MyConfig.h
5  * repeater and gateway builds a routing tables in RAM or EEPROM which keeps track of the
18  */
28 #ifndef MyConfig_h
29 #define MyConfig_h
48 //#define MY_DEBUG
64 //#define MY_DEBUGDEVICE
86 //#define MY_DEBUG_OTA (0)
97 //#define MY_DEBUG_OTA_DISABLE_ECHO
98 #if defined(MY_DEBUG_OTA_DISABLE_ACK) && !defined(DOXYGEN)
99 #warning MY_DEBUG_OTA_DISABLE_ACK is deprecated, please use MY_DEBUG_OTA_DISABLE_ECHO instead
100 #define MY_DEBUG_OTA_DISABLE_ECHO
101 #endif
110 //#define MY_OTA_LOG_RECEIVER_FEATURE
119 //#define MY_OTA_LOG_SENDER_FEATURE
134 //#define MY_SPECIAL_DEBUG
143 //#define MY_DISABLED_SERIAL
144
152 //#define MY_SPLASH_SCREEN_DISABLED
162 #ifndef MY_BAUD_RATE
163 #define MY_BAUD_RATE (115200ul)
164 #endif
165
172 #ifndef MY_SERIAL_OUTPUT_SIZE
173 #define MY_SERIAL_OUTPUT_SIZE (120u)
174 #endif
175  // End of SerialDebugGrpPub group
176
181 //#define MY_DEBUG_VERBOSE_OTA_UPDATE
182
190 //#define MY_OTA_USE_I2C_EEPROM
191
192 #ifdef MY_OTA_USE_I2C_EEPROM
193 // I2C address of EEPROM. Wire will shift this left, i.e. 0x50->0xA0
194 #ifndef MY_OTA_I2C_ADDR
195 #define MY_OTA_I2C_ADDR 0x50
196 #endif
197 #endif
198
199
219 //#define MY_RS485
220
225 #ifndef MY_RS485_BAUD_RATE
226 #define MY_RS485_BAUD_RATE (9600)
227 #endif
228
233 #ifndef MY_RS485_MAX_MESSAGE_LENGTH
234 #define MY_RS485_MAX_MESSAGE_LENGTH (40)
235 #endif
236
241 #ifndef MY_RS485_SOH_COUNT
242 #define MY_RS485_SOH_COUNT (1)
243 #endif
244
245
250 //#define MY_RS485_DE_PIN (2)
251
256 //#define MY_RS485_DE_INVERSE
257
264 //#define MY_RS485_HWSERIAL (Serial1) // End of RS485SettingGrpPub group
266
287 // legacy - remove for 3.0.0
293 #ifdef MY_RADIO_NRF24
294 #warning MY_RADIO_NRF24 is deprecated, use MY_RADIO_RF24 instead.
295 #undef MY_RADIO_NRF24
296 #define MY_RADIO_RF24
297 #endif
298
303 //#define MY_RADIO_RF24
304
315 //#define MY_RF24_ENABLE_ENCRYPTION
316
321 //#define MY_DEBUG_VERBOSE_RF24
322
329 #ifndef MY_RF24_SPI_SPEED
330 #define MY_RF24_SPI_SPEED (2*1000000ul)
331 #endif
332
337 #ifndef MY_RF24_CE_PIN
338 #define MY_RF24_CE_PIN (DEFAULT_RF24_CE_PIN)
339 #endif
340
345 #ifndef MY_RF24_CS_PIN
346 #define MY_RF24_CS_PIN (DEFAULT_RF24_CS_PIN)
347 #endif
348
353 //#define MY_RF24_IRQ_PIN (2)
354
359 //#define MY_RF24_POWER_PIN (3)
360
372 //#define MY_RX_MESSAGE_BUFFER_FEATURE
373
380 #ifdef MY_RX_MESSAGE_BUFFER_FEATURE
381 #ifndef MY_RX_MESSAGE_BUFFER_SIZE
382 #define MY_RX_MESSAGE_BUFFER_SIZE (20)
383 #endif
384 #endif
385
395 #ifndef MY_RF24_PA_LEVEL
396 #define MY_RF24_PA_LEVEL (RF24_PA_HIGH)
397 #endif
398
419 #ifndef MY_RF24_CHANNEL
420 #define MY_RF24_CHANNEL (76)
421 #endif
422
434 #ifndef MY_RF24_DATARATE
435 #define MY_RF24_DATARATE (RF24_250KBPS)
436 #endif
437
445 #ifndef MY_RF24_BASE_RADIO_ID
446 #define MY_RF24_BASE_RADIO_ID 0x00,0xFC,0xE1,0xA8,0xA8
447 #endif
448
453 #ifndef MY_RF24_ADDR_WIDTH
454 #define MY_RF24_ADDR_WIDTH (5)
455 #endif
456  // End of RF24SettingGrpPub group
457
479 //#define MY_RADIO_NRF5_ESB
480
491 //#define MY_NRF5_ESB_ENABLE_ENCRYPTION
492
497 //#define MY_DEBUG_VERBOSE_NRF5_ESB
498
508 #ifndef MY_NRF5_ESB_PA_LEVEL
509 #define MY_NRF5_ESB_PA_LEVEL (NRF5_PA_MAX)
510 #endif
511
532 #ifndef MY_NRF5_ESB_CHANNEL
533 #define MY_NRF5_ESB_CHANNEL (76)
534 #endif
535
545 #ifndef MY_NRF5_ESB_MODE
546 #define MY_NRF5_ESB_MODE (NRF5_250KBPS)
547 #endif
548
556 #ifndef MY_NRF5_ESB_BASE_RADIO_ID
557 #define MY_NRF5_ESB_BASE_RADIO_ID 0x00, 0xFC, 0xE1, 0xA8, 0xA8
558 #endif
559
564 #ifndef MY_NRF5_ESB_ADDR_WIDTH
565 #define MY_NRF5_ESB_ADDR_WIDTH (5)
566 #endif
567
572 #ifndef MY_NRF5_ESB_RX_BUFFER_SIZE
573 #define MY_NRF5_ESB_RX_BUFFER_SIZE (20)
574 #endif
575
580 //#define MY_NRF5_ESB_REVERSE_ACK_TX
581
586 //#define MY_NRF5_ESB_REVERSE_ACK_RX // End of NRF5SettingGrpPub group
588
605 //#define MY_RADIO_RFM69
606
611 //#define MY_DEBUG_VERBOSE_RFM69
612
617 //#define MY_DEBUG_VERBOSE_RFM69_REGISTERS
618
625 //#define MY_RFM69_NEW_DRIVER
626
642 #ifndef MY_RFM69_FREQUENCY
643 #define MY_RFM69_FREQUENCY (RFM69_868MHZ)
644 #endif
645
650 //#define MY_IS_RFM69HW
651
658 #ifdef MY_IS_RFM69HW
659 #define MY_RFM69HW true
660 #else
661 #define MY_RFM69HW false
662 #endif
663
668 #ifndef MY_RFM69_TX_POWER_DBM
669 #define MY_RFM69_TX_POWER_DBM (5)
670 #endif
671
676 #ifndef MY_RFM69_ATC_TARGET_RSSI_DBM
677 #define MY_RFM69_ATC_TARGET_RSSI_DBM (-80)
678 #endif
679
684 //#define MY_RFM69_ATC_MODE_DISABLED
685
697 //#define MY_RFM69_MAX_POWER_LEVEL_DBM (10u)
698
703 #ifndef MY_RFM69_NETWORKID
704 #define MY_RFM69_NETWORKID (100)
705 #endif
706
711 //#define MY_RFM69_RST_PIN (9)
712
713 #ifdef MY_RF69_RESET
714 #warning MY_RF69_RESET is depreciated, please use MY_RFM69_RST_PIN instead.
715 #define MY_RFM69_RST_PIN MY_RF69_RESET
716 #endif
717
722 //#define MY_RFM69_POWER_PIN (3)
723
728 #ifndef MY_RFM69_IRQ_PIN
729 #ifdef MY_RF69_IRQ_PIN
730 #warning MY_RF69_IRQ_PIN is depreciated, please use MY_RFM69_IRQ_PIN instead.
731 #define MY_RFM69_IRQ_PIN MY_RF69_IRQ_PIN
732 #else
733 #define MY_RFM69_IRQ_PIN DEFAULT_RFM69_IRQ_PIN
734 #endif
735 #endif
736
741 #ifndef MY_RFM69_IRQ_NUM
742 #ifdef MY_RF69_IRQ_NUM
743 #warning MY_RF69_IRQ_NUM is depreciated, please use MY_RFM69_IRQ_NUM instead.
744 #define MY_RFM69_IRQ_NUM MY_RF69_IRQ_NUM
745 #else
746 #define MY_RFM69_IRQ_NUM digitalPinToInterrupt(MY_RFM69_IRQ_PIN)
747 #endif
748 #endif
749
754 #ifndef MY_RFM69_CS_PIN
755 #ifdef MY_RF69_SPI_CS
756 #warning MY_RF69_SPI_CS is depreciated, please use MY_RFM69_CS_PIN instead.
757 #define MY_RFM69_CS_PIN MY_RF69_SPI_CS
758 #else
759 #define MY_RFM69_CS_PIN DEFAULT_RFM69_CS_PIN
760 #endif
761 #endif
762
767 #ifndef MY_RFM69_SPI_SPEED
768 #define MY_RFM69_SPI_SPEED (4*1000000ul) // datasheet says 10Mhz max.
769 #endif
770
779 //#define MY_RFM69_ENABLE_ENCRYPTION
780
801 //#define MY_RFM69_MODEM_CONFIGURATION (RFM69_FSK_BR55_5_FD50)
802
803  // End of RFM69SettingGrpPub group
805
820 //#define MY_RADIO_RFM95
821
826 //#define MY_DEBUG_VERBOSE_RFM95
827
838 //#define MY_RFM95_ENABLE_ENCRYPTION
839
854 #ifndef MY_RFM95_FREQUENCY
855 #define MY_RFM95_FREQUENCY (RFM95_868MHZ)
856 #endif
857
874 #ifndef MY_RFM95_MODEM_CONFIGRUATION
875 #define MY_RFM95_MODEM_CONFIGRUATION RFM95_BW125CR45SF128
876 #endif
877
882 //#define MY_RFM95_RST_PIN (9)
883
888 //#define MY_RFM95_POWER_PIN (3)
889
894 #ifndef MY_RFM95_IRQ_PIN
895 #define MY_RFM95_IRQ_PIN DEFAULT_RFM95_IRQ_PIN
896 #endif
897
902 #ifndef MY_RFM95_IRQ_NUM
903 #define MY_RFM95_IRQ_NUM digitalPinToInterrupt(MY_RFM95_IRQ_PIN)
904 #endif
905
910 #ifndef MY_RFM95_CS_PIN
911 #define MY_RFM95_CS_PIN DEFAULT_RFM95_CS_PIN
912 #endif
913
918 #ifndef MY_RFM95_SPI_SPEED
919 #define MY_RFM95_SPI_SPEED (4*1000000ul)
920 #endif
921
928 #ifndef MY_RFM95_TX_POWER_DBM
929 #define MY_RFM95_TX_POWER_DBM (13u) // 20mW
930 #endif
931
936 //#define MY_RFM95_ATC_MODE_DISABLED
937
942 #ifndef MY_RFM95_ATC_TARGET_RSSI
943 #define MY_RFM95_ATC_TARGET_RSSI (-70)
944 #endif
945
957 //#define MY_RFM95_MAX_POWER_LEVEL_DBM (10u)
958
965 //#define MY_RFM95_TCXO // End of RFM95SettingGrpPub group
967
985 //#define MY_SOFTSPI
986
991 #ifndef MY_SOFT_SPI_SCK_PIN
992 #define MY_SOFT_SPI_SCK_PIN (14)
993 #endif
994
999 #ifndef MY_SOFT_SPI_MISO_PIN
1000 #define MY_SOFT_SPI_MISO_PIN (16)
1001 #endif
1002
1007 #ifndef MY_SOFT_SPI_MOSI_PIN
1008 #define MY_SOFT_SPI_MOSI_PIN (15)
1009 #endif
1010  // End of SoftSpiSettingGrpPub group
1011  // End of TransportSettingGrpPub group
1013
1034 #ifndef MY_DISABLE_RAM_ROUTING_TABLE_FEATURE
1035 #define MY_RAM_ROUTING_TABLE_FEATURE
1036 #endif
1037
1042 #ifndef MY_ROUTING_TABLE_SAVE_INTERVAL_MS
1043 #define MY_ROUTING_TABLE_SAVE_INTERVAL_MS (30*60*1000ul)
1044 #endif
1045
1052 //#define MY_REPEATER_FEATURE
1053
1063 //#define MY_PASSIVE_NODE
1064
1069 #ifndef MY_NODE_ID
1070 #define MY_NODE_ID (AUTO)
1071 #endif
1072
1077 #ifndef MY_PARENT_NODE_ID
1078 #define MY_PARENT_NODE_ID (AUTO)
1079 #endif
1080
1085 //#define MY_PARENT_NODE_IS_STATIC
1086
1093 //#define MY_TRANSPORT_SANITY_CHECK
1094
1099 #ifndef MY_TRANSPORT_SANITY_CHECK_INTERVAL_MS
1100 #define MY_TRANSPORT_SANITY_CHECK_INTERVAL_MS (15*60*1000ul)
1101 #endif
1102
1106 #ifndef MY_TRANSPORT_DISCOVERY_INTERVAL_MS
1107 #define MY_TRANSPORT_DISCOVERY_INTERVAL_MS (20*60*1000ul)
1108 #endif
1109
1114 //#define MY_TRANSPORT_UPLINK_CHECK_DISABLED
1115
1120 //#define MY_TRANSPORT_MAX_TX_FAILURES (10u)
1121
1126 #ifndef MY_TRANSPORT_WAIT_READY_MS
1127 #define MY_TRANSPORT_WAIT_READY_MS (0)
1128 #endif
1129
1135 //#define MY_SIGNAL_REPORT_ENABLED
1136  // End of RoutingNodeSettingGrpPub group
1138
1151 #define MY_REGISTRATION_FEATURE
1152
1158 #ifndef MY_REGISTRATION_RETRIES
1159 #define MY_REGISTRATION_RETRIES (3u)
1160 #endif
1161
1167 #define MY_REGISTRATION_DEFAULT (true)
1168
1173 //#define MY_REGISTRATION_CONTROLLER // End of RegistrationSettingGrpPub group
1175
1186 //#define MY_CORE_ONLY
1187
1193 #define MY_CORE_COMPATIBILITY_CHECK
1194  // End of CoreSettingGrpPub group
1195
1206 #ifndef MY_SLEEP_TRANSPORT_RECONNECT_TIMEOUT_MS
1207 #define MY_SLEEP_TRANSPORT_RECONNECT_TIMEOUT_MS (10*1000ul)
1208 #endif
1209
1217 #ifndef MY_SMART_SLEEP_WAIT_DURATION_MS
1218 #define MY_SMART_SLEEP_WAIT_DURATION_MS (500ul)
1219 #endif
1220  // End of SleepSettingGrpPub group
1221
1237 //#define MY_OTA_FIRMWARE_FEATURE
1238
1243 #ifndef MY_OTA_FLASH_SS
1244 #define MY_OTA_FLASH_SS (8)
1245 #endif
1246
1251 #ifndef MY_OTA_FLASH_JDECID
1252 #define MY_OTA_FLASH_JDECID (0x1F65)
1253 #endif
1254
1259 //#define MY_DISABLE_REMOTE_RESET // End of OTASettingGrpPub group
1261
1272 #ifndef MY_GATEWAY_MAX_RECEIVE_LENGTH
1273 #define MY_GATEWAY_MAX_RECEIVE_LENGTH (100u)
1274 #endif
1275
1280 #ifndef MY_GATEWAY_MAX_SEND_LENGTH
1281 #define MY_GATEWAY_MAX_SEND_LENGTH (120u)
1282 #endif
1283
1288 #ifndef MY_GATEWAY_MAX_CLIENTS
1289 #define MY_GATEWAY_MAX_CLIENTS (1u)
1290 #endif
1291
1296 //#define MY_INCLUSION_MODE_FEATURE
1297
1304 //#define MY_INCLUSION_BUTTON_FEATURE
1305
1306 // Disable inclusion mode button if inclusion mode feature is not enabled
1307 #ifndef MY_INCLUSION_MODE_FEATURE
1308 #undef MY_INCLUSION_BUTTON_FEATURE
1309 #endif
1310
1318 //#define MY_INCLUSION_LED_PIN (7)
1319
1324 #ifndef MY_INCLUSION_MODE_BUTTON_PIN
1325 #if defined(ARDUINO_ARCH_ESP8266)
1326 #define MY_INCLUSION_MODE_BUTTON_PIN (5)
1327 #else
1328 #define MY_INCLUSION_MODE_BUTTON_PIN (3)
1329 #endif
1330 #endif
1331
1336 #ifndef MY_INCLUSION_MODE_DURATION
1337 #define MY_INCLUSION_MODE_DURATION (60)
1338 #endif
1339
1350 #if defined(MY_INCLUSION_BUTTON_EXTERNAL_PULLUP)
1351 #define MY_INCLUSION_BUTTON_PRESSED (HIGH)
1352 #else
1353 #define MY_INCLUSION_BUTTON_PRESSED (LOW)
1354 #endif
1355
1356
1357 /**************************************
1358 * Ethernet Gateway Transport Defaults
1359 ***************************************/
1378 // The gateway options available
1379 //#define MY_GATEWAY_W5100
1380 //#define MY_GATEWAY_ENC28J60
1381 //#define MY_GATEWAY_ESP8266
1382 //#define MY_GATEWAY_ESP32
1383 //#define MY_GATEWAY_LINUX
1384 //#define MY_GATEWAY_TINYGSM
1385 //#define MY_GATEWAY_MQTT_CLIENT
1386 //#define MY_GATEWAY_SERIAL
1387
1388
1393 //#define MY_DEBUG_VERBOSE_GATEWAY
1394
1399 //#define MY_WIFI_SSID "MySSID"
1400
1405 #ifndef MY_WIFI_BSSID
1406 #define MY_WIFI_BSSID NULL
1407 #endif
1408
1413 //#define MY_WIFI_PASSWORD "MyVerySecretPassword"
1414
1419 #ifndef MY_HOSTNAME
1420 #define MY_HOSTNAME "MYSENSORS_DEVICE"
1421 #endif
1422
1427 #ifndef MY_PORT
1428 #ifdef MY_GATEWAY_MQTT_CLIENT
1429 #define MY_PORT 1883
1430 #else
1431 #define MY_PORT 5003
1432 #endif
1433 #endif
1434
1439 //#define MY_MQTT_CLIENT_PUBLISH_RETAIN
1440
1449 //#define MY_MQTT_PASSWORD "secretpassword"
1450
1459 //#define MY_MQTT_USER "username"
1460
1468 //#define MY_MQTT_CLIENT_ID "mysensors-1"
1469
1477 //#define MY_MQTT_PUBLISH_TOPIC_PREFIX "mygateway1-out"
1478
1486 //#define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX "mygateway1-in"
1487
1494 //#define MY_IP_ADDRESS 192,168,178,66
1495
1502 //#define MY_IP_GATEWAY_ADDRESS 192,168,1,1
1503
1510 //#define MY_IP_SUBNET_ADDRESS 255,255,255,0
1511
1517 //#define MY_USE_UDP
1518
1523 #ifndef MY_IP_RENEWAL_INTERVAL_MS
1524 #define MY_IP_RENEWAL_INTERVAL_MS (60*1000ul)
1525 #endif
1526
1532 #ifndef MY_MAC_ADDRESS
1533 #define MY_MAC_ADDRESS 0xDE,0xAD,0xBE,0xEF,0xFE,0xED
1534 #endif
1535
1546 //#define MY_CONTROLLER_IP_ADDRESS 192,168,178,254
1547
1558 //#define MY_CONTROLLER_URL_ADDRESS "test.mosquitto.org"
1559  // End of GatewaySettingGrpPub group
1561
1572 //#define MY_GSM_APN
1577 //#define MY_GSM_BAUDRATE (9600u)
1582 //#define MY_GSM_PIN
1587 //#define MY_GSM_PSW
1592 //#define MY_GSM_RX
1597 //#define MY_GSM_SSID
1602 //#define MY_GSM_TX
1607 //#define MY_GSM_USR
1608  // End of GSMSettingGrpPub group
1610
1625 //#define MY_DEFAULT_ERR_LED_PIN (6)
1626
1635 //#define MY_DEFAULT_TX_LED_PIN (7)
1636
1645 //#define MY_DEFAULT_RX_LED_PIN (8)
1646
1653 //#define MY_WITH_LEDS_BLINKING_INVERSE
1654
1659 //#define MY_INDICATION_HANDLER
1660
1665 #ifndef MY_DEFAULT_LED_BLINK_PERIOD
1666 #define MY_DEFAULT_LED_BLINK_PERIOD 300
1667 #endif
1668  // End of LEDSettingGrpPub group
1669
1710 //#define MY_SECURITY_SIMPLE_PASSWD "MyInsecurePassword"
1711 #if defined(MY_SECURITY_SIMPLE_PASSWD)
1712 #define MY_SIGNING_SIMPLE_PASSWD MY_SECURITY_SIMPLE_PASSWD
1713 #define MY_ENCRYPTION_SIMPLE_PASSWD MY_SECURITY_SIMPLE_PASSWD
1714 #endif
1715
1728 //#define MY_DEBUG_VERBOSE_SIGNING
1729
1759 //#define MY_SIGNING_SIMPLE_PASSWD "MyInsecurePassword"
1760 #if defined(MY_SIGNING_SIMPLE_PASSWD)
1761 #define MY_SIGNING_SOFT
1762 #define MY_SIGNING_REQUEST_SIGNATURES
1763 #endif
1764
1769 //#define MY_SIGNING_ATSHA204
1770
1775 //#define MY_SIGNING_SOFT
1776
1785 //#define MY_SIGNING_REQUEST_SIGNATURES
1786
1803 //#define MY_SIGNING_WEAK_SECURITY
1804
1816 #ifndef MY_VERIFICATION_TIMEOUT_MS
1817 #define MY_VERIFICATION_TIMEOUT_MS (5*1000ul)
1818 #endif
1819
1836 //#define MY_SIGNING_NODE_WHITELISTING {{.nodeId = GATEWAY_ADDRESS,.serial = {0x09,0x08,0x07,0x06,0x05,0x04,0x03,0x02,0x01}}}
1837
1842 #ifndef MY_SIGNING_ATSHA204_PIN
1843 #define MY_SIGNING_ATSHA204_PIN (17)
1844 #endif
1845
1852 #ifndef MY_SIGNING_SOFT_RANDOMSEED_PIN
1853 #define MY_SIGNING_SOFT_RANDOMSEED_PIN (7)
1854 #endif
1855
1871 //#define MY_LOCK_DEVICE
1872
1878 #if defined(MY_SIGNING_ATSHA204) || defined(MY_SIGNING_SOFT)
1879 #define MY_SIGNING_FEATURE
1880 #endif
1881  // End of SigningSettingGrpPub group
1882
1911 //#define MY_ENCRYPTION_SIMPLE_PASSWD "MyInsecurePassword"
1912 #if defined(MY_ENCRYPTION_SIMPLE_PASSWD)
1913 #ifndef MY_RF24_ENABLE_ENCRYPTION
1914 #define MY_RF24_ENABLE_ENCRYPTION
1915 #endif
1916 #ifndef MY_RFM69_ENABLE_ENCRYPTION
1917 #define MY_RFM69_ENABLE_ENCRYPTION
1918 #endif
1919 #ifndef MY_NRF5_ESB_ENABLE_ENCRYPTION
1920 #define MY_NRF5_ESB_ENABLE_ENCRYPTION
1921 #endif
1922 #ifndef MY_RFM95_ENABLE_ENCRYPTION
1923 #define MY_RFM95_ENABLE_ENCRYPTION
1924 #endif
1925 #endif
1926
1933 #if defined(MY_RF24_ENABLE_ENCRYPTION) || defined(MY_RFM69_ENABLE_ENCRYPTION) || defined(MY_NRF5_ESB_ENABLE_ENCRYPTION) || defined(MY_RFM95_ENABLE_ENCRYPTION)
1934 #define MY_ENCRYPTION_FEATURE
1935 #endif
1936  // End of EncryptionSettingGrpPub group
1937
1977 //#define MY_NODE_LOCK_FEATURE
1978
1987 #ifndef MY_NODE_UNLOCK_PIN
1988 #define MY_NODE_UNLOCK_PIN (14)
1989 #endif
1990
1997 #ifndef MY_NODE_LOCK_COUNTER_MAX
1998 #define MY_NODE_LOCK_COUNTER_MAX (5)
1999 #endif
2000  // Node lock group // End of SecuritySettingGrpPub group
2002
2023 #ifndef MY_ESP8266_SERIAL_MODE
2024 #define MY_ESP8266_SERIAL_MODE SERIAL_FULL
2025 #endif
2026  // End of ESP8266SettingGrpPub group
2027
2035 //
2036 // no ESP32 settings
2037 //
2038  // End of ESP32SettingGrpPub group
2040
2052 //#define MY_LINUX_SERIAL_PORT "/dev/ttyUSB0"
2053
2058 #ifdef MY_LINUX_SERIAL_PTY
2059 #warning MY_LINUX_SERIAL_PTY is deprecated, please use MY_LINUX_SERIAL_PORT
2060 #define MY_LINUX_SERIAL_PORT MY_LINUX_SERIAL_PTY
2061 #endif
2062
2067 #ifdef MY_LINUX_IS_SERIAL_PTY
2068 #warning MY_LINUX_IS_SERIAL_PTY is deprecated, please use MY_LINUX_SERIAL_IS_PTY
2069 #define MY_LINUX_SERIAL_IS_PTY
2070 #endif
2071
2079 //#define MY_LINUX_SERIAL_IS_PTY
2080
2085 //#define MY_LINUX_SERIAL_GROUPNAME "tty"
2086
2093 #ifndef MY_LINUX_CONFIG_FILE
2094 #define MY_LINUX_CONFIG_FILE "/etc/mysensors.conf"
2095 #endif
2096  // End of LinuxSettingGrpPub group // End of PlatformSettingGrpPub group
2098
2099 /*
2100 * "Helper" definitions
2101 */
2102
2103 /*
2104  * Detect node type
2105  * MY_GATEWAY_FEATURE is set for gateway sketches.
2106  * MY_IS_GATEWAY is true when @ref MY_GATEWAY_FEATURE is set.
2107  * MY_NODE_TYPE contain a string describing the class of sketch/node (gateway/repeater/node).
2108  */
2109 #if defined(MY_GATEWAY_SERIAL) || defined(MY_GATEWAY_W5100) || defined(MY_GATEWAY_ENC28J60) || defined(MY_GATEWAY_ESP8266) || defined(MY_GATEWAY_ESP32)|| defined(MY_GATEWAY_LINUX) || defined(MY_GATEWAY_MQTT_CLIENT) || defined(MY_GATEWAY_TINYGSM)
2110 #define MY_GATEWAY_FEATURE
2111 #define MY_IS_GATEWAY (true)
2112 #define MY_NODE_TYPE "GW"
2113 #elif defined(MY_REPEATER_FEATURE)
2114 #define MY_IS_GATEWAY (false)
2115 #define MY_NODE_TYPE "REPEATER"
2116 #elif defined(DOXYGEN)
2117 #define MY_IS_GATEWAY
2118 #define MY_NODE_TYPE
2119 #else
2120 #define MY_IS_GATEWAY (false)
2121 #define MY_NODE_TYPE "NODE"
2122 #endif
2123
2124 // DEBUG
2125 #if defined(MY_DISABLED_SERIAL) && !defined(MY_DEBUG_OTA)
2126 #undef MY_DEBUG
2127 #endif
2128 #if defined(MY_DEBUG)
2129 // standard debug output
2130 #define MY_DEBUG_VERBOSE_CORE
2131 #define MY_DEBUG_VERBOSE_TRANSPORT
2132 #define MY_DEBUG_VERBOSE_GATEWAY
2133 #define MY_DEBUG_VERBOSE_OTA_UPDATE
2134 #endif
2135
2136 #if defined(MY_DEBUG) || defined(MY_DEBUG_VERBOSE_CORE) || defined(MY_DEBUG_VERBOSE_TRANSPORT) || defined(MY_DEBUG_VERBOSE_GATEWAY) || defined(MY_DEBUG_VERBOSE_SIGNING) || defined(MY_DEBUG_VERBOSE_OTA_UPDATE) || defined(MY_DEBUG_VERBOSE_RF24) || defined(MY_DEBUG_VERBOSE_NRF5_ESB) || defined(MY_DEBUG_VERBOSE_RFM69) || defined(MY_DEBUG_VERBOSE_RFM95) || defined(MY_DEBUG_VERBOSE_TRANSPORT_HAL)
2137 #define DEBUG_OUTPUT_ENABLED
2138 #ifndef MY_DEBUG_OTA
2139 #define DEBUG_OUTPUT(x,...) hwDebugPrint(x, ##__VA_ARGS__)
2140 #else
2141 #ifndef MY_OTA_LOG_SENDER_FEATURE
2142 #define MY_OTA_LOG_SENDER_FEATURE
2143 #endif
2144 #ifndef MY_DEBUG_OTA_DISABLE_ECHO
2145 #define DEBUG_OUTPUT(x,...) OTALog((MY_DEBUG_OTA), true, x, ##__VA_ARGS__)
2146 #else
2147 #define DEBUG_OUTPUT(x,...) OTALog((MY_DEBUG_OTA), false, x, ##__VA_ARGS__)
2148 #endif
2149 // disable radio related debugging messages
2150 #undef MY_DEBUG_VERBOSE_RF24
2151 #undef MY_DEBUG_VERBOSE_NRF5_ESB
2152 #undef MY_DEBUG_VERBOSE_RFM69
2153 #undef MY_DEBUG_VERBOSE_RFM69_REGISTERS
2154 #undef MY_DEBUG_VERBOSE_RFM95
2155 #endif
2156 #else
2157 #define DEBUG_OUTPUT(x,...)
2158 #endif
2159
2160 // temp. workaround for nRF5 verifier: redirect RF24 to NRF_ESB
2161 #if defined(ARDUINO_ARCH_NRF5) && (defined(MY_RADIO_RF24) )
2162 #undef MY_RADIO_RF24
2163 #define MY_RADIO_NRF5_ESB
2164 #endif
2165
2166 // Enable sensor network "feature" if one of the transport types was enabled
2167 #if defined(MY_RADIO_RF24) || defined(MY_RADIO_NRF5_ESB) || defined(MY_RADIO_RFM69) || defined(MY_RADIO_RFM95) || defined(MY_RS485)
2168 #define MY_SENSOR_NETWORK
2169 #endif
2170
2171 // LEDS
2172 #if !defined(MY_DEFAULT_ERR_LED_PIN) && defined(MY_HW_ERR_LED_PIN)
2173 #define MY_DEFAULT_ERR_LED_PIN MY_HW_ERR_LED_PIN
2174 #endif
2175
2176 #if !defined(MY_DEFAULT_TX_LED_PIN) && defined(MY_HW_TX_LED_PIN)
2177 #define MY_DEFAULT_TX_LED_PIN MY_HW_TX_LED_PIN
2178 #endif
2179
2180 #if !defined(MY_DEFAULT_RX_LED_PIN) && defined(MY_HW_TX_LED_PIN)
2181 #define MY_DEFAULT_RX_LED_PIN MY_HW_TX_LED_PIN
2182 #endif
2183
2184 #endif // MyConfig_h
2185
2186 // Doxygen specific constructs, not included when built normally
2187 // This is used to enable disabled macros/definitions to be included in the documentation as well.
2188 #if DOXYGEN
2189
2193 #define ARDUINO_ARCH_SAMD
2194
2199 #define ARDUINO_ARCH_NRF5
2200
2205 #define ARDUINO_ARCH_ESP8266
2206
2211 #define ARDUINO_ARCH_ESP32
2212
2217 #define ARDUINO_ARCH_AVR
2218
2223 #define ARDUINO_ARCH_STM32F1
2224
2229 #define TEENSYDUINO
2230
2231 // debug
2232 #define MY_DEBUG
2233 #define MY_DEBUGDEVICE
2234 #define MY_DEBUG_OTA
2235 #define MY_DEBUG_OTA_DISABLE_ECHO
2236 #define MY_SPECIAL_DEBUG
2237 #define MY_DISABLED_SERIAL
2238 #define MY_SPLASH_SCREEN_DISABLED
2239 // linux
2240 #define MY_LINUX_SERIAL_PORT
2241 #define MY_LINUX_SERIAL_IS_PTY
2242 #define MY_LINUX_SERIAL_GROUPNAME
2243 #define MY_LINUX_SERIAL_PTY
2244 #define MY_LINUX_IS_SERIAL_PTY
2245 // inclusion mode
2246 #define MY_INCLUSION_MODE_FEATURE
2247 #define MY_INCLUSION_BUTTON_FEATURE
2248 // OTA logging and debug
2249 #define MY_OTA_LOG_RECEIVER_FEATURE
2250 #define MY_OTA_LOG_SENDER_FEATURE
2251 // transport
2252 #define MY_PARENT_NODE_IS_STATIC
2253 #define MY_REGISTRATION_CONTROLLER
2254 #define MY_TRANSPORT_UPLINK_CHECK_DISABLED
2255 #define MY_TRANSPORT_SANITY_CHECK
2256 #define MY_NODE_LOCK_FEATURE
2257 #define MY_REPEATER_FEATURE
2258 #define MY_PASSIVE_NODE
2259 #define MY_MQTT_CLIENT_PUBLISH_RETAIN
2260 #define MY_MQTT_PASSWORD
2261 #define MY_MQTT_USER
2262 #define MY_MQTT_CLIENT_ID
2263 #define MY_MQTT_PUBLISH_TOPIC_PREFIX
2264 #define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX
2265 #define MY_SIGNAL_REPORT_ENABLED
2266 // general
2267 #define MY_WITH_LEDS_BLINKING_INVERSE
2268 #define MY_INDICATION_HANDLER
2269 #define MY_DISABLE_REMOTE_RESET
2270 #define MY_DISABLE_RAM_ROUTING_TABLE_FEATURE
2271 #define MY_LOCK_DEVICE
2272 // core
2273 #define MY_CORE_ONLY
2274 // GW
2275 #define MY_DEBUG_VERBOSE_GATEWAY
2276 #define MY_INCLUSION_BUTTON_EXTERNAL_PULLUP
2277 #define MY_INCLUSION_LED_PIN
2278 #define MY_GATEWAY_W5100
2279 #define MY_GATEWAY_ENC28J60
2280 #define MY_GATEWAY_ESP8266
2281 #define MY_GATEWAY_ESP32
2282 #define MY_WIFI_SSID
2283 #define MY_WIFI_BSSID
2284 #define MY_WIFI_PASSWORD
2285 #define MY_HOSTNAME
2286 #define MY_GATEWAY_LINUX
2287 #define MY_GATEWAY_TINYGSM
2288 #define MY_GATEWAY_MQTT_CLIENT
2289 #define MY_GATEWAY_SERIAL
2290 #define MY_IP_ADDRESS
2291 #define MY_IP_GATEWAY_ADDRESS
2292 #define MY_IP_SUBNET_ADDRESS
2293 #define MY_USE_UDP
2294 #define MY_CONTROLLER_IP_ADDRESS
2295 #define MY_CONTROLLER_URL_ADDRESS
2296 // TinyGSM
2297 #define MY_GSM_APN
2298 #define MY_GSM_BAUDRATE
2299 #define MY_GSM_PIN
2300 #define MY_GSM_PSW
2301 #define MY_GSM_RX
2302 #define MY_GSM_SSID
2303 #define MY_GSM_TX
2304 #define MY_GSM_USR
2305 // LED
2306 #define MY_DEFAULT_ERR_LED_PIN
2307 #define MY_DEFAULT_TX_LED_PIN
2308 #define MY_DEFAULT_RX_LED_PIN
2309 // signing
2310 #define MY_SECURITY_SIMPLE_PASSWD
2311 #define MY_SIGNING_SIMPLE_PASSWD
2312 #define MY_ENCRYPTION_SIMPLE_PASSWD
2313 #define MY_SIGNING_ATSHA204
2314 #define MY_SIGNING_SOFT
2315 #define MY_SIGNING_REQUEST_SIGNATURES
2316 #define MY_SIGNING_WEAK_SECURITY
2317 #define MY_SIGNING_NODE_WHITELISTING
2318 #define MY_DEBUG_VERBOSE_SIGNING
2319 #define MY_SIGNING_FEATURE
2320 #define MY_ENCRYPTION_FEATURE
2321 // FOTA update
2322 #define MY_DEBUG_VERBOSE_OTA_UPDATE
2323 #define MY_OTA_USE_I2C_EEPROM
2324 // RS485
2325 #define MY_RS485
2326 #define MY_RS485_DE_PIN
2327 #define MY_RS485_DE_INVERSE
2328 #define MY_RS485_HWSERIAL
2329 // RF24
2330 #define MY_RADIO_RF24
2331 #define MY_RADIO_NRF24 //deprecated
2332 #define MY_DEBUG_VERBOSE_RF24
2333 #define MY_RF24_POWER_PIN
2334 #define MY_RF24_IRQ_PIN
2335 #define MY_RF24_ENABLE_ENCRYPTION
2336 #define MY_RX_MESSAGE_BUFFER_FEATURE
2337 #define MY_RX_MESSAGE_BUFFER_SIZE
2338 // NRF5_ESB
2339 #define MY_RADIO_NRF5_ESB
2340 #define MY_NRF5_ESB_ENABLE_ENCRYPTION
2341 #define MY_DEBUG_VERBOSE_NRF5_ESB
2342 #define MY_NRF5_ESB_REVERSE_ACK_RX
2343 #define MY_NRF5_ESB_REVERSE_ACK_TX
2344 // RFM69
2345 #define MY_RADIO_RFM69
2346 #define MY_IS_RFM69HW
2347 #define MY_RFM69_NEW_DRIVER
2348 #define MY_RFM69_POWER_PIN
2349 #define MY_RFM69_MODEM_CONFIGURATION
2350 #define MY_RFM69_ENABLE_ENCRYPTION
2351 #define MY_RFM69_ATC_MODE_DISABLED
2352 #define MY_RFM69_MAX_POWER_LEVEL_DBM
2353 #define MY_RFM69_RST_PIN
2354 #define MY_DEBUG_VERBOSE_RFM69
2355 #define MY_DEBUG_VERBOSE_RFM69_REGISTERS
2356 // RFM95
2357 #define MY_RADIO_RFM95
2358 #define MY_DEBUG_VERBOSE_RFM95
2359 #define MY_RFM95_ENABLE_ENCRYPTION
2360 #define MY_RFM95_ATC_MODE_DISABLED
2361 #define MY_RFM95_RST_PIN
2362 #define MY_RFM95_MODEM_CONFIGRUATION
2363 #define MY_RFM95_POWER_PIN
2364 #define MY_RFM95_TCXO
2365 #define MY_RFM95_MAX_POWER_LEVEL_DBM
2366 // SOFT-SPI
2367 #define MY_SOFTSPI
2368 #endif
2369  // End of MyConfig group
