GatewaySerial.ino
39 // Enable debug prints to serial monitor
40 #define MY_DEBUG
43 // Enable and select radio type attached
44 #define MY_RADIO_RF24
45 //#define MY_RADIO_NRF5_ESB
46 //#define MY_RADIO_RFM69
47 //#define MY_RADIO_RFM95
49 // Set LOW transmit power level as default, if you have an amplified NRF-module and
50 // power your radio separately with a good regulator you can turn up PA level.
51 #define MY_RF24_PA_LEVEL RF24_PA_LOW
53 // Enable serial gateway
54 #define MY_GATEWAY_SERIAL
56 // Define a lower baud rate for Arduinos running on 8 MHz (Arduino Pro Mini 3.3V & SenseBender)
57 #if F_CPU == 8000000L
58 #define MY_BAUD_RATE 38400
59 #endif
61 // Enable inclusion mode
62 #define MY_INCLUSION_MODE_FEATURE
63 // Enable Inclusion mode button on gateway
64 //#define MY_INCLUSION_BUTTON_FEATURE
66 // Inverses behavior of inclusion button (if using external pullup)
67 //#define MY_INCLUSION_BUTTON_EXTERNAL_PULLUP
69 // Set inclusion mode duration (in seconds)
70 #define MY_INCLUSION_MODE_DURATION 60
71 // Digital pin used for inclusion mode button
72 //#define MY_INCLUSION_MODE_BUTTON_PIN 3
74 // Set blinking period
75 #define MY_DEFAULT_LED_BLINK_PERIOD 300
77 // Inverses the behavior of leds
78 //#define MY_WITH_LEDS_BLINKING_INVERSE
80 // Flash leds on rx/tx/err
81 // Uncomment to override default HW configurations
82 //#define MY_DEFAULT_ERR_LED_PIN 4 // Error led pin
83 //#define MY_DEFAULT_RX_LED_PIN 6 // Receive led pin
84 //#define MY_DEFAULT_TX_LED_PIN 5 // the PCB, on board LED
86 #include <MySensors.h>
88 void setup()
89 {
90  // Setup locally attached sensors
91 }
94 {
95  // Present locally attached sensors
96 }
98 void loop()
99 {
100  // Send locally attached sensor data here
101 }
Definition: GatewaySerial.ino:98
Definition: GatewaySerial.ino:93
Definition: GatewaySerial.ino:88
