripheral.
See also
Physical Addresses
◆ bcm2835_regbase()
uint32_t* bcm2835_regbase ( uint8_t  regbase)
Gets the base of a register
[in]regbaseYou can use one of the common values BCM2835_REGBASE_* in bcm2835RegisterBase
Returns
the register base
See also
Physical Addresses
