Here is a list of all documented file members with links to the documentation:
- m -
- max
: MySensors.h
- MAX
: MySensors.h
- MAX_HOPS
: MyTransport.h
- MAX_MESSAGE_SIZE
: MyMessage.h
- MAX_PAYLOAD
: MyMessage.h
- MAX_PAYLOAD_SIZE
: MyMessage.h
- MAX_SUBSEQ_MSGS
: MyTransport.h
- mGetCommand
: MyMessage.h
- mGetEcho
: MyMessage.h
- mGetLength
: MyMessage.h
- mGetPayloadType
: MyMessage.h
- mGetRequestEcho
: MyMessage.h
- mGetSigned
: MyMessage.h
- mGetVersion
: MyMessage.h
- min
: MySensors.h
- MIN
: MySensors.h
- MISO_LEVEL
: SoftSPI.h
- MISO_MODE
: SoftSPI.h
- MODE_NOT_DEFINED
: MySensorsCore.h
- MOSI_MODE
: SoftSPI.h
- mSetCommand
: MyMessage.h
- mSetEcho
: MyMessage.h
- mSetLength
: MyMessage.h
- mSetPayloadType
: MyMessage.h
- mSetRequestEcho
: MyMessage.h
- mSetSigned
: MyMessage.h
- mSetVersion
: MyMessage.h
- MSG_GW_STARTUP_COMPLETE
: MyGatewayTransport.h
- MY_AES_KEY
: SecurityPersonalizer.ino
- MY_BAUD_RATE
: MyConfig.h
- MY_CAP_ARCH
: MyCapabilities.h
- MY_CAP_ENCR
: MyCapabilities.h
- MY_CAP_OTA_FW
: MyCapabilities.h
- MY_CAP_RADIO
: MyCapabilities.h
- MY_CAP_RESET
: MyCapabilities.h
- MY_CAP_RXBUF
: MyCapabilities.h
- MY_CAP_SIGN
: MyCapabilities.h
- MY_CAP_TYPE
: MyCapabilities.h
- MY_CAPABILITIES
: MyCapabilities.h
- MY_CONTROLLER_IP_ADDRESS
: MyConfig.h
- MY_CONTROLLER_URL_ADDRESS
: MyConfig.h
- MY_CORE_COMPATIBILITY_CHECK
: MyConfig.h
- MY_CORE_MIN_VERSION
: MySensorsCore.h
- MY_CORE_ONLY
, MyConfig.h
- MY_CORE_VERSION
: MySensorsCore.h
- MY_CRITICAL_SECTION
: MyHwHAL.h
- MY_DEBUG
: SecureActuator.ino
, MyConfig.h
- MY_DEBUG_OTA
: MyConfig.h
- MY_DEBUG_OTA_DISABLE_ECHO
: MyConfig.h
- MY_DEBUG_VERBOSE_GATEWAY
: MyConfig.h
- MY_DEBUG_VERBOSE_NRF5_ESB
: MyConfig.h
- MY_DEBUG_VERBOSE_OTA_UPDATE
: MyConfig.h
- MY_DEBUG_VERBOSE_RF24
: MyConfig.h
- MY_DEBUG_VERBOSE_RFM69
: MyConfig.h
- MY_DEBUG_VERBOSE_RFM69_REGISTERS
: MyConfig.h
- MY_DEBUG_VERBOSE_RFM95
: MyConfig.h
- MY_DEBUG_VERBOSE_SIGNING
, MyConfig.h
- MY_DEBUGDEVICE
: MyConfig.h
- MY_DEFAULT_ERR_LED_PIN
: MyConfig.h
- MY_DEFAULT_LED_BLINK_PERIOD
: MyConfig.h
- MY_DEFAULT_RX_LED_PIN
: MyConfig.h
- MY_DEFAULT_TX_LED_PIN
: MyConfig.h
- MY_DISABLE_RAM_ROUTING_TABLE_FEATURE
: MyConfig.h
- MY_DISABLE_REMOTE_RESET
: MyConfig.h
- MY_DISABLED_SERIAL
: MyConfig.h
- MY_ENCRYPTION_FEATURE
: MyConfig.h
- MY_ENCRYPTION_SIMPLE_PASSWD
: MyConfig.h
- MY_ESP8266_SERIAL_MODE
: MyConfig.h
- MY_GATEWAY_CLIENT_MODE
: MySensors.h
- MY_GATEWAY_ENC28J60
: MyConfig.h
- MY_GATEWAY_ESP32
: MyConfig.h
- MY_GATEWAY_ESP8266
: MyConfig.h
- MY_GATEWAY_LINUX
: MyConfig.h
- MY_GATEWAY_MAX_CLIENTS
: MyConfig.h
- MY_GATEWAY_MAX_RECEIVE_LENGTH
: MyConfig.h
- MY_GATEWAY_MAX_SEND_LENGTH
: MyConfig.h
- MY_GATEWAY_MQTT_CLIENT
: MyConfig.h
- MY_GATEWAY_SERIAL
: MyConfig.h
- MY_GATEWAY_TINYGSM
: MyConfig.h
- MY_GATEWAY_W5100
: MyConfig.h
- MY_GSM_APN
: MyConfig.h
- MY_GSM_BAUDRATE
: MyConfig.h
- MY_GSM_PIN
: MyConfig.h
- MY_GSM_PSW
: MyConfig.h
- MY_GSM_RX
: MyConfig.h
- MY_GSM_SSID
: MyConfig.h
- MY_GSM_TX
: MyConfig.h
- MY_GSM_USR
: MyConfig.h
- MY_HMAC_KEY
- MY_HOSTNAME
: MyConfig.h
- MY_HW_HAS_GETENTROPY
: MyHwHAL.h
- MY_HWID_PADDING_BYTE
: MyHwHAL.h
- MY_INCLUSION_BUTTON_EXTERNAL_PULLUP
: MyConfig.h
- MY_INCLUSION_BUTTON_FEATURE
: MyConfig.h
- MY_INCLUSION_BUTTON_PRESSED
: MyConfig.h
- MY_INCLUSION_LED_PIN
: MyConfig.h
- MY_INCLUSION_MODE_BUTTON_PIN
: MyConfig.h
- MY_INCLUSION_MODE_DURATION
: MyConfig.h
- MY_INCLUSION_MODE_FEATURE
: MyConfig.h
- MY_INDICATION_HANDLER
: MyConfig.h
- MY_IP_ADDRESS
: MyConfig.h
- MY_IP_GATEWAY_ADDRESS
: MyConfig.h
- MY_IP_RENEWAL_INTERVAL_MS
: MyConfig.h
- MY_IP_SUBNET_ADDRESS
: MyConfig.h
- MY_IS_GATEWAY
: MyConfig.h
- MY_IS_RFM69HW
: MyConfig.h
- MY_LINUX_CONFIG_FILE
: MyConfig.h
- MY_LINUX_IS_SERIAL_PTY
: MyConfig.h
- MY_LINUX_SERIAL_GROUPNAME
: MyConfig.h
- MY_LINUX_SERIAL_IS_PTY
: MyConfig.h
- MY_LINUX_SERIAL_PORT
: MyConfig.h
- MY_LINUX_SERIAL_PTY
: MyConfig.h
- MY_LOCK_DEVICE
: MyConfig.h
- MY_MAC_ADDRESS
: MyConfig.h
- MY_MQTT_CLIENT_ID
: MyConfig.h
- MY_MQTT_CLIENT_PUBLISH_RETAIN
: MyConfig.h
- MY_MQTT_PASSWORD
: MyConfig.h
- MY_MQTT_PUBLISH_TOPIC_PREFIX
: MyConfig.h
- MY_MQTT_SUBSCRIBE_TOPIC_PREFIX
: MyConfig.h
- MY_MQTT_USER
: MyConfig.h
- MY_NODE_ID
: MyConfig.h
- MY_NODE_LOCK_COUNTER_MAX
: MyConfig.h
- MY_NODE_LOCK_FEATURE
: MyConfig.h
, SecureActuator.ino
- MY_NODE_TYPE
: MyConfig.h
- MY_NODE_UNLOCK_PIN
: MyConfig.h
- MY_NRF5_ESB_ADDR_WIDTH
: MyConfig.h
- MY_NRF5_ESB_BASE_RADIO_ID
: MyConfig.h
- MY_NRF5_ESB_CHANNEL
: MyConfig.h
- MY_NRF5_ESB_ENABLE_ENCRYPTION
: MyConfig.h
- MY_NRF5_ESB_MODE
: MyConfig.h
- MY_NRF5_ESB_PA_LEVEL
: MyConfig.h
- MY_NRF5_ESB_REVERSE_ACK_RX
: MyConfig.h
- MY_NRF5_ESB_REVERSE_ACK_TX
: MyConfig.h
- MY_NRF5_ESB_RX_BUFFER_SIZE
: MyConfig.h
- MY_OTA_BOOTLOADER_MAJOR_VERSION
: MyOTAFirmwareUpdate.h
- MY_OTA_BOOTLOADER_MINOR_VERSION
- MY_OTA_BOOTLOADER_VERSION
- MY_OTA_FLASH_JDECID
: MyConfig.h
- MY_OTA_FLASH_SS
: MyConfig.h
- MY_OTA_LOG_RECEIVER_FEATURE
: MyConfig.h
- MY_OTA_LOG_SENDER_FEATURE
: MyConfig.h
- MY_OTA_RETRY
- MY_OTA_RETRY_DELAY
- MY_OTA_USE_I2C_EEPROM
: MyConfig.h
- MY_PARENT_NODE_ID
: MyConfig.h
- MY_PARENT_NODE_IS_STATIC
: MyConfig.h
- MY_PASSIVE_NODE
: MyConfig.h
- MY_PORT
: MyConfig.h
- MY_RADIO_NRF24
: MyConfig.h
- MY_RADIO_NRF5_ESB
: MyConfig.h
- MY_RADIO_RF24
, MyConfig.h
- MY_RADIO_RFM69
: MyConfig.h
- MY_RADIO_RFM95
: MyConfig.h
- MY_RAM_ROUTING_TABLE_ENABLED
: MySensors.h
- MY_RAM_ROUTING_TABLE_FEATURE
: MyConfig.h
- MY_REGISTRATION_CONTROLLER
: MyConfig.h
- MY_REGISTRATION_DEFAULT
: MyConfig.h
- MY_REGISTRATION_FEATURE
: MyConfig.h
- MY_REGISTRATION_RETRIES
: MyConfig.h
- MY_REPEATER_FEATURE
: MyConfig.h
- MY_RF24_ADDR_WIDTH
: MyConfig.h
- MY_RF24_BASE_RADIO_ID
: MyConfig.h
- MY_RF24_CE_PIN
: MyConfig.h
- MY_RF24_CHANNEL
: MyConfig.h
- MY_RF24_CS_PIN
: MyConfig.h
- MY_RF24_DATARATE
: MyConfig.h
- MY_RF24_ENABLE_ENCRYPTION
: MyConfig.h
- MY_RF24_IRQ_PIN
: MyConfig.h
- MY_RF24_PA_LEVEL
: MyConfig.h
- MY_RF24_POWER_PIN
: MyConfig.h
- MY_RF24_SPI_SPEED
: MyConfig.h
- MY_RFM69_ATC_MODE_DISABLED
: MyConfig.h
- MY_RFM69_ATC_TARGET_RSSI_DBM
: MyConfig.h
- MY_RFM69_CS_PIN
: MyConfig.h
- MY_RFM69_CSMA_LIMIT_DBM
: RFM69_new.h
- MY_RFM69_CSMA_TIMEOUT_MS
: RFM69_new.h
- MY_RFM69_ENABLE_ENCRYPTION
: MyConfig.h
- MY_RFM69_FREQUENCY
: MyConfig.h
- MY_RFM69_IRQ_NUM
: MyConfig.h
- MY_RFM69_IRQ_PIN
: MyConfig.h
- MY_RFM69_MAX_POWER_LEVEL_DBM
: MyConfig.h
- MY_RFM69_MODEM_CONFIGURATION
: RFM69_new.h
, MyConfig.h
- MY_RFM69_NETWORKID
: MyConfig.h
- MY_RFM69_NEW_DRIVER
: MyConfig.h
- MY_RFM69_POWER_PIN
: MyConfig.h
- MY_RFM69_RST_PIN
: MyConfig.h
- MY_RFM69_SPI_SPEED
: MyConfig.h
- MY_RFM69_TX_POWER_DBM
: MyConfig.h
- MY_RFM69_TX_TIMEOUT_MS
: RFM69_new.h
- MY_RFM69HW
: MyConfig.h
- MY_RFM95_ATC_MODE_DISABLED
: MyConfig.h
- MY_RFM95_ATC_TARGET_RSSI
: MyConfig.h
- MY_RFM95_CS_PIN
: MyConfig.h
- MY_RFM95_ENABLE_ENCRYPTION
: MyConfig.h
- MY_RFM95_FREQUENCY
: MyConfig.h
- MY_RFM95_IRQ_NUM
: MyConfig.h
- MY_RFM95_IRQ_PIN
: MyConfig.h
- MY_RFM95_MAX_POWER_LEVEL_DBM
: MyConfig.h
- MY_RFM95_MODEM_CONFIGRUATION
: MyConfig.h
- MY_RFM95_POWER_PIN
: MyConfig.h
- MY_RFM95_RST_PIN
: MyConfig.h
- MY_RFM95_SPI_SPEED
: MyConfig.h
- MY_RFM95_TCXO
: MyConfig.h
- MY_RFM95_TX_POWER_DBM
: MyConfig.h
- MY_RFM95_TX_TIMEOUT_MS
: RFM95.h
- MY_ROUTING_TABLE_SAVE_INTERVAL_MS
: MyConfig.h
- MY_RS485
: MyConfig.h
- MY_RS485_BAUD_RATE
: MyConfig.h
- MY_RS485_DE_INVERSE
: MyConfig.h
- MY_RS485_DE_PIN
: MyConfig.h
- MY_RS485_HWSERIAL
: MyConfig.h
- MY_RS485_MAX_MESSAGE_LENGTH
: MyConfig.h
- MY_RS485_SOH_COUNT
: MyConfig.h
- MY_RX_MESSAGE_BUFFER_FEATURE
: MyConfig.h
- MY_RX_MESSAGE_BUFFER_SIZE
: MyConfig.h
- MY_SECURITY_SIMPLE_PASSWD
: MyConfig.h
- MY_SERIAL_OUTPUT_SIZE
: MyConfig.h
- MY_SIGNAL_REPORT_ENABLED
: MyConfig.h
- MY_SIGNING_ATSHA204
: MyConfig.h
- MY_SIGNING_ATSHA204_PIN
: MyConfig.h
- MY_SIGNING_FEATURE
: MyConfig.h
- MY_SIGNING_NODE_WHITELISTING
: MyConfig.h
- MY_SIGNING_REQUEST_SIGNATURES
: MyConfig.h
- MY_SIGNING_SIMPLE_PASSWD
: MyConfig.h
- MY_SIGNING_SOFT
: MyConfig.h
- MY_SIGNING_SOFT_RANDOMSEED_PIN
: MyConfig.h
- MY_SIGNING_WEAK_SECURITY
: MyConfig.h
- MY_SLEEP_NOT_POSSIBLE
: MySensorsCore.h
- MY_SLEEP_TRANSPORT_RECONNECT_TIMEOUT_MS
: MyConfig.h
- MY_SMART_SLEEP_WAIT_DURATION_MS
: MyConfig.h
- MY_SOFT_SERIAL
- MY_SOFT_SPI_MISO_PIN
: MyConfig.h
- MY_SOFT_SPI_MOSI_PIN
: MyConfig.h
- MY_SOFT_SPI_SCK_PIN
: MyConfig.h
- MY_SOFTSPI
: MyConfig.h
- MY_SPECIAL_DEBUG
: MyConfig.h
- MY_SPIFLASH_SST25TYPE
: SPIFlash.h
- MY_SPLASH_SCREEN_DISABLED
: MyConfig.h
- MY_TRANSPORT_CHKUPL_INTERVAL_MS
: MyTransport.h
- MY_TRANSPORT_DISCOVERY_INTERVAL_MS
: MyConfig.h
- MY_TRANSPORT_ENCRYPTION
: MySensors.h
- MY_TRANSPORT_MAX_TSM_FAILURES
: MyTransport.h
- MY_TRANSPORT_MAX_TX_FAILURES
: MyTransport.h
- MY_TRANSPORT_SANITY_CHECK
: MyConfig.h
, MySensors.h
- MY_TRANSPORT_SANITY_CHECK_INTERVAL_MS
: MyConfig.h
- MY_TRANSPORT_STATE_RETRIES
: MyTransport.h
- MY_TRANSPORT_STATE_TIMEOUT_MS
: MyTransport.h
- MY_TRANSPORT_TIMEOUT_EXT_FAILURE_STATE_MS
: MyTransport.h
- MY_TRANSPORT_TIMEOUT_FAILURE_STATE_MS
: MyTransport.h
- MY_TRANSPORT_UPLINK_CHECK_DISABLED
: MyConfig.h
- MY_TRANSPORT_WAIT_READY_MS
: MyConfig.h
- MY_USE_UDP
: MyConfig.h
- MY_VERIFICATION_TIMEOUT_MS
: MyConfig.h
- MY_WAKE_UP_BY_TIMER
: MySensorsCore.h
- MY_WIFI_BSSID
: MyConfig.h
- MY_WIFI_PASSWORD
: MyConfig.h
- MY_WIFI_SSID
: MyConfig.h
- MY_WITH_LEDS_BLINKING_INVERSE
: MyConfig.h
- MyMessage()
: MyMessage.h
- mysensors_command_t
: MyMessage.h
- mysensors_internal_t
: MyMessage.h
- MYSENSORS_LIBRARY_VERSION
: Version.h
- MYSENSORS_LIBRARY_VERSION_INT
: Version.h
- MYSENSORS_LIBRARY_VERSION_MAJOR
: Version.h
- MYSENSORS_LIBRARY_VERSION_MINOR
: Version.h
- MYSENSORS_LIBRARY_VERSION_PATCH
: Version.h
- MYSENSORS_LIBRARY_VERSION_PRERELEASE
: Version.h
- MYSENSORS_LIBRARY_VERSION_PRERELEASE_NUMBER
: Version.h
- mysensors_payload_t
: MyMessage.h
- mysensors_stream_t
: MyMessage.h
