These options control gateway specific configurations.
#define | MY_GATEWAY_MAX_RECEIVE_LENGTH (100u) |
Max buffersize needed for messages coming from controller. | |
#define | MY_GATEWAY_MAX_SEND_LENGTH (120u) |
Max buffer size when sending messages. | |
#define | MY_GATEWAY_MAX_CLIENTS (1u) |
Max number of parallel clients (sever mode). | |
#define | MY_INCLUSION_MODE_FEATURE |
Define this to enable the inclusion mode feature. | |
#define | MY_INCLUSION_BUTTON_FEATURE |
Enables inclusion-mode button feature on the gateway device. More... | |
#define | MY_INCLUSION_LED_PIN |
Enables an inclusion mode LED indicator on the gateway device. More... | |
#define | MY_INCLUSION_MODE_BUTTON_PIN (3) |
The default input pin used for the inclusion mode button. | |
#define | MY_INCLUSION_MODE_DURATION (60) |
Number of seconds inclusion mode should be enabled. | |
#define | MY_INCLUSION_BUTTON_EXTERNAL_PULLUP |
Define this to change the default state for MY_INCLUSION_BUTTON_PRESSED. | |
#define | MY_INCLUSION_BUTTON_PRESSED (LOW) |
The logical level indicating a pressed inclusion mode button. More... | |
#define | MY_GATEWAY_W5100 |
Define this for Ethernet GW based on the W5100 module. | |
#define | MY_GATEWAY_ENC28J60 |
Define this for Ethernet GW based on the ENC28J60 module. | |
#define | MY_GATEWAY_ESP8266 |
Define this for Ethernet GW based on the ESP8266. | |
#define | MY_GATEWAY_ESP32 |
Define this for Ethernet GW based on the ESP32. | |
#define | MY_GATEWAY_LINUX |
Define this for Ethernet GW based on Linux. | |
#define | MY_GATEWAY_TINYGSM |
Define this for Ethernet GW based on GSM modems supported by TinyGSM library. | |
#define | MY_GATEWAY_MQTT_CLIENT |
Define this for MQTT client GW. | |
#define | MY_GATEWAY_SERIAL |
Define this for Serial GW. | |
#define | MY_DEBUG_VERBOSE_GATEWAY |
Define this for verbose debug prints related to the gateway transport. | |
#define | MY_WIFI_SSID |
SSID of your WiFi network. | |
#define | MY_WIFI_BSSID NULL |
BSSID of your WiFi network. | |
#define | MY_WIFI_BSSID |
#define | MY_WIFI_PASSWORD |
Password of your WiFi network. | |
#define | MY_HOSTNAME "MYSENSORS_DEVICE" |
Hostname of your device. | |
#define | MY_HOSTNAME |
#define | MY_PORT 5003 |
The Ethernet TCP/UDP port to open on controller or gateway. | |
#define | MY_MQTT_CLIENT_PUBLISH_RETAIN |
Enables MQTT client to set the retain flag when publishing specific messages. | |
#define | MY_MQTT_PASSWORD |
Used for authenticated MQTT connections. More... | |
#define | MY_MQTT_USER |
#define | MY_MQTT_CLIENT_ID |
Set client ID for MQTT connections. More... | |
#define | MY_MQTT_PUBLISH_TOPIC_PREFIX |
Set prefix for MQTT topic to publish to. More... | |
#define | MY_MQTT_SUBSCRIBE_TOPIC_PREFIX |
Set prefix for MQTT topic to subscribe to. More... | |
#define | MY_IP_ADDRESS |
Static ip address of gateway. If not defined, DHCP will be used. More... | |
#define | MY_IP_GATEWAY_ADDRESS |
IP address of your broadband router/gateway, if not using DHCP. More... | |
#define | MY_IP_SUBNET_ADDRESS |
Subnet address of your local network, if not using DHCP. More... | |
#define | MY_USE_UDP |
Enables UDP mode for Ethernet gateway. More... | |
#define | MY_IP_RENEWAL_INTERVAL_MS (60*1000ul) |
DHCP, default renewal setting in milliseconds. | |
#define | MY_MAC_ADDRESS 0xDE,0xAD,0xBE,0xEF,0xFE,0xED |
Ethernet MAC address. More... | |
#define | MY_CONTROLLER_IP_ADDRESS |
If this is defined, gateway will act as a client trying to contact controller on MY_PORT using this IP address. More... | |
#define | MY_CONTROLLER_URL_ADDRESS |
If this is defined, gateway will act as a client (ethernet or MQTT) trying to contact controller on the given URL. More... | |
#define MY_CONTROLLER_IP_ADDRESS |
Example:
If left un-defined, gateway acts as server allowing incoming connections.
Definition at line 2294 of file MyConfig.h.
#define MY_CONTROLLER_URL_ADDRESS |
If left un-defined, gateway acts as server allowing incoming connections. Example:
Definition at line 2295 of file MyConfig.h.
#define MY_INCLUSION_BUTTON_FEATURE |
With this defined, you can put the GW in inclusion mode by pressing a button attached to the GW.
Definition at line 2247 of file MyConfig.h.
#define MY_INCLUSION_BUTTON_PRESSED (LOW) |
If MY_INCLUSION_BUTTON_EXTERNAL_PULLUP is defined, this defaults to HIGH.
Definition at line 1353 of file MyConfig.h.
#define MY_INCLUSION_LED_PIN |
With this defined, inclusion mode status (on or off) is indicated by the LED. This feature obeys MY_WITH_LEDS_BLINKING_INVERSE
Definition at line 2277 of file MyConfig.h.
#define MY_IP_ADDRESS |
Example:
Definition at line 2290 of file MyConfig.h.
#define MY_IP_GATEWAY_ADDRESS |
Example:
Definition at line 2291 of file MyConfig.h.
#define MY_IP_SUBNET_ADDRESS |
Example:
Definition at line 2292 of file MyConfig.h.
#define MY_MAC_ADDRESS 0xDE,0xAD,0xBE,0xEF,0xFE,0xED |
Definition at line 1533 of file MyConfig.h.
#define MY_MQTT_CLIENT_ID |
This define is mandatory for all MQTT client gateways. Example:
Definition at line 2262 of file MyConfig.h.
#define MY_MQTT_PASSWORD |
Set if your MQTT broker requires username/password. Example:
Definition at line 2260 of file MyConfig.h.
#define MY_MQTT_PUBLISH_TOPIC_PREFIX |
Definition at line 2263 of file MyConfig.h.
#define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX |
Definition at line 2264 of file MyConfig.h.
#define MY_MQTT_USER |
Definition at line 2261 of file MyConfig.h.
#define MY_USE_UDP |
Definition at line 2293 of file MyConfig.h.
