Macros | Enumerations | Variables
Constants for passing to and from library functions
The values here are designed to be passed to various functions in the bcm2835 library.
#define HIGH   0x1
#define LOW   0x0
#define MIN(a, b)   (a < b ? a : b)
#define BCM2835_CORE_CLK_HZ   250000000
#define BMC2835_RPI2_DT_FILENAME   "/proc/device-tree/soc/ranges"
#define BCM2835_PERI_BASE   0x20000000
#define BCM2835_PERI_SIZE   0x01000000
#define BCM2835_RPI2_PERI_BASE   0x3F000000
#define BCM2835_RPI4_PERI_BASE   0xFE000000
#define BCM2835_RPI4_PERI_SIZE   0x01800000
#define BCM2835_ST_BASE   0x3000
#define BCM2835_GPIO_PADS   0x100000
#define BCM2835_CLOCK_BASE   0x101000
#define BCM2835_GPIO_BASE   0x200000
#define BCM2835_SPI0_BASE   0x204000
#define BCM2835_BSC0_BASE   0x205000
#define BCM2835_GPIO_PWM   0x20C000
#define BCM2835_AUX_BASE   0x215000
#define BCM2835_SPI1_BASE   0x215080
#define BCM2835_SPI2_BASE   0x2150C0
#define BCM2835_BSC1_BASE   0x804000
#define BCM2835_PAGE_SIZE   (4*1024)
#define BCM2835_BLOCK_SIZE   (4*1024)
#define BCM2835_GPFSEL0   0x0000
#define BCM2835_GPFSEL1   0x0004
#define BCM2835_GPFSEL2   0x0008
#define BCM2835_GPFSEL3   0x000c
#define BCM2835_GPFSEL4   0x0010
#define BCM2835_GPFSEL5   0x0014
#define BCM2835_GPSET0   0x001c
#define BCM2835_GPSET1   0x0020
#define BCM2835_GPCLR0   0x0028
#define BCM2835_GPCLR1   0x002c
#define BCM2835_GPLEV0   0x0034
#define BCM2835_GPLEV1   0x0038
#define BCM2835_GPEDS0   0x0040
#define BCM2835_GPEDS1   0x0044
#define BCM2835_GPREN0   0x004c
#define BCM2835_GPREN1   0x0050
#define BCM2835_GPFEN0   0x0058
#define BCM2835_GPFEN1   0x005c
#define BCM2835_GPHEN0   0x0064
#define BCM2835_GPHEN1   0x0068
#define BCM2835_GPLEN0   0x0070
#define BCM2835_GPLEN1   0x0074
#define BCM2835_GPAREN0   0x007c
#define BCM2835_GPAREN1   0x0080
#define BCM2835_GPAFEN0   0x0088
#define BCM2835_GPAFEN1   0x008c
#define BCM2835_GPPUD   0x0094
#define BCM2835_GPPUDCLK0   0x0098
#define BCM2835_GPPUDCLK1   0x009c
#define BCM2835_GPPUPPDN0   0x00e4 /* Pin pull-up/down for pins 15:0 */
#define BCM2835_GPPUPPDN1   0x00e8 /* Pin pull-up/down for pins 31:16 */
#define BCM2835_GPPUPPDN2   0x00ec /* Pin pull-up/down for pins 47:32 */
#define BCM2835_GPPUPPDN3   0x00f0 /* Pin pull-up/down for pins 57:48 */
#define BCM2835_GPIO_PUD_ERROR   0x08
#define BCM2835_PADS_GPIO_0_27   0x002c
#define BCM2835_PADS_GPIO_28_45   0x0030
#define BCM2835_PADS_GPIO_46_53   0x0034
#define BCM2835_PAD_PASSWRD   (0x5A << 24)
#define BCM2835_PAD_SLEW_RATE_UNLIMITED   0x10
#define BCM2835_PAD_HYSTERESIS_ENABLED   0x08
#define BCM2835_PAD_DRIVE_2mA   0x00
#define BCM2835_PAD_DRIVE_4mA   0x01
#define BCM2835_PAD_DRIVE_6mA   0x02
#define BCM2835_PAD_DRIVE_8mA   0x03
#define BCM2835_PAD_DRIVE_10mA   0x04
#define BCM2835_PAD_DRIVE_12mA   0x05
#define BCM2835_PAD_DRIVE_14mA   0x06
#define BCM2835_PAD_DRIVE_16mA   0x07
#define BCM2835_AUX_IRQ   0x0000
#define BCM2835_AUX_ENABLE   0x0004
#define BCM2835_AUX_ENABLE_UART1   0x01
#define BCM2835_AUX_ENABLE_SPI0   0x02
#define BCM2835_AUX_ENABLE_SPI1   0x04
#define BCM2835_AUX_SPI_CNTL0   0x0000
#define BCM2835_AUX_SPI_CNTL1   0x0004
#define BCM2835_AUX_SPI_STAT   0x0008
#define BCM2835_AUX_SPI_PEEK   0x000C
#define BCM2835_AUX_SPI_IO   0x0020
#define BCM2835_AUX_SPI_TXHOLD   0x0030
#define BCM2835_AUX_SPI_CLOCK_MIN   30500
#define BCM2835_AUX_SPI_CLOCK_MAX   125000000
#define BCM2835_AUX_SPI_CNTL0_SPEED   0xFFF00000
#define BCM2835_AUX_SPI_CNTL0_SPEED_MAX   0xFFF
#define BCM2835_AUX_SPI_CNTL0_SPEED_SHIFT   20
#define BCM2835_AUX_SPI_CNTL0_CS0_N   0x000C0000
#define BCM2835_AUX_SPI_CNTL0_CS1_N   0x000A0000
#define BCM2835_AUX_SPI_CNTL0_CS2_N   0x00060000
#define BCM2835_AUX_SPI_CNTL0_POSTINPUT   0x00010000
#define BCM2835_AUX_SPI_CNTL0_VAR_CS   0x00008000
#define BCM2835_AUX_SPI_CNTL0_VAR_WIDTH   0x00004000
#define BCM2835_AUX_SPI_CNTL0_DOUTHOLD   0x00003000
#define BCM2835_AUX_SPI_CNTL0_ENABLE   0x00000800
#define BCM2835_AUX_SPI_CNTL0_CPHA_IN   0x00000400
#define BCM2835_AUX_SPI_CNTL0_CLEARFIFO   0x00000200
#define BCM2835_AUX_SPI_CNTL0_CPHA_OUT   0x00000100
#define BCM2835_AUX_SPI_CNTL0_CPOL   0x00000080
#define BCM2835_AUX_SPI_CNTL0_MSBF_OUT   0x00000040
#define BCM2835_AUX_SPI_CNTL0_SHIFTLEN   0x0000003F
#define BCM2835_AUX_SPI_CNTL1_CSHIGH   0x00000700
#define BCM2835_AUX_SPI_CNTL1_IDLE   0x00000080
#define BCM2835_AUX_SPI_CNTL1_TXEMPTY   0x00000040
#define BCM2835_AUX_SPI_CNTL1_MSBF_IN   0x00000002
#define BCM2835_AUX_SPI_CNTL1_KEEP_IN   0x00000001
#define BCM2835_AUX_SPI_STAT_TX_LVL   0xFF000000
#define BCM2835_AUX_SPI_STAT_RX_LVL   0x00FF0000
#define BCM2835_AUX_SPI_STAT_TX_FULL   0x00000400
#define BCM2835_AUX_SPI_STAT_TX_EMPTY   0x00000200
#define BCM2835_AUX_SPI_STAT_RX_FULL   0x00000100
#define BCM2835_AUX_SPI_STAT_RX_EMPTY   0x00000080
#define BCM2835_AUX_SPI_STAT_BUSY   0x00000040
#define BCM2835_AUX_SPI_STAT_BITCOUNT   0x0000003F
#define BCM2835_SPI0_CS   0x0000
#define BCM2835_SPI0_FIFO   0x0004
#define BCM2835_SPI0_CLK   0x0008
#define BCM2835_SPI0_DLEN   0x000c
#define BCM2835_SPI0_LTOH   0x0010
#define BCM2835_SPI0_DC   0x0014
#define BCM2835_SPI0_CS_LEN_LONG   0x02000000
#define BCM2835_SPI0_CS_DMA_LEN   0x01000000
#define BCM2835_SPI0_CS_CSPOL2   0x00800000
#define BCM2835_SPI0_CS_CSPOL1   0x00400000
#define BCM2835_SPI0_CS_CSPOL0   0x00200000
#define BCM2835_SPI0_CS_RXF   0x00100000
#define BCM2835_SPI0_CS_RXR   0x00080000
#define BCM2835_SPI0_CS_TXD   0x00040000
#define BCM2835_SPI0_CS_RXD   0x00020000
#define BCM2835_SPI0_CS_DONE   0x00010000
#define BCM2835_SPI0_CS_TE_EN   0x00008000
#define BCM2835_SPI0_CS_LMONO   0x00004000
#define BCM2835_SPI0_CS_LEN   0x00002000
#define BCM2835_SPI0_CS_REN   0x00001000
#define BCM2835_SPI0_CS_ADCS   0x00000800
#define BCM2835_SPI0_CS_INTR   0x00000400
#define BCM2835_SPI0_CS_INTD   0x00000200
#define BCM2835_SPI0_CS_DMAEN   0x00000100
#define BCM2835_SPI0_CS_TA   0x00000080
#define BCM2835_SPI0_CS_CSPOL   0x00000040
#define BCM2835_SPI0_CS_CLEAR   0x00000030
#define BCM2835_SPI0_CS_CLEAR_RX   0x00000020
#define BCM2835_SPI0_CS_CLEAR_TX   0x00000010
#define BCM2835_SPI0_CS_CPOL   0x00000008
#define BCM2835_SPI0_CS_CPHA   0x00000004
#define BCM2835_SPI0_CS_CS   0x00000003
#define BCM2835_BSC_C   0x0000
#define BCM2835_BSC_S   0x0004
#define BCM2835_BSC_DLEN   0x0008
#define BCM2835_BSC_A   0x000c
#define BCM2835_BSC_FIFO   0x0010
#define BCM2835_BSC_DIV   0x0014
#define BCM2835_BSC_DEL   0x0018
#define BCM2835_BSC_CLKT   0x001c
#define BCM2835_BSC_C_I2CEN   0x00008000
#define BCM2835_BSC_C_INTR   0x00000400
#define BCM2835_BSC_C_INTT   0x00000200
#define BCM2835_BSC_C_INTD   0x00000100
#define BCM2835_BSC_C_ST   0x00000080
#define BCM2835_BSC_C_CLEAR_1   0x00000020
#define BCM2835_BSC_C_CLEAR_2   0x00000010
#define BCM2835_BSC_C_READ   0x00000001
#define BCM2835_BSC_S_CLKT   0x00000200
#define BCM2835_BSC_S_ERR   0x00000100
#define BCM2835_BSC_S_RXF   0x00000080
#define BCM2835_BSC_S_TXE   0x00000040
#define BCM2835_BSC_S_RXD   0x00000020
#define BCM2835_BSC_S_TXD   0x00000010
#define BCM2835_BSC_S_RXR   0x00000008
#define BCM2835_BSC_S_TXW   0x00000004
#define BCM2835_BSC_S_DONE   0x00000002
#define BCM2835_BSC_S_TA   0x00000001
#define BCM2835_BSC_FIFO_SIZE   16
#define BCM2835_ST_CS   0x0000
#define BCM2835_ST_CLO   0x0004
#define BCM2835_ST_CHI   0x0008
Enumerations
enum  bcm2835RegisterBase {
  BCM2835_REGBASE_ST = 1, BCM2835_REGBASE_GPIO = 2, BCM2835_REGBASE_PWM = 3, BCM2835_REGBASE_CLK = 4,
  BCM2835_REGBASE_PADS = 5, BCM2835_REGBASE_SPI0 = 6, BCM2835_REGBASE_BSC0 = 7, BCM2835_REGBASE_BSC1 = 8,
  BCM2835_REGBASE_AUX = 9, BCM2835_REGBASE_SPI1 = 10
 bcm2835RegisterBase Register bases for bcm2835_regbase() More...
enum  bcm2835FunctionSelect {
  BCM2835_GPIO_FSEL_INPT = 0x00, BCM2835_GPIO_FSEL_OUTP = 0x01, BCM2835_GPIO_FSEL_ALT0 = 0x04, BCM2835_GPIO_FSEL_ALT1 = 0x05,
  BCM2835_GPIO_FSEL_ALT2 = 0x06, BCM2835_GPIO_FSEL_ALT3 = 0x07, BCM2835_GPIO_FSEL_ALT4 = 0x03, BCM2835_GPIO_FSEL_ALT5 = 0x02,
  BCM2835_GPIO_FSEL_MASK = 0x07
 bcm2835PortFunction Port function select modes for bcm2835_gpio_fsel() More...
enum  bcm2835PUDControl { BCM2835_GPIO_PUD_OFF = 0x00, BCM2835_GPIO_PUD_DOWN = 0x01, BCM2835_GPIO_PUD_UP = 0x02 }
 bcm2835PUDControl Pullup/Pulldown defines for bcm2835_gpio_pud() More...
enum  bcm2835PadGroup { BCM2835_PAD_GROUP_GPIO_0_27 = 0, BCM2835_PAD_GROUP_GPIO_28_45 = 1, BCM2835_PAD_GROUP_GPIO_46_53 = 2 }
 bcm2835PadGroup Pad group specification for bcm2835_gpio_pad() More...
enum  RPiGPIOPin {
  RPI_GPIO_P1_03 = 0, RPI_GPIO_P1_05 = 1, RPI_GPIO_P1_07 = 4, RPI_GPIO_P1_08 = 14,
  RPI_GPIO_P1_10 = 15, RPI_GPIO_P1_11 = 17, RPI_GPIO_P1_12 = 18, RPI_GPIO_P1_13 = 21,
  RPI_GPIO_P1_15 = 22, RPI_GPIO_P1_16 = 23, RPI_GPIO_P1_18 = 24, RPI_GPIO_P1_19 = 10,
  RPI_GPIO_P1_21 = 9, RPI_GPIO_P1_22 = 25, RPI_GPIO_P1_23 = 11, RPI_GPIO_P1_24 = 8,
  RPI_GPIO_P1_26 = 7, RPI_V2_GPIO_P1_03 = 2, RPI_V2_GPIO_P1_05 = 3, RPI_V2_GPIO_P1_07 = 4,
  RPI_V2_GPIO_P1_08 = 14, RPI_V2_GPIO_P1_10 = 15, RPI_V2_GPIO_P1_11 = 17, RPI_V2_GPIO_P1_12 = 18,
  RPI_V2_GPIO_P1_13 = 27, RPI_V2_GPIO_P1_15 = 22, RPI_V2_GPIO_P1_16 = 23, RPI_V2_GPIO_P1_18 = 24,
  RPI_V2_GPIO_P1_19 = 10, RPI_V2_GPIO_P1_21 = 9, RPI_V2_GPIO_P1_22 = 25, RPI_V2_GPIO_P1_23 = 11,
  RPI_V2_GPIO_P1_24 = 8, RPI_V2_GPIO_P1_26 = 7, RPI_V2_GPIO_P1_29 = 5, RPI_V2_GPIO_P1_31 = 6,
  RPI_V2_GPIO_P1_32 = 12, RPI_V2_GPIO_P1_33 = 13, RPI_V2_GPIO_P1_35 = 19, RPI_V2_GPIO_P1_36 = 16,
  RPI_V2_GPIO_P1_37 = 26, RPI_V2_GPIO_P1_38 = 20, RPI_V2_GPIO_P1_40 = 21, RPI_V2_GPIO_P5_03 = 28,
  RPI_V2_GPIO_P5_04 = 29, RPI_V2_GPIO_P5_05 = 30, RPI_V2_GPIO_P5_06 = 31, RPI_BPLUS_GPIO_J8_03 = 2,
  RPI_BPLUS_GPIO_J8_05 = 3, RPI_BPLUS_GPIO_J8_07 = 4, RPI_BPLUS_GPIO_J8_08 = 14, RPI_BPLUS_GPIO_J8_10 = 15,
  RPI_BPLUS_GPIO_J8_11 = 17, RPI_BPLUS_GPIO_J8_12 = 18, RPI_BPLUS_GPIO_J8_13 = 27, RPI_BPLUS_GPIO_J8_15 = 22,
  RPI_BPLUS_GPIO_J8_16 = 23, RPI_BPLUS_GPIO_J8_18 = 24, RPI_BPLUS_GPIO_J8_19 = 10, RPI_BPLUS_GPIO_J8_21 = 9,
  RPI_BPLUS_GPIO_J8_22 = 25, RPI_BPLUS_GPIO_J8_23 = 11, RPI_BPLUS_GPIO_J8_24 = 8, RPI_BPLUS_GPIO_J8_26 = 7,
  RPI_BPLUS_GPIO_J8_29 = 5, RPI_BPLUS_GPIO_J8_31 = 6, RPI_BPLUS_GPIO_J8_32 = 12, RPI_BPLUS_GPIO_J8_33 = 13,
  RPI_BPLUS_GPIO_J8_35 = 19, RPI_BPLUS_GPIO_J8_36 = 16, RPI_BPLUS_GPIO_J8_37 = 26, RPI_BPLUS_GPIO_J8_38 = 20,
  RPI_BPLUS_GPIO_J8_40 = 21
 GPIO Pin Numbers. More...
enum  bcm2835SPIBitOrder { BCM2835_SPI_BIT_ORDER_LSBFIRST = 0, BCM2835_SPI_BIT_ORDER_MSBFIRST = 1 }
 bcm2835SPIBitOrder SPI Bit order Specifies the SPI data bit ordering for bcm2835_spi_setBitOrder() More...
enum  bcm2835SPIMode { BCM2835_SPI_MODE0 = 0, BCM2835_SPI_MODE1 = 1, BCM2835_SPI_MODE2 = 2, BCM2835_SPI_MODE3 = 3 }
 SPI Data mode Specify the SPI data mode to be passed to bcm2835_spi_setDataMode() More...
enum  bcm2835SPIChipSelect { BCM2835_SPI_CS0 = 0, BCM2835_SPI_CS1 = 1, BCM2835_SPI_CS2 = 2, BCM2835_SPI_CS_NONE = 3 }
 bcm2835SPIChipSelect Specify the SPI chip select pin(s) More...
enum  bcm2835SPIClockDivider {
  BCM2835_SPI_CLOCK_DIVIDER_65536 = 0, BCM2835_SPI_CLOCK_DIVIDER_32768 = 32768, BCM2835_SPI_CLOCK_DIVIDER_16384 = 16384, BCM2835_SPI_CLOCK_DIVIDER_8192 = 8192,
  BCM2835_SPI_CLOCK_DIVIDER_4096 = 4096, BCM2835_SPI_CLOCK_DIVIDER_2048 = 2048, BCM2835_SPI_CLOCK_DIVIDER_1024 = 1024, BCM2835_SPI_CLOCK_DIVIDER_512 = 512,
  BCM2835_SPI_CLOCK_DIVIDER_256 = 256, BCM2835_SPI_CLOCK_DIVIDER_128 = 128, BCM2835_SPI_CLOCK_DIVIDER_64 = 64, BCM2835_SPI_CLOCK_DIVIDER_32 = 32,
  BCM2835_SPI_CLOCK_DIVIDER_16 = 16, BCM2835_SPI_CLOCK_DIVIDER_8 = 8, BCM2835_SPI_CLOCK_DIVIDER_4 = 4, BCM2835_SPI_CLOCK_DIVIDER_2 = 2,
  BCM2835_SPI_CLOCK_DIVIDER_1 = 1
 bcm2835SPIClockDivider Specifies the divider used to generate the SPI clock from the system clock. Figures below give the divider, clock period and clock frequency. Clock divided is based on nominal core clock rate of 250MHz on RPi1 and RPi2, and 400MHz on RPi3. It is reported that (contrary to the documentation) any even divider may used. The frequencies shown for each divider have been confirmed by measurement on RPi1 and RPi2. The system clock frequency on RPi3 is different, so the frequency you get from a given divider will be different. See comments in 'SPI Pins' for information about reliable SPI speeds. Note: it is possible to change the core clock rate of the RPi 3 back to 250MHz, by putting More...
enum  bcm2835I2CClockDivider { BCM2835_I2C_CLOCK_DIVIDER_2500 = 2500, BCM2835_I2C_CLOCK_DIVIDER_626 = 626, BCM2835_I2C_CLOCK_DIVIDER_150 = 150, BCM2835_I2C_CLOCK_DIVIDER_148 = 148 }
 bcm2835I2CClockDivider Specifies the divider used to generate the I2C clock from the system clock. Clock divided is based on nominal base clock rate of 250MHz More...
enum  bcm2835I2CReasonCodes { BCM2835_I2C_REASON_OK = 0x00, BCM2835_I2C_REASON_ERROR_NACK = 0x01, BCM2835_I2C_REASON_ERROR_CLKT = 0x02, BCM2835_I2C_REASON_ERROR_DATA = 0x04 }
 bcm2835I2CReasonCodes Specifies the reason codes for the bcm2835_i2c_write and bcm2835_i2c_read functions. More...
Variables
uint32_t * bcm2835_peripherals_base
uint32_t bcm2835_peripherals_size
volatile uint32_t * bcm2835_st
volatile uint32_t * bcm2835_gpio
volatile uint32_t * bcm2835_pwm
volatile uint32_t * bcm2835_clk
volatile uint32_t * bcm2835_pads
volatile uint32_t * bcm2835_spi0
volatile uint32_t * bcm2835_bsc0
volatile uint32_t * bcm2835_bsc1
volatile uint32_t * bcm2835_aux
volatile uint32_t * bcm2835_spi1
◆ BCM2835_AUX_BASE
Base Address of the AUX registers
Definition at line 621 of file bcm2835.h.
◆ BCM2835_AUX_ENABLE_SPI0
SPI0 (SPI1 in the device)
Definition at line 913 of file bcm2835.h.
◆ BCM2835_AUX_ENABLE_SPI1
SPI1 (SPI2 in the device)
Definition at line 914 of file bcm2835.h.
◆ BCM2835_AUX_IRQ
xxx
Definition at line 909 of file bcm2835.h.
◆ BCM2835_AUX_SPI_CLOCK_MAX
125Mhz
Definition at line 925 of file bcm2835.h.
◆ BCM2835_AUX_SPI_CLOCK_MIN
30,5kHz
Definition at line 924 of file bcm2835.h.
◆ BCM2835_AUX_SPI_CNTL0_CS0_N
CS 0 low
Definition at line 931 of file bcm2835.h.
◆ BCM2835_AUX_SPI_CNTL0_CS1_N
CS 1 low
Definition at line 932 of file bcm2835.h.
◆ BCM2835_AUX_SPI_CNTL0_CS2_N
CS 2 low
Definition at line 933 of file bcm2835.h.
◆ BCM2835_AUX_SPI_IO
Write = TX, read=RX
Definition at line 921 of file bcm2835.h.
◆ BCM2835_AUX_SPI_PEEK
Read but do not take from FF
Definition at line 920 of file bcm2835.h.
◆ BCM2835_AUX_SPI_TXHOLD
Write = TX keep CS, read=RX
Definition at line 922 of file bcm2835.h.
◆ BCM2835_BLOCK_SIZE
Size of memory block on RPi
Definition at line 710 of file bcm2835.h.
◆ BCM2835_BSC0_BASE
Base Address of the BSC0 registers
Definition at line 617 of file bcm2835.h.
◆ BCM2835_BSC1_BASE
Base Address of the BSC1 registers
Definition at line 627 of file bcm2835.h.
◆ BCM2835_BSC_A
BSC Master Slave Address
Definition at line 1070 of file bcm2835.h.
◆ BCM2835_BSC_C
BSC Master Control
Definition at line 1067 of file bcm2835.h.
◆ BCM2835_BSC_C_CLEAR_1
Clear FIFO Clear
Definition at line 1082 of file bcm2835.h.
◆ BCM2835_BSC_C_CLEAR_2
Clear FIFO Clear
Definition at line 1083 of file bcm2835.h.
◆ BCM2835_BSC_C_I2CEN
I2C Enable, 0 = disabled, 1 = enabled
Definition at line 1077 of file bcm2835.h.
◆ BCM2835_BSC_C_INTD
Interrupt on DONE
Definition at line 1080 of file bcm2835.h.
◆ BCM2835_BSC_C_INTR
Interrupt on RX
Definition at line 1078 of file bcm2835.h.
◆ BCM2835_BSC_C_INTT
Interrupt on TX
Definition at line 1079 of file bcm2835.h.
◆ BCM2835_BSC_C_READ
Read transfer
Definition at line 1084 of file bcm2835.h.
◆ BCM2835_BSC_C_ST
Start transfer, 1 = Start a new transfer
Definition at line 1081 of file bcm2835.h.
◆ BCM2835_BSC_CLKT
BSC Master Clock Stretch Timeout
Definition at line 1074 of file bcm2835.h.
◆ BCM2835_BSC_DEL
BSC Master Data Delay
Definition at line 1073 of file bcm2835.h.
◆ BCM2835_BSC_DIV
BSC Master Clock Divider
Definition at line 1072 of file bcm2835.h.
◆ BCM2835_BSC_DLEN
BSC Master Data Length
Definition at line 1069 of file bcm2835.h.
◆ BCM2835_BSC_FIFO
BSC Master Data FIFO
Definition at line 1071 of file bcm2835.h.
◆ BCM2835_BSC_FIFO_SIZE
BSC FIFO size
Definition at line 1098 of file bcm2835.h.
◆ BCM2835_BSC_S
BSC Master Status
Definition at line 1068 of file bcm2835.h.
◆ BCM2835_BSC_S_CLKT
Clock stretch timeout
Definition at line 1087 of file bcm2835.h.
◆ BCM2835_BSC_S_DONE
Transfer DONE
Definition at line 1095 of file bcm2835.h.
◆ BCM2835_BSC_S_ERR
ACK error
Definition at line 1088 of file bcm2835.h.
◆ BCM2835_BSC_S_RXD
RXD FIFO contains data
Definition at line 1091 of file bcm2835.h.
◆ BCM2835_BSC_S_RXF
RXF FIFO full, 0 = FIFO is not full, 1 = FIFO is full
Definition at line 1089 of file bcm2835.h.
◆ BCM2835_BSC_S_RXR
RXR FIFO needs reading (full)
Definition at line 1093 of file bcm2835.h.
◆ BCM2835_BSC_S_TA
Transfer Active
Definition at line 1096 of file bcm2835.h.
◆ BCM2835_BSC_S_TXD
TXD FIFO can accept data
Definition at line 1092 of file bcm2835.h.
◆ BCM2835_BSC_S_TXE
TXE FIFO full, 0 = FIFO is not full, 1 = FIFO is full
Definition at line 1090 of file bcm2835.h.
◆ BCM2835_BSC_S_TXW
TXW FIFO needs writing (full)
Definition at line 1094 of file bcm2835.h.
◆ BCM2835_CLOCK_BASE
Base Address of the Clock/timer registers
Definition at line 611 of file bcm2835.h.
◆ BCM2835_CORE_CLK_HZ
Speed of the core clock core_clk 250 MHz
Definition at line 582 of file bcm2835.h.
◆ BCM2835_GPAFEN0
GPIO Pin Async. Falling Edge Detect 0
Definition at line 744 of file bcm2835.h.
◆ BCM2835_GPAFEN1
GPIO Pin Async. Falling Edge Detect 1
Definition at line 745 of file bcm2835.h.
◆ BCM2835_GPAREN0
GPIO Pin Async. Rising Edge Detect 0
Definition at line 742 of file bcm2835.h.
◆ BCM2835_GPAREN1
GPIO Pin Async. Rising Edge Detect 1
Definition at line 743 of file bcm2835.h.
◆ BCM2835_GPCLR0
GPIO Pin Output Clear 0
Definition at line 728 of file bcm2835.h.
◆ BCM2835_GPCLR1
GPIO Pin Output Clear 1
Definition at line 729 of file bcm2835.h.
◆ BCM2835_GPEDS0
GPIO Pin Event Detect Status 0
Definition at line 732 of file bcm2835.h.
◆ BCM2835_GPEDS1
GPIO Pin Event Detect Status 1
Definition at line 733 of file bcm2835.h.
◆ BCM2835_GPFEN0
GPIO Pin Falling Edge Detect Enable 0
Definition at line 736 of file bcm2835.h.
◆ BCM2835_GPFEN1
GPIO Pin Falling Edge Detect Enable 1
Definition at line 737 of file bcm2835.h.
◆ BCM2835_GPFSEL0
GPIO register offsets from BCM2835_GPIO_BASE. Offsets into the GPIO Peripheral block in bytes per 6.1 Register View GPIO Function Select 0
Definition at line 720 of file bcm2835.h.
◆ BCM2835_GPFSEL1
GPIO Function Select 1
Definition at line 721 of file bcm2835.h.
◆ BCM2835_GPFSEL2
GPIO Function Select 2
Definition at line 722 of file bcm2835.h.
◆ BCM2835_GPFSEL3
GPIO Function Select 3
Definition at line 723 of file bcm2835.h.
◆ BCM2835_GPFSEL4
GPIO Function Select 4
Definition at line 724 of file bcm2835.h.
◆ BCM2835_GPFSEL5
GPIO Function Select 5
Definition at line 725 of file bcm2835.h.
◆ BCM2835_GPHEN0
GPIO Pin High Detect Enable 0
Definition at line 738 of file bcm2835.h.
◆ BCM2835_GPHEN1
GPIO Pin High Detect Enable 1
Definition at line 739 of file bcm2835.h.
◆ BCM2835_GPIO_BASE
Base Address of the GPIO registers
Definition at line 613 of file bcm2835.h.
◆ BCM2835_GPIO_PADS
Base Address of the Pads registers
Definition at line 609 of file bcm2835.h.
◆ BCM2835_GPIO_PWM
Base Address of the PWM registers
Definition at line 619 of file bcm2835.h.
◆ BCM2835_GPLEN0
GPIO Pin Low Detect Enable 0
Definition at line 740 of file bcm2835.h.
◆ BCM2835_GPLEN1
GPIO Pin Low Detect Enable 1
Definition at line 741 of file bcm2835.h.
◆ BCM2835_GPLEV0
GPIO Pin Level 0
Definition at line 730 of file bcm2835.h.
◆ BCM2835_GPLEV1
GPIO Pin Level 1
Definition at line 731 of file bcm2835.h.
◆ BCM2835_GPPUD
GPIO Pin Pull-up/down Enable
Definition at line 746 of file bcm2835.h.
◆ BCM2835_GPPUDCLK0
GPIO Pin Pull-up/down Enable Clock 0
Definition at line 747 of file bcm2835.h.
◆ BCM2835_GPPUDCLK1
GPIO Pin Pull-up/down Enable Clock 1
Definition at line 748 of file bcm2835.h.
◆ BCM2835_GPREN0
GPIO Pin Rising Edge Detect Enable 0
Definition at line 734 of file bcm2835.h.
◆ BCM2835_GPREN1
GPIO Pin Rising Edge Detect Enable 1
Definition at line 735 of file bcm2835.h.
◆ BCM2835_GPSET0
GPIO Pin Output Set 0
Definition at line 726 of file bcm2835.h.
◆ BCM2835_GPSET1
GPIO Pin Output Set 1
Definition at line 727 of file bcm2835.h.
◆ BCM2835_PAD_DRIVE_10mA
10mA drive current
Definition at line 796 of file bcm2835.h.
◆ BCM2835_PAD_DRIVE_12mA
12mA drive current
Definition at line 797 of file bcm2835.h.
◆ BCM2835_PAD_DRIVE_14mA
14mA drive current
Definition at line 798 of file bcm2835.h.
◆ BCM2835_PAD_DRIVE_16mA
16mA drive current
Definition at line 799 of file bcm2835.h.
◆ BCM2835_PAD_DRIVE_2mA
2mA drive current
Definition at line 792 of file bcm2835.h.
◆ BCM2835_PAD_DRIVE_4mA
4mA drive current
Definition at line 793 of file bcm2835.h.
◆ BCM2835_PAD_DRIVE_6mA
6mA drive current
Definition at line 794 of file bcm2835.h.
◆ BCM2835_PAD_DRIVE_8mA
8mA drive current
Definition at line 795 of file bcm2835.h.
◆ BCM2835_PAD_HYSTERESIS_ENABLED
Hysteresis enabled
Definition at line 791 of file bcm2835.h.
◆ BCM2835_PAD_PASSWRD
Pad Control masks Password to enable setting pad mask
Definition at line 789 of file bcm2835.h.
◆ BCM2835_PAD_SLEW_RATE_UNLIMITED
Slew rate unlimited
Definition at line 790 of file bcm2835.h.
◆ BCM2835_PADS_GPIO_0_27
Pad control register offsets from BCM2835_GPIO_PADS Pad control register for pads 0 to 27
Definition at line 784 of file bcm2835.h.
◆ BCM2835_PADS_GPIO_28_45
Pad control register for pads 28 to 45
Definition at line 785 of file bcm2835.h.
◆ BCM2835_PADS_GPIO_46_53
Pad control register for pads 46 to 53
Definition at line 786 of file bcm2835.h.
◆ BCM2835_PAGE_SIZE
Size of memory page on RPi
Definition at line 708 of file bcm2835.h.
◆ BCM2835_PERI_BASE
Physical addresses for various peripheral register sets Base Physical Address of the BCM 2835 peripheral registers Note this is different for the RPi2 BCM2836, where this is derived from /proc/device-tree/soc/ranges If /proc/device-tree/soc/ranges exists on a RPi 1 OS, it would be expected to contain the following numbers:
Peripherals block base address on RPi 1
Definition at line 594 of file bcm2835.h.
◆ BCM2835_PERI_SIZE
Size of the peripherals block on RPi 1
Definition at line 596 of file bcm2835.h.
◆ BCM2835_RPI2_PERI_BASE
Alternate base address for RPI 2 / 3
Definition at line 598 of file bcm2835.h.
◆ BCM2835_RPI4_PERI_BASE
Alternate base address for RPI 4
Definition at line 600 of file bcm2835.h.
◆ BCM2835_RPI4_PERI_SIZE
Alternate size for RPI 4
Definition at line 602 of file bcm2835.h.
◆ BCM2835_SPI0_BASE
Base Address of the SPI0 registers
Definition at line 615 of file bcm2835.h.
◆ BCM2835_SPI0_CLK
SPI Master Clock Divider
Definition at line 968 of file bcm2835.h.
◆ BCM2835_SPI0_CS
SPI Master Control and Status
Definition at line 966 of file bcm2835.h.
◆ BCM2835_SPI0_CS_ADCS
ADCS Automatically Deassert Chip Select
Definition at line 988 of file bcm2835.h.
◆ BCM2835_SPI0_CS_CLEAR
Clear FIFO Clear RX and TX
Definition at line 994 of file bcm2835.h.
◆ BCM2835_SPI0_CS_CLEAR_RX
Clear FIFO Clear RX
Definition at line 995 of file bcm2835.h.
◆ BCM2835_SPI0_CS_CLEAR_TX
Clear FIFO Clear TX
Definition at line 996 of file bcm2835.h.
◆ BCM2835_SPI0_CS_CPHA
Clock Phase
Definition at line 998 of file bcm2835.h.
◆ BCM2835_SPI0_CS_CPOL
Clock Polarity
Definition at line 997 of file bcm2835.h.
◆ BCM2835_SPI0_CS_CS
Chip Select
Definition at line 999 of file bcm2835.h.
◆ BCM2835_SPI0_CS_CSPOL
Chip Select Polarity
Definition at line 993 of file bcm2835.h.
◆ BCM2835_SPI0_CS_CSPOL0
Chip Select 0 Polarity
Definition at line 978 of file bcm2835.h.
◆ BCM2835_SPI0_CS_CSPOL1
Chip Select 1 Polarity
Definition at line 977 of file bcm2835.h.
◆ BCM2835_SPI0_CS_CSPOL2
Chip Select 2 Polarity
Definition at line 976 of file bcm2835.h.
◆ BCM2835_SPI0_CS_DMA_LEN
Enable DMA mode in Lossi mode
Definition at line 975 of file bcm2835.h.
◆ BCM2835_SPI0_CS_DMAEN
DMAEN DMA Enable
Definition at line 991 of file bcm2835.h.
◆ BCM2835_SPI0_CS_DONE
Done transfer Done
Definition at line 983 of file bcm2835.h.
◆ BCM2835_SPI0_CS_INTD
INTD Interrupt on Done
Definition at line 990 of file bcm2835.h.
◆ BCM2835_SPI0_CS_INTR
INTR Interrupt on RXR
Definition at line 989 of file bcm2835.h.
◆ BCM2835_SPI0_CS_LEN
LEN LoSSI enable
Definition at line 986 of file bcm2835.h.
◆ BCM2835_SPI0_CS_LEN_LONG
Enable Long data word in Lossi mode if DMA_LEN is set
Definition at line 974 of file bcm2835.h.
◆ BCM2835_SPI0_CS_LMONO
Unused
Definition at line 985 of file bcm2835.h.
◆ BCM2835_SPI0_CS_REN
REN Read Enable
Definition at line 987 of file bcm2835.h.
◆ BCM2835_SPI0_CS_RXD
RXD RX FIFO contains Data
Definition at line 982 of file bcm2835.h.
◆ BCM2835_SPI0_CS_RXF
RXF - RX FIFO Full
Definition at line 979 of file bcm2835.h.
◆ BCM2835_SPI0_CS_RXR
RXR RX FIFO needs Reading (full)
Definition at line 980 of file bcm2835.h.
◆ BCM2835_SPI0_CS_TA
Transfer Active
Definition at line 992 of file bcm2835.h.
◆ BCM2835_SPI0_CS_TE_EN
Unused
Definition at line 984 of file bcm2835.h.
◆ BCM2835_SPI0_CS_TXD
TXD TX FIFO can accept Data
Definition at line 981 of file bcm2835.h.
◆ BCM2835_SPI0_DC
SPI DMA DREQ Controls
Definition at line 971 of file bcm2835.h.
◆ BCM2835_SPI0_DLEN
SPI Master Data Length
Definition at line 969 of file bcm2835.h.
◆ BCM2835_SPI0_FIFO
SPI Master TX and RX FIFOs
Definition at line 967 of file bcm2835.h.
◆ BCM2835_SPI0_LTOH
SPI LOSSI mode TOH
Definition at line 970 of file bcm2835.h.
◆ BCM2835_SPI1_BASE
Base Address of the AUX_SPI1 registers
Definition at line 623 of file bcm2835.h.
◆ BCM2835_SPI2_BASE
Base Address of the AUX_SPI2 registers
Definition at line 625 of file bcm2835.h.
◆ BCM2835_ST_BASE
Offsets for the bases of various peripherals within the peripherals block / Base Address of the System Timer registers
Definition at line 607 of file bcm2835.h.
◆ BCM2835_ST_CHI
System Timer Counter Upper 32 bits
Definition at line 1134 of file bcm2835.h.
◆ BCM2835_ST_CLO
System Timer Counter Lower 32 bits
Definition at line 1133 of file bcm2835.h.
◆ BCM2835_ST_CS
System Timer Control/Status
Definition at line 1132 of file bcm2835.h.
◆ BMC2835_RPI2_DT_FILENAME
On all recent OSs, the base of the peripherals is read from a /proc file
Definition at line 585 of file bcm2835.h.
◆ HIGH
#define HIGH   0x1
This means pin HIGH, true, 3.3volts on a pin.
Definition at line 572 of file bcm2835.h.
◆ LOW
#define LOW   0x0
This means pin LOW, false, 0volts on a pin.
Definition at line 574 of file bcm2835.h.
◆ MIN
#define MIN (   a,
  b
)    (a < b ? a : b)
Return the minimum of 2 numbers
Definition at line 578 of file bcm2835.h.
Enumeration Type Documentation
◆ bcm2835FunctionSelect
Enumerator
Input 0b000
Output 0b001
Alternate function 0 0b100
Alternate function 1 0b101
Alternate function 2 0b110,
Alternate function 3 0b111
Alternate function 4 0b011
Alternate function 5 0b010
Function select bits mask 0b111
Definition at line 759 of file bcm2835.h.
◆ bcm2835I2CClockDivider
Enumerator
2500 = 10us = 100 kHz
622 = 2.504us = 399.3610 kHz
150 = 60ns = 1.666 MHz (default at reset)
148 = 59ns = 1.689 MHz
Definition at line 1104 of file bcm2835.h.
◆ bcm2835I2CReasonCodes
Enumerator
Success
Received a NACK
Received Clock Stretch Timeout
Not all data is sent / received
Definition at line 1114 of file bcm2835.h.
◆ bcm2835PadGroup
Enumerator
Pad group for GPIO pads 0 to 27
Pad group for GPIO pads 28 to 45
Pad group for GPIO pads 46 to 53
Definition at line 804 of file bcm2835.h.
◆ bcm2835PUDControl
Enumerator
Off ? disable pull-up/down 0b00
Enable Pull Down control 0b01
BCM2835_GPIO_PUD_UP
Enable Pull Up control 0b10
Definition at line 774 of file bcm2835.h.
◆ bcm2835RegisterBase
Enumerator
BCM2835_REGBASE_ST
Base of the ST (System Timer) registers.
Base of the GPIO registers.
BCM2835_REGBASE_PWM
Base of the PWM registers.
BCM2835_REGBASE_CLK
Base of the CLK registers.
Base of the PADS registers.
Base of the SPI0 registers.
Base of the BSC0 registers.
Base of the BSC1 registers.
BCM2835_REGBASE_AUX
Base of the AUX registers.
Base of the SPI1 registers.
Definition at line 694 of file bcm2835.h.
◆ bcm2835SPIBitOrder
Enumerator
LSB First
MSB First
Definition at line 1004 of file bcm2835.h.
◆ bcm2835SPIChipSelect
Enumerator
BCM2835_SPI_CS0
Chip Select 0
BCM2835_SPI_CS1
Chip Select 1
BCM2835_SPI_CS2
Chip Select 2 (ie pins CS1 and CS2 are asserted)
BCM2835_SPI_CS_NONE
No CS, control it yourself
Definition at line 1022 of file bcm2835.h.
◆ bcm2835SPIClockDivider
core_freq=250
in the config.txt
Enumerator
65536 = 3.814697260kHz on Rpi2, 6.1035156kHz on RPI3
32768 = 7.629394531kHz on Rpi2, 12.20703125kHz on RPI3
16384 = 15.25878906kHz on Rpi2, 24.4140625kHz on RPI3
8192 = 30.51757813kHz on Rpi2, 48.828125kHz on RPI3
4096 = 61.03515625kHz on Rpi2, 97.65625kHz on RPI3
2048 = 122.0703125kHz on Rpi2, 195.3125kHz on RPI3
1024 = 244.140625kHz on Rpi2, 390.625kHz on RPI3
512 = 488.28125kHz on Rpi2, 781.25kHz on RPI3
256 = 976.5625kHz on Rpi2, 1.5625MHz on RPI3
128 = 1.953125MHz on Rpi2, 3.125MHz on RPI3
64 = 3.90625MHz on Rpi2, 6.250MHz on RPI3
32 = 7.8125MHz on Rpi2, 12.5MHz on RPI3
16 = 15.625MHz on Rpi2, 25MHz on RPI3
8 = 31.25MHz on Rpi2, 50MHz on RPI3
4 = 62.5MHz on Rpi2, 100MHz on RPI3. Dont expect this speed to work reliably.
2 = 125MHz on Rpi2, 200MHz on RPI3, fastest you can get. Dont expect this speed to work reliably.
1 = 3.814697260kHz on Rpi2, 6.1035156kHz on RPI3, same as 0/65536
Definition at line 1043 of file bcm2835.h.
◆ bcm2835SPIMode
Enumerator
BCM2835_SPI_MODE0
CPOL = 0, CPHA = 0
BCM2835_SPI_MODE1
CPOL = 0, CPHA = 1
BCM2835_SPI_MODE2
CPOL = 1, CPHA = 0
BCM2835_SPI_MODE3
CPOL = 1, CPHA = 1
Definition at line 1012 of file bcm2835.h.
◆ RPiGPIOPin
enum RPiGPIOPin
GPIO Pin Numbers.
Here we define Raspberry Pin GPIO pins on P1 in terms of the underlying BCM GPIO pin numbers. These can be passed as a pin number to any function requiring a pin. Not all pins on the RPi 26 bin IDE plug are connected to GPIO pins and some can adopt an alternate function. RPi version 2 has some slightly different pinouts, and these are values RPI_V2_*. RPi B+ has yet differnet pinouts and these are defined in RPI_BPLUS_*. At bootup, pins 8 and 10 are set to UART0_TXD, UART0_RXD (ie the alt0 function) respectively When SPI0 is in use (ie after bcm2835_spi_begin()), SPI0 pins are dedicated to SPI and cant be controlled independently. If you are using the RPi Compute Module, just use the GPIO number: there is no need to use one of these symbolic names
Enumerator
RPI_GPIO_P1_03
Version 1, Pin P1-03
RPI_GPIO_P1_05
Version 1, Pin P1-05
RPI_GPIO_P1_07
Version 1, Pin P1-07
RPI_GPIO_P1_08
Version 1, Pin P1-08, defaults to alt function 0 UART0_TXD
RPI_GPIO_P1_10
Version 1, Pin P1-10, defaults to alt function 0 UART0_RXD
RPI_GPIO_P1_11
Version 1, Pin P1-11
RPI_GPIO_P1_12
Version 1, Pin P1-12, can be PWM channel 0 in ALT FUN 5
RPI_GPIO_P1_13
Version 1, Pin P1-13
RPI_GPIO_P1_15
Version 1, Pin P1-15
RPI_GPIO_P1_16
Version 1, Pin P1-16
RPI_GPIO_P1_18
Version 1, Pin P1-18
RPI_GPIO_P1_19
Version 1, Pin P1-19, MOSI when SPI0 in use
RPI_GPIO_P1_21
Version 1, Pin P1-21, MISO when SPI0 in use
RPI_GPIO_P1_22
Version 1, Pin P1-22
RPI_GPIO_P1_23
Version 1, Pin P1-23, CLK when SPI0 in use
RPI_GPIO_P1_24
Version 1, Pin P1-24, CE0 when SPI0 in use
RPI_GPIO_P1_26
Version 1, Pin P1-26, CE1 when SPI0 in use
RPI_V2_GPIO_P1_03
Version 2, Pin P1-03
RPI_V2_GPIO_P1_05
Version 2, Pin P1-05
RPI_V2_GPIO_P1_07
Version 2, Pin P1-07
RPI_V2_GPIO_P1_08
Version 2, Pin P1-08, defaults to alt function 0 UART0_TXD
RPI_V2_GPIO_P1_10
Version 2, Pin P1-10, defaults to alt function 0 UART0_RXD
RPI_V2_GPIO_P1_11
Version 2, Pin P1-11
RPI_V2_GPIO_P1_12
Version 2, Pin P1-12, can be PWM channel 0 in ALT FUN 5
RPI_V2_GPIO_P1_13
Version 2, Pin P1-13
RPI_V2_GPIO_P1_15
Version 2, Pin P1-15
RPI_V2_GPIO_P1_16
Version 2, Pin P1-16
RPI_V2_GPIO_P1_18
Version 2, Pin P1-18
RPI_V2_GPIO_P1_19
Version 2, Pin P1-19, MOSI when SPI0 in use
RPI_V2_GPIO_P1_21
Version 2, Pin P1-21, MISO when SPI0 in use
RPI_V2_GPIO_P1_22
Version 2, Pin P1-22
RPI_V2_GPIO_P1_23
Version 2, Pin P1-23, CLK when SPI0 in use
RPI_V2_GPIO_P1_24
Version 2, Pin P1-24, CE0 when SPI0 in use
RPI_V2_GPIO_P1_26
Version 2, Pin P1-26, CE1 when SPI0 in use
RPI_V2_GPIO_P1_29
Version 2, Pin P1-29
RPI_V2_GPIO_P1_31
Version 2, Pin P1-31
RPI_V2_GPIO_P1_32
Version 2, Pin P1-32
RPI_V2_GPIO_P1_33
Version 2, Pin P1-33
RPI_V2_GPIO_P1_35
Version 2, Pin P1-35, can be PWM channel 1 in ALT FUN 5
RPI_V2_GPIO_P1_36
Version 2, Pin P1-36
RPI_V2_GPIO_P1_37
Version 2, Pin P1-37
RPI_V2_GPIO_P1_38
Version 2, Pin P1-38
RPI_V2_GPIO_P1_40
Version 2, Pin P1-40
RPI_V2_GPIO_P5_03
Version 2, Pin P5-03
RPI_V2_GPIO_P5_04
Version 2, Pin P5-04
RPI_V2_GPIO_P5_05
Version 2, Pin P5-05
RPI_V2_GPIO_P5_06
Version 2, Pin P5-06
B+, Pin J8-03
B+, Pin J8-05
B+, Pin J8-07
B+, Pin J8-08, defaults to alt function 0 UART0_TXD
B+, Pin J8-10, defaults to alt function 0 UART0_RXD
B+, Pin J8-11
B+, Pin J8-12, can be PWM channel 0 in ALT FUN 5
B+, Pin J8-13
B+, Pin J8-15
B+, Pin J8-16
B+, Pin J8-18
B+, Pin J8-19, MOSI when SPI0 in use
B+, Pin J8-21, MISO when SPI0 in use
B+, Pin J8-22
B+, Pin J8-23, CLK when SPI0 in use
B+, Pin J8-24, CE0 when SPI0 in use
B+, Pin J8-26, CE1 when SPI0 in use
B+, Pin J8-29,
B+, Pin J8-31,
B+, Pin J8-32,
B+, Pin J8-33,
B+, Pin J8-35, can be PWM channel 1 in ALT FUN 5
B+, Pin J8-36,
B+, Pin J8-37,
B+, Pin J8-38,
B+, Pin J8-40,
Definition at line 824 of file bcm2835.h.
Variable Documentation
◆ bcm2835_aux
volatile uint32_t* bcm2835_aux
Base of the AUX registers. Available after bcm2835_init has been called (as root)
◆ bcm2835_bsc0
volatile uint32_t* bcm2835_bsc0
Base of the BSC0 registers. Available after bcm2835_init has been called (as root)
◆ bcm2835_bsc1
volatile uint32_t* bcm2835_bsc1
Base of the BSC1 registers. Available after bcm2835_init has been called (as root)
◆ bcm2835_clk
volatile uint32_t* bcm2835_clk
Base of the CLK registers. Available after bcm2835_init has been called (as root)
◆ bcm2835_gpio
volatile uint32_t* bcm2835_gpio
Base of the GPIO registers. Available after bcm2835_init has been called
◆ bcm2835_pads
volatile uint32_t* bcm2835_pads
Base of the PADS registers. Available after bcm2835_init has been called (as root)
◆ bcm2835_peripherals
uint32_t* bcm2835_peripherals
Virtual memory address of the mapped peripherals block
◆ bcm2835_peripherals_base
uint32_t* bcm2835_peripherals_base
Physical address and size of the peripherals block May be overridden on RPi2
◆ bcm2835_peripherals_size
Size of the peripherals block to be mapped
◆ bcm2835_pwm
volatile uint32_t* bcm2835_pwm
Base of the PWM registers. Available after bcm2835_init has been called (as root)
◆ bcm2835_spi0
volatile uint32_t* bcm2835_spi0
Base of the SPI0 registers. Available after bcm2835_init has been called (as root)
◆ bcm2835_spi1
volatile uint32_t* bcm2835_spi1
Base of the SPI1 registers. Available after bcm2835_init has been called (as root)
◆ bcm2835_st
volatile uint32_t* bcm2835_st
Base of the ST (System Timer) registers. Available after bcm2835_init has been called (as root)
