40 #define MY_REPEATER_FEATURE
44 #define RELAY_PIN 4 // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
45 #define NUMBER_OF_RELAYS 1 // Total number of attached relays
46 #define RELAY_ON 1 // GPIO value to write to turn on attached relay
47 #define RELAY_OFF 0 // GPIO value to write to turn off attached relay
85 if (message.
getType()==V_STATUS) {
87 digitalWrite(message.
getSensor()-1+RELAY_PIN, message.
getBool()?RELAY_ON:RELAY_OFF);
91 Serial.print(
"Incoming change for sensor:");
93 Serial.print(
", New status: ");
94 Serial.println(message.
getBool());
uint8_t getSensor(void) const
Get sensor ID of message.
uint8_t sensor
void before()
Called before node initialises.
uint8_t getType(void) const
Get message type.
bool getBool(void) const
Get bool payload.
