These options are specific to the RS485 wired transport.
#define | MY_RS485 |
Define this to use the RS485 wired transport for sensor network communication. | |
#define | MY_RS485_BAUD_RATE (9600) |
The RS485 BAUD rate. | |
#define | MY_RS485_MAX_MESSAGE_LENGTH (40) |
The maximum message length used for RS485. | |
#define | MY_RS485_SOH_COUNT (1) |
Use this in case of collisions on the bus. 3 might be a good setting. | |
#define | MY_RS485_DE_PIN |
RS485 driver enable pin. | |
#define | MY_RS485_DE_INVERSE |
Define this if RS485 driver enable pin polarity is inverted (low-active). | |
#define | MY_RS485_HWSERIAL |
Define this if RS485 is connected to a hardware serial port. More... | |
#define MY_RS485_HWSERIAL |
Example:
Definition at line 2328 of file MyConfig.h.
