Collaboration diagram for RFM95:These options are specific to the RFM95 family of wireless transport modules.
| #define | MY_RADIO_RFM95 |
| Define this to use RFM95 based radios for sensor network communication. | |
| #define | MY_DEBUG_VERBOSE_RFM95 |
| Define this for verbose debug prints related to the RFM95 driver. | |
| #define | MY_RFM95_ENABLE_ENCRYPTION |
| Define this to enable software based AES encryption. More... | |
| #define | MY_RFM95_FREQUENCY (RFM95_868MHZ) |
| The frequency to use. More... | |
| #define | MY_RFM95_MODEM_CONFIGRUATION RFM95_BW125CR45SF128 |
| RFM95 modem configuration. More... | |
| #define | MY_RFM95_MODEM_CONFIGRUATION |
| #define | MY_RFM95_RST_PIN |
| Define this to use the RFM95 reset pin (optional). | |
| #define | MY_RFM95_POWER_PIN |
| Define this to use the RFM95 power pin (optional). | |
| #define | MY_RFM95_IRQ_PIN DEFAULT_RFM95_IRQ_PIN |
| Define this to use the RFM95 IRQ pin. | |
| #define | MY_RFM95_IRQ_NUM digitalPinToInterrupt(MY_RFM95_IRQ_PIN) |
| RFM95 IRQ number. | |
| #define | MY_RFM95_CS_PIN DEFAULT_RFM95_CS_PIN |
| RFM95 SPI chip select pin. | |
| #define | MY_RFM95_SPI_SPEED (4*1000000ul) |
| Set to overrule default RFM95 SPI speed. | |
| #define | MY_RFM95_TX_POWER_DBM (13u) |
| Set TX power level, default 13dBm (overridden if ATC mode enabled) More... | |
| #define | MY_RFM95_ATC_MODE_DISABLED |
| Define to disable ATC mode of RFM95 driver. | |
| #define | MY_RFM95_ATC_TARGET_RSSI (-70) |
| Target RSSI level (in dBm) for RFM95 ATC mode. | |
| #define | MY_RFM95_MAX_POWER_LEVEL_DBM |
| Set max TX power in dBm if local legislation requires this. More... | |
| #define | MY_RFM95_TCXO |
| Enable to force your radio to use an external frequency source (e.g. TCXO, if present). More... | |
| #define MY_RFM95_ENABLE_ENCRYPTION |
Definition at line 2359 of file MyConfig.h.
| #define MY_RFM95_FREQUENCY (RFM95_868MHZ) |
This must match the hardware version of the RFM95 radio. Additional information: https://en.wikipedia.org/wiki/Short_Range_Devices
Definition at line 855 of file MyConfig.h.
| #define MY_RFM95_MAX_POWER_LEVEL_DBM |
See here: https://en.wikipedia.org/wiki/Short_Range_Devices
Definition at line 2365 of file MyConfig.h.
| #define MY_RFM95_MODEM_CONFIGRUATION RFM95_BW125CR45SF128 |
BW = Bandwidth in kHz CR = Error correction code SF = Spreading factor, chips / symbol
| CONFIG | BW | CR | SF | Comment |
| RFM95_BW125CR45SF128 | 125 | 4/5 | 128 | Default, medium range |
| RFM95_BW500CR45SF128 | 500 | 4/5 | 128 | Fast, short range |
| RFM95_BW31_25CR48SF512 | 31.25 | 4/8 | 512 | Slow, long range |
| RFM95_BW125CR48SF4096 | 125 | 4/8 | 4096 | Slow, long range |
Definition at line 2362 of file MyConfig.h.
| #define MY_RFM95_MODEM_CONFIGRUATION |
| #define MY_RFM95_TCXO |
This allows for better stability using SF 9 to 12.
Definition at line 2364 of file MyConfig.h.
| #define MY_RFM95_TX_POWER_DBM (13u) |
See here https://en.wikipedia.org/wiki/Short_Range_Devices
Definition at line 929 of file MyConfig.h.
