These options are specific to the nRF5 (with Enhanced ShockBurst) family of wireless transport modules.
The nRF5 driver is OTA compatible with the RF24 driver.
#define | MY_RADIO_NRF5_ESB |
Define this to use nRF5 based radios for sensor network communication. More... | |
#define | MY_NRF5_ESB_ENABLE_ENCRYPTION |
Define this to enable software based (RF24 compatible) AES encryption. More... | |
#define | MY_DEBUG_VERBOSE_NRF5_ESB |
Define this for verbose debug prints related to the nRF5 driver. | |
#define | MY_NRF5_ESB_PA_LEVEL (NRF5_PA_MAX) |
Default nRF5 PA level. Override in sketch if needed. More... | |
#define | MY_NRF5_ESB_CHANNEL (76) |
RF channel for the sensor net, 0-125. More... | |
#define | MY_NRF5_ESB_MODE (NRF5_250KBPS) |
nRF5 mode. More... | |
#define | MY_NRF5_ESB_BASE_RADIO_ID 0x00, 0xFC, 0xE1, 0xA8, 0xA8 |
nRF5 radio network identifier. More... | |
#define | MY_NRF5_ESB_ADDR_WIDTH (5) |
nRF5 base address width. | |
#define | MY_NRF5_ESB_RX_BUFFER_SIZE (20) |
Declare the amount of incoming messages that can be buffered at driver level. | |
#define | MY_NRF5_ESB_REVERSE_ACK_TX |
Switch to SI24R1 or faked nRF24L01+ compatible ACK mode. ACK bit is reversed on TX side. | |
#define | MY_NRF5_ESB_REVERSE_ACK_RX |
Switch to SI24R1 or faked nRF24L01+ compatible ACK mode. ACK bit is reversed on RX side. | |
#define MY_NRF5_ESB_BASE_RADIO_ID 0x00, 0xFC, 0xE1, 0xA8, 0xA8 |
This acts as base value for sensor nodeId addresses. Change this (or channel) if you have more than one sensor network.
Definition at line 557 of file MyConfig.h.
#define MY_NRF5_ESB_CHANNEL (76) |
Frequencies: 2400 Mhz - 2525 Mhz
Channels: 126
In some countries there might be limitations, in Germany for example only the range 2400,0 - 2483,5 Mhz is allowed.
Definition at line 533 of file MyConfig.h.
#define MY_NRF5_ESB_ENABLE_ENCRYPTION |
Definition at line 2340 of file MyConfig.h.
#define MY_NRF5_ESB_MODE (NRF5_250KBPS) |
nRF5 mode.
Definition at line 546 of file MyConfig.h.
#define MY_NRF5_ESB_PA_LEVEL (NRF5_PA_MAX) |
Definition at line 509 of file MyConfig.h.
#define MY_RADIO_NRF5_ESB |
Definition at line 2339 of file MyConfig.h.
