API declaration for MyGatewayTransport.
Gateway transport-related log messages, format: [!]SYSTEM:[SUB SYSTEM:]MESSAGE
- [!] Exclamation mark is prepended in case of error
- SYSTEM:
- GWT: messages emitted by MyGatewayTransport
- SUB SYSTEMS:
Gateway transport debug log messages :
| E | SYS | SUB | Message | Comment |
| GWT | TIN | CONNECTING... | Connecting to router |
| GWT | TIN | IP=%s | IP address [%s] obtained |
| ! | GWT | TIN | DHCP FAIL | DHCP request failed |
| GWT | TIN | ETH OK | Connected to network |
| ! | GWT | TIN | ETH FAIL | Connection failed |
| GWT | TPS | TOPIC=%s,MSG SENT | MQTT message sent on topic [%s] |
| GWT | TPS | ETH OK | Connected to network |
| ! | GWT | TPS | ETH FAIL | Connection failed |
| GWT | IMQ | TOPIC=%s,MSG RECEIVE | MQTT message received on topic [%s] |
| GWT | RMQ | CONNECTING... | Connecting to MQTT broker |
| GWT | RMQ | OK | Connected to MQTT broker |
| ! | GWT | RMQ | FAIL | Connection to MQTT broker failed |
| GWT | TPC | CONNECTING... | Obtaining IP address |
| GWT | TPC | IP=%s | IP address [%s] obtained |
| ! | GWT | TPC | DHCP FAIL | DHCP request failed |
| GWT | RFC | C=%d,MSG=%s | Received message [%s] from client [%d] |
| ! | GWT | RFC | C=%d,MSG TOO LONG | Received message from client [%d] too long |
| GWT | TSA | UDP MSG=%s | Received UDP message [%s] |
| GWT | TSA | ETH OK | Connected to network |
| ! | GWT | TSA | ETH FAIL | Connection failed |
| GWT | TSA | C=d,DISCONNECTED | Client [%d] disconnected |
| GWT | TSA | C=d,CONNECTED | Client [%d] connected |
| ! | GWT | TSA | NO FREE SLOT | No free slot for client |
| ! | GWT | TRC | IP RENEW FAIL | IP renewal failed |
◆ gatewayTransportAvailable()
| bool gatewayTransportAvailable |
void |
Check if a new message is available from controller.
- Returns
- true if message available
◆ gatewayTransportInit()
| bool gatewayTransportInit |
void |
Initialize gateway transport driver.
- Returns
- true if transport initialized
◆ gatewayTransportReceive()
Pick up last message received from controller.
- Returns
- message
◆ gatewayTransportSend()
| bool gatewayTransportSend |
MyMessage & |
message | ) |
Send message to controller.
- Parameters
- Returns
- true if message delivered
