Collaboration diagram for Serial and debugging:These options control serial and debugging features and functionalities in the library.
Modules | |
| Transport selection | |
| These options control what transport type to use and various transport specific customisations. | |
| Routing and node | |
| These options control message routing and node configurations. | |
| Node registration | |
| These options control node registration configurations. | |
| Core | |
| These options control the library core configurations. | |
| Sleep | |
| These options control sleep configurations. | |
| Over The Air firmware | |
| These options control OTA firmware configurations. | |
| Gateway | |
| These options control gateway specific configurations. | |
| GSM | |
| These options control GSM specific configurations. | |
| LED | |
| These options control LED specific configurations. | |
| Security | |
| These options control security related configurations. | |
| Platform specifics | |
| These options control platform specific configurations. | |
| #define | MY_DEBUG_VERBOSE_OTA_UPDATE |
| Define this for verbose debug prints related to FOTA updates. | |
| #define | MY_OTA_USE_I2C_EEPROM |
| Define this if you want I2C EEPROM instead of a SPI flash. Used EEPROM needs to be large enough, an 24(L)C256 will do as minimum. HW I2C assumed. This will exclude the SPI flash code. Note that you also need an updated DualOptiboot supporting I2C EEPROM! | |
| #define | MY_IS_GATEWAY |
| true when configuration indicate a gateway device, More... | |
| #define | MY_NODE_TYPE |
| "GW" for gateways, REPEATER" for repeaters, "NODE" for nodes, More... | |
| #define | DEBUG_OUTPUT(x, ...) |
| debug NULL | |
| #define | ARDUINO_ARCH_SAMD |
| Automatically set when building for SAMD targets. | |
| #define | ARDUINO_ARCH_NRF5 |
| Automatically set when building for nRF5 targets. | |
| #define | ARDUINO_ARCH_ESP8266 |
| Automatically set when building for ESP8266 targets. | |
| #define | ARDUINO_ARCH_ESP32 |
| Automatically set when building for ESP32 targets. | |
| #define | ARDUINO_ARCH_AVR |
| Automatically set when building for AVR targets. | |
| #define | ARDUINO_ARCH_STM32F1 |
| Automatically set when building for STM32F1 targets. | |
| #define | TEENSYDUINO |
| Automatically set when building for Teensy targets. | |
| #define | MY_DEBUG |
| Define MY_DEBUG to show debug prints. More... | |
| #define | MY_DEBUGDEVICE |
| Define MY_DEBUGDEVICE to redirect debug prints. More... | |
| #define | MY_DEBUG_OTA |
| Define MY_DEBUG_OTA to (nodeID) to redirect debug prints to given node ID. More... | |
| #define | MY_DEBUG_OTA_DISABLE_ECHO |
| Define MY_DEBUG_OTA_DISABLE_ECHO to send messages without requesting the destination to echo the message. More... | |
| #define | MY_OTA_LOG_RECEIVER_FEATURE |
| Define this to enable printing of OTA logs. More... | |
| #define | MY_OTA_LOG_SENDER_FEATURE |
| #define | MY_SPECIAL_DEBUG |
| Define MY_SPECIAL_DEBUG to enable support for I_DEBUG messages. More... | |
| #define | MY_DISABLED_SERIAL |
| Define MY_DISABLED_SERIAL if you want to use the UART TX/RX pins as normal I/O pins. More... | |
| #define | MY_BAUD_RATE (115200ul) |
| Serial output baud rate (debug prints and serial gateway speed). More... | |
| #define | MY_SERIAL_OUTPUT_SIZE (120u) |
| Maximum characters for serial output. More... | |
| #define | MY_SPLASH_SCREEN_DISABLED |
| If defined, will disable the MySensors splash screen. More... | |
| #define MY_BAUD_RATE (115200ul) |
The baud rate configured here must match the baud rate at the "other" end.
Definition at line 163 of file MyConfig.h.
| #define MY_DEBUG |
This option will add a lot to the size of the final sketch but is helpful to see what is actually is happening during development.
Definition at line 2232 of file MyConfig.h.
| #define MY_DEBUG_OTA |
Example:
will redirect debug prints to node ID 0.
With this option debugging messages over serial are disabled. It's not possible to send debug messages generated by the radio. All other debug messages redirected to the given Node ID. The debug messages are sent without signing.
This function allocates some additional memory for radio packet preparation and buffering. Debug messages are sent to child ID 255 (NODE_SENSOR_ID) as I_LOG_MESSAGE type.
You have to enable the MY_OTA_LOG_RECEIVER_FEATURE on the target node. Look into the LogOTAGateway and LogOTANode examples.
The output buffer can be configured via MY_SERIAL_OUTPUT_SIZE Transport related debugging is disabled when MY_DEBUG_OTA is enabled.
Definition at line 2234 of file MyConfig.h.
| #define MY_DEBUG_OTA_DISABLE_ECHO |
This option reduces the latency added by OTA debug messages by sending packages only once. You can loose debug messages.
Definition at line 2235 of file MyConfig.h.
| #define MY_DEBUGDEVICE |
If defined, MY_DEBUGDEVICE replaces MY_SERIALDEVICE for the purpose of printing debug messages. This only applies to debugging.
The intent is to provide the ability to send debugging messages out a different serial port than what is being used for communication between nodes or from gateway to controller when this communication uses a serial interface. This assumes that the MY_DEBUGDEVICE serial interface already exists. It can be a hardware serial device or a software serial device.
Definition at line 2233 of file MyConfig.h.
| #define MY_DISABLED_SERIAL |
Definition at line 2237 of file MyConfig.h.
| #define MY_IS_GATEWAY |
Definition at line 2117 of file MyConfig.h.
| #define MY_NODE_TYPE |
Definition at line 2118 of file MyConfig.h.
| #define MY_OTA_LOG_RECEIVER_FEATURE |
This option requires additional memory for buffering. The buffer size can be configured via MY_SERIAL_OUTPUT_SIZE.
Definition at line 2249 of file MyConfig.h.
| #define MY_OTA_LOG_SENDER_FEATURE |
Definition at line 2250 of file MyConfig.h.
| #define MY_SERIAL_OUTPUT_SIZE (120u) |
If you are running extremely low on memory, reducing this size might just save your day.
Definition at line 173 of file MyConfig.h.
| #define MY_SPECIAL_DEBUG |
I_DEBUG messages are sent from the controller to the node, which responds with the requested data. The request can be one of the following:
Definition at line 2236 of file MyConfig.h.
| #define MY_SPLASH_SCREEN_DISABLED |
Definition at line 2238 of file MyConfig.h.
