Collaboration diagram for Tips for reducing memory footprint:Some settings are optional but add significantly to the memory footprint size.
By disabeling optional features that you don't need you can save memory which can be a valuable resource on cheaper hardware like the atmega328p. These options can be defined in your sketch to disable such features.
| #define | MY_DISABLE_RAM_ROUTING_TABLE_FEATURE |
| If defined, routing table will not be kept in RAM. More... | |
| #define | MY_SPLASH_SCREEN_DISABLED |
| If defined, will disable the MySensors splash screen. More... | |
| #define MY_DISABLE_RAM_ROUTING_TABLE_FEATURE |
Definition at line 2270 of file MyConfig.h.
| #define MY_SPLASH_SCREEN_DISABLED |
Definition at line 2238 of file MyConfig.h.
