These options are specific to the RF24 family of wireless transport modules.
Vendor | Chip |
Nordic Semiconductor | nRF24L01 |
nRF24L01+ | |
Beken Corporation | BK2401 |
BK2421 | |
BK2491 | |
Hope Microelectronics | RFM70 |
RFM73 | |
Panchip Microelectronics | XN297 |
Silicon Labs(?) | SI24R1 |
#define | MY_RADIO_NRF24 |
Define this to use a RF24-based radio transport for sensor network communication. More... | |
#define | MY_RADIO_RF24 |
Define this to use a RF24-based radio transport for sensor network communication. | |
#define | MY_RF24_ENABLE_ENCRYPTION |
Define this to enable software based AES encryption. More... | |
#define | MY_DEBUG_VERBOSE_RF24 |
Define this for verbose debug prints related to the RF24 driver. | |
#define | MY_RF24_SPI_SPEED (2*1000000ul) |
Define this if you need to run the SPI clock at a different frequency than the default. More... | |
#define | MY_RF24_CE_PIN (DEFAULT_RF24_CE_PIN) |
Define this to change the chip enable pin from the default. | |
#define | MY_RF24_CS_PIN (DEFAULT_RF24_CS_PIN) |
Define this to change the chip select pin from the default. | |
#define | MY_RF24_IRQ_PIN |
Define this to use the IRQ pin of the RF24 module (optional). | |
#define | MY_RF24_POWER_PIN |
Define this to use the RF24 power pin (optional). | |
#define | MY_RX_MESSAGE_BUFFER_FEATURE |
This enables the receiving buffer feature. More... | |
#define | MY_RX_MESSAGE_BUFFER_SIZE |
Define this to change the incoming message buffer size from the default. More... | |
#define | MY_RF24_PA_LEVEL (RF24_PA_HIGH) |
Default RF24 PA level. Override in sketch if needed. More... | |
#define | MY_RF24_CHANNEL (76) |
RF channel for the sensor net, 0-125. More... | |
#define | MY_RF24_DATARATE (RF24_250KBPS) |
RF24 data rate. More... | |
#define | MY_RF24_BASE_RADIO_ID 0x00,0xFC,0xE1,0xA8,0xA8 |
RF24 radio network identifier. More... | |
#define | MY_RF24_ADDR_WIDTH (5) |
RF24 base address width. | |
#define MY_RADIO_NRF24 |
Definition at line 2331 of file MyConfig.h.
#define MY_RF24_BASE_RADIO_ID 0x00,0xFC,0xE1,0xA8,0xA8 |
This acts as base value for sensor nodeId addresses. Change this (or channel) if you have more than one sensor network.
Definition at line 446 of file MyConfig.h.
#define MY_RF24_CHANNEL (76) |
Frequencies: 2400 Mhz - 2525 Mhz
Channels: 126
In some countries there might be limitations, in Germany for example only the range 2400,0 - 2483,5 Mhz is allowed.
Definition at line 420 of file MyConfig.h.
#define MY_RF24_DATARATE (RF24_250KBPS) |
RF24 data rate.
Definition at line 435 of file MyConfig.h.
#define MY_RF24_ENABLE_ENCRYPTION |
Definition at line 2335 of file MyConfig.h.
#define MY_RF24_PA_LEVEL (RF24_PA_HIGH) |
Definition at line 396 of file MyConfig.h.
#define MY_RF24_SPI_SPEED (2*1000000ul) |
Default nRF24L01+ SPI speed, 2MHz should be safe for nRF24L01+ clones.
Definition at line 330 of file MyConfig.h.
#define MY_RX_MESSAGE_BUFFER_FEATURE |
This feature is currently not supported for anything but RF24. Require MY_RF24_IRQ_PIN to be set.
Note: Not supported on ESP8266, ESP32, STM32, nRF5 and sketches that use SoftSPI. See below issue for details https://github.com/mysensors/MySensors/issues/1128
Definition at line 2336 of file MyConfig.h.
#define MY_RX_MESSAGE_BUFFER_SIZE |
Require MY_RX_MESSAGE_BUFFER_FEATURE to be set.
Definition at line 2337 of file MyConfig.h.
