| E | SYS | SUB | Message | Comment |
|  | RF24 | INIT | PIN,CE=%d,CS=%d | Initialise RF24 radio, pin configuration: chip enable (CE), chip select (CS) |
| ! | RF24 | INIT | SANCHK FAIL | Sanity check failed, check wiring or replace module |
|  | RF24 | SPP | PCT=%d,TX LEVEL=%d | Set TX level, input TX percent (PCT) |
|  | RF24 | RBR | REG=%d,VAL=%d | Read register (REG), value=(VAL) |
|  | RF24 | WBR | REG=%d,VAL=%d | Write register (REG), value=(VAL) |
|  | RF24 | FRX |  | Flush RX buffer |
|  | RF24 | FTX |  | Flush TX buffer |
|  | RF24 | OWP | RCPT=%d | Open writing pipe, recipient=(RCPT) |
|  | RF24 | STL |  | Start listening |
|  | RF24 | SPL |  | Stop listening |
|  | RF24 | SLP |  | Set radio to sleep |
|  | RF24 | SBY |  | Set radio to standby |
|  | RF24 | TXM | TO=%d,LEN=%d | Transmit message to=(TO), length=(LEN) |
| ! | RF24 | TXM | MAX_RT | Max TX retries, no ACK received |
| ! | RF24 | GDP | PYL INV | Invalid payload size |
|  | RF24 | RXM | LEN=%d | Read message, length=(LEN) |
|  | RF24 | STX | LEVEL=%d | Set TX level, level=(LEVEL) |
| #define | RF24_SPI   hwSPI |
|  | default SPI
| #define | DEFAULT_RF24_CE_PIN   (9) |
|  | DEFAULT_RF24_CE_PIN.
| #define | DEFAULT_RF24_CS_PIN   (SS) |
|  | DEFAULT_RF24_CS_PIN.
| #define | LOCAL   static |
|  | static
| #define | RF24_SPI_DATA_ORDER   MSBFIRST |
|  | RF24_SPI_DATA_ORDER.
| #define | RF24_SPI_DATA_MODE   SPI_MODE0 |
|  | RF24_SPI_DATA_MODE.
| #define | RF24_BROADCAST_ADDRESS   (255u) |
|  | RF24_BROADCAST_ADDRESS.
| #define | RF24_CONFIGURATION   (uint8_t) (RF24_CRC_16 << 2) |
|  | RF24_CONFIGURATION.
| #define | RF24_FEATURE   (uint8_t)( _BV(RF24_EN_DPL)) |
|  | RF24_FEATURE.
| #define | RF24_RF_SETUP   (uint8_t)(( ((MY_RF24_DATARATE & 0b10 ) << 4) | ((MY_RF24_DATARATE & 0b01 ) << 3) | (MY_RF24_PA_LEVEL << 1) ) + 1) |
|  | RF24_RF_SETUP, +1 for Si24R1 and LNA.
| #define | RF24_POWERUP_DELAY_MS   (100u) |
|  | Power up delay, allow VCC to settle, transport to become fully operational.
| #define | RF24_BROADCAST_PIPE   (1u) |
|  | RF24_BROADCAST_PIPE.
| #define | RF24_NODE_PIPE   (0u) |
|  | RF24_NODE_PIPE.
| #define | RF24_readByteRegister(__reg)   RF24_RAW_readByteRegister(RF24_CMD_READ_REGISTER | (RF24_REGISTER_MASK & (__reg))) |
|  | RF24_readByteRegister.
| #define | RF24_writeByteRegister(__reg,  __value)   RF24_RAW_writeByteRegister(RF24_CMD_WRITE_REGISTER | (RF24_REGISTER_MASK & (__reg)), __value) |
|  | RF24_writeByteRegister.
| #define | RF24_writeMultiByteRegister(__reg,  __buf,  __len)   RF24_spiMultiByteTransfer(RF24_CMD_WRITE_REGISTER | (RF24_REGISTER_MASK & (__reg)),(uint8_t *)__buf, __len,false) |
|  | RF24_writeMultiByteRegister.
| LOCAL void | RF24_csn (const bool level) |
|  | RF24_csn.  More...
| LOCAL void | RF24_ce (const bool level) |
|  | RF24_ce.  More...
| LOCAL uint8_t | RF24_spiMultiByteTransfer (const uint8_t cmd, uint8_t *buf, const uint8_t len, const bool readMode) |
|  | RF24_spiMultiByteTransfer.  More...
| LOCAL uint8_t | RF24_spiByteTransfer (const uint8_t cmd) |
|  | RF24_spiByteTransfer.  More...
| LOCAL uint8_t | RF24_RAW_readByteRegister (const uint8_t cmd) |
|  | RF24_RAW_readByteRegister.  More...
| LOCAL uint8_t | RF24_RAW_writeByteRegister (const uint8_t cmd, const uint8_t value) |
|  | RF24_RAW_writeByteRegister.  More...
| LOCAL void | RF24_flushRX (void) |
|  | RF24_flushRX.
| LOCAL void | RF24_flushTX (void) |
|  | RF24_flushTX.
| LOCAL uint8_t | RF24_getStatus (void) |
|  | RF24_getStatus.  More...
| LOCAL uint8_t | RF24_getFIFOStatus (void) __attribute__((unused)) |
|  | RF24_getFIFOStatus.  More...
| LOCAL void | RF24_openWritingPipe (const uint8_t recipient) |
|  | RF24_openWritingPipe.  More...
| LOCAL void | RF24_startListening (void) |
|  | RF24_startListening.
| LOCAL void | RF24_stopListening (void) |
|  | RF24_stopListening.
| LOCAL void | RF24_sleep (void) |
|  | RF24_sleep.
| LOCAL void | RF24_standBy (void) |
|  | RF24_standBy.
| LOCAL void | RF24_powerDown (void) |
|  | RF24_powerDown.
| LOCAL void | RF24_powerUp (void) |
|  | RF24_powerUp.
| LOCAL bool | RF24_sendMessage (const uint8_t recipient, const void *buf, const uint8_t len, const bool noACK=false) |
|  | RF24_sendMessage.  More...
| LOCAL uint8_t | RF24_getDynamicPayloadSize (void) |
|  | RF24_getDynamicPayloadSize.  More...
| LOCAL bool | RF24_isDataAvailable (void) |
|  | RF24_isDataAvailable.  More...
| LOCAL uint8_t | RF24_readMessage (void *buf) |
|  | RF24_readMessage.  More...
| LOCAL void | RF24_setNodeAddress (const uint8_t address) |
|  | RF24_setNodeAddress.  More...
| LOCAL uint8_t | RF24_getNodeID (void) |
|  | RF24_getNodeID.  More...
| LOCAL bool | RF24_sanityCheck (void) |
|  | RF24_sanityCheck.  More...
| LOCAL bool | RF24_initialize (void) |
|  | RF24_initialize.  More...
| LOCAL void | RF24_setChannel (const uint8_t channel) |
|  | RF24_setChannel.  More...
| LOCAL void | RF24_setRetries (const uint8_t retransmitDelay, const uint8_t retransmitCount) |
|  | RF24_setRetries.  More...
| LOCAL void | RF24_setAddressWidth (const uint8_t addressWidth) |
|  | RF24_setAddressWidth.  More...
| LOCAL void | RF24_setRFSetup (const uint8_t RFsetup) |
|  | RF24_setRFSetup.  More...
| LOCAL void | RF24_setFeature (const uint8_t feature) |
|  | RF24_setFeature.  More...
| LOCAL uint8_t | RF24_getFeature (void) |
|  | RF24_getFeature.  More...
| LOCAL void | RF24_setPipe (const uint8_t pipe) |
|  | RF24_setPipe.  More...
| LOCAL void | RF24_setAutoACK (const uint8_t pipe) |
|  | RF24_setAutoACK.  More...
| LOCAL void | RF24_setDynamicPayload (const uint8_t pipe) |
|  | RF24_setDynamicPayload.  More...
| LOCAL void | RF24_setRFConfiguration (const uint8_t configuration) |
|  | RF24_setRFConfiguration.  More...
| LOCAL void | RF24_setPipeAddress (const uint8_t pipe, uint8_t *address, const uint8_t addressWidth) |
|  | RF24_setPipeAddress.  More...
| LOCAL void | RF24_setPipeLSB (const uint8_t pipe, const uint8_t LSB) |
|  | RF24_setPipeLSB.  More...
| LOCAL uint8_t | RF24_getObserveTX (void) |
|  | RF24_getObserveTX.  More...
| LOCAL uint8_t | RF24_setStatus (const uint8_t status) |
|  | RF24_setStatus.  More...
| LOCAL void | RF24_enableFeatures (void) |
|  | RF24_enableFeatures.
| LOCAL uint8_t | RF24_getTxPowerPercent (void) |
|  | RF24_getTxPowerPercent.  More...
| LOCAL int16_t | RF24_getTxPowerLevel (void) |
|  | RF24_getTxPowerLevel.  More...
| LOCAL bool | RF24_setTxPowerPercent (const uint8_t newPowerPercent) |
|  | RF24_setTxPowerPercent.  More...
| LOCAL int16_t | RF24_getSendingRSSI (void) |
|  | RF24_getSendingRSSI.  More...
| LOCAL void | RF24_enableConstantCarrierWave (void) __attribute__((unused)) |
|  | Generate a constant carrier wave at active channel & transmit power (for testing only).
| LOCAL void | RF24_disableConstantCarrierWave (void) __attribute__((unused)) |
|  | Stop generating a constant carrier wave (for testing only).
| LOCAL bool | RF24_getReceivedPowerDetector (void) __attribute__((unused)) |
|  | Retrieve latched RPD power level, in receive mode (for testing, nRF24L01+ only).  More...
