These functions allow you to control the GPIO interface. You can set the function of each GPIO pin, read the input state and set the output state.
◆ bcm2835_delay()
void bcm2835_delay |
unsigned int |
millis | ) |
Delays for the specified number of milliseconds. Uses nanosleep(), and therefore does not use CPU until the time is up. However, you are at the mercy of nanosleep(). From the manual for nanosleep(): If the interval specified in req is not an exact multiple of the granularity underlying clock (see time(7)), then the interval will be rounded up to the next multiple. Furthermore, after the sleep completes, there may still be a delay before the CPU becomes free to once again execute the calling thread.
- Parameters
[in] | millis | Delay in milliseconds |
◆ bcm2835_delayMicroseconds()
void bcm2835_delayMicroseconds |
uint64_t |
micros | ) |
Delays for the specified number of microseconds. Uses a combination of nanosleep() and a busy wait loop on the BCM2835 system timers, However, you are at the mercy of nanosleep(). From the manual for nanosleep(): If the interval specified in req is not an exact multiple of the granularity underlying clock (see time(7)), then the interval will be rounded up to the next multiple. Furthermore, after the sleep completes, there may still be a delay before the CPU becomes free to once again execute the calling thread. For times less than about 450 microseconds, uses a busy wait on the System Timer. It is reported that a delay of 0 microseconds on RaspberryPi will in fact result in a delay of about 80 microseconds. Your mileage may vary.
- Parameters
[in] | micros | Delay in microseconds |
◆ bcm2835_gpio_afen()
void bcm2835_gpio_afen |
uint8_t |
pin | ) |
Enable Asynchronous Falling Edge Detect Enable for the specified pin. When a falling edge is detected, sets the appropriate pin in Event Detect Status. Asynchronous means the incoming signal is not sampled by the system clock. As such falling edges of very short duration can be detected.
- Parameters
[in] | pin | GPIO number, or one of RPI_GPIO_P1_* from RPiGPIOPin. |
◆ bcm2835_gpio_aren()
void bcm2835_gpio_aren |
uint8_t |
pin | ) |
Enable Asynchronous Rising Edge Detect Enable for the specified pin. When a rising edge is detected, sets the appropriate pin in Event Detect Status. Asynchronous means the incoming signal is not sampled by the system clock. As such rising edges of very short duration can be detected.
- Parameters
◆ bcm2835_gpio_clr()
void bcm2835_gpio_clr |
uint8_t |
pin | ) |
◆ bcm2835_gpio_clr_afen()
void bcm2835_gpio_clr_afen |
uint8_t |
pin | ) |
Disable Asynchronous Falling Edge Detect Enable for the specified pin.
- Parameters
◆ bcm2835_gpio_clr_aren()
void bcm2835_gpio_clr_aren |
uint8_t |
pin | ) |
Disable Asynchronous Rising Edge Detect Enable for the specified pin.
- Parameters
◆ bcm2835_gpio_clr_fen()
void bcm2835_gpio_clr_fen |
uint8_t |
pin | ) |
Disable Falling Edge Detect Enable for the specified pin.
- Parameters
◆ bcm2835_gpio_clr_hen()
void bcm2835_gpio_clr_hen |
uint8_t |
pin | ) |
Disable High Detect Enable for the specified pin.
- Parameters
◆ bcm2835_gpio_clr_len()
void bcm2835_gpio_clr_len |
uint8_t |
pin | ) |
Disable Low Detect Enable for the specified pin.
- Parameters
◆ bcm2835_gpio_clr_multi()
void bcm2835_gpio_clr_multi |
uint32_t |
mask | ) |
Sets any of the first 32 GPIO output pins specified in the mask to LOW.
- Parameters
[in] | mask | Mask of pins to affect. Use eg: (1 << RPI_GPIO_P1_03) | (1 << RPI_GPIO_P1_05) |
- See also
- bcm2835_gpio_write_multi()
◆ bcm2835_gpio_clr_ren()
void bcm2835_gpio_clr_ren |
uint8_t |
pin | ) |
Disable Rising Edge Detect Enable for the specified pin.
- Parameters
◆ bcm2835_gpio_eds()
uint8_t bcm2835_gpio_eds |
uint8_t |
pin | ) |
◆ bcm2835_gpio_eds_multi()
uint32_t bcm2835_gpio_eds_multi |
uint32_t |
mask | ) |
Same as bcm2835_gpio_eds() but checks if any of the pins specified in the mask have detected a level or edge.
- Parameters
[in] | mask | Mask of pins to check. Use eg: (1 << RPI_GPIO_P1_03) | (1 << RPI_GPIO_P1_05) |
- Returns
- Mask of pins HIGH if the event detect status for the given pin is true.
◆ bcm2835_gpio_fen()
void bcm2835_gpio_fen |
uint8_t |
pin | ) |
Enable Falling Edge Detect Enable for the specified pin. When a falling edge is detected, sets the appropriate pin in Event Detect Status. The GPRENn registers use synchronous edge detection. This means the input signal is sampled using the system clock and then it is looking for a ?100? pattern on the sampled signal. This has the effect of suppressing glitches.
- Parameters
◆ bcm2835_gpio_fsel()
void bcm2835_gpio_fsel |
uint8_t |
pin, |
uint8_t |
mode |
Sets the Function Select register for the given pin, which configures the pin as Input, Output or one of the 6 alternate functions.
- Parameters
◆ bcm2835_gpio_get_pud()
uint8_t bcm2835_gpio_get_pud |
uint8_t |
pin | ) |
On the BCM2711 based RPI 4, gets the current Pull-up/down mode for the specified pin. Returns one of BCM2835_GPIO_PUD_* from bcm2835PUDControl. On earlier RPI versions not based on the BCM2711, returns BCM2835_GPIO_PUD_ERROR
- Parameters
◆ bcm2835_gpio_hen()
void bcm2835_gpio_hen |
uint8_t |
pin | ) |
Enable High Detect Enable for the specified pin. When a HIGH level is detected on the pin, sets the appropriate pin in Event Detect Status.
- Parameters
◆ bcm2835_gpio_len()
void bcm2835_gpio_len |
uint8_t |
pin | ) |
Enable Low Detect Enable for the specified pin. When a LOW level is detected on the pin, sets the appropriate pin in Event Detect Status.
- Parameters
◆ bcm2835_gpio_lev()
uint8_t bcm2835_gpio_lev |
uint8_t |
pin | ) |
Reads the current level on the specified pin and returns either HIGH or LOW. Works whether or not the pin is an input or an output.
- Parameters
- Returns
- the current level either HIGH or LOW
◆ bcm2835_gpio_pad()
uint32_t bcm2835_gpio_pad |
uint8_t |
group | ) |
Reads and returns the Pad Control for the given GPIO group. Caution: requires root access.
- Parameters
[in] | group | The GPIO pad group number, one of BCM2835_PAD_GROUP_GPIO_* |
- Returns
- Mask of bits from BCM2835_PAD_* from bcm2835PadGroup
◆ bcm2835_gpio_pud()
void bcm2835_gpio_pud |
uint8_t |
pud | ) |
◆ bcm2835_gpio_pudclk()
void bcm2835_gpio_pudclk |
uint8_t |
pin, |
uint8_t |
on |
◆ bcm2835_gpio_ren()
void bcm2835_gpio_ren |
uint8_t |
pin | ) |
Enable Rising Edge Detect Enable for the specified pin. When a rising edge is detected, sets the appropriate pin in Event Detect Status. The GPRENn registers use synchronous edge detection. This means the input signal is sampled using the system clock and then it is looking for a ?011? pattern on the sampled signal. This has the effect of suppressing glitches.
- Parameters
◆ bcm2835_gpio_set()
void bcm2835_gpio_set |
uint8_t |
pin | ) |
◆ bcm2835_gpio_set_eds()
void bcm2835_gpio_set_eds |
uint8_t |
pin | ) |
Sets the Event Detect Status register for a given pin to 1, which has the effect of clearing the flag. Use this afer seeing an Event Detect Status on the pin.
- Parameters
◆ bcm2835_gpio_set_eds_multi()
void bcm2835_gpio_set_eds_multi |
uint32_t |
mask | ) |
Same as bcm2835_gpio_set_eds() but clears the flag for any pin which is set in the mask.
- Parameters
[in] | mask | Mask of pins to clear. Use eg: (1 << RPI_GPIO_P1_03) | (1 << RPI_GPIO_P1_05) |
◆ bcm2835_gpio_set_multi()
void bcm2835_gpio_set_multi |
uint32_t |
mask | ) |
Sets any of the first 32 GPIO output pins specified in the mask to HIGH.
- Parameters
- See also
◆ bcm2835_gpio_set_pad()
void bcm2835_gpio_set_pad |
uint8_t |
group, |
uint32_t |
control |
Sets the Pad Control for the given GPIO group. Caution: requires root access.
- Parameters
[in] | control | Mask of bits from BCM2835_PAD_* from bcm2835PadGroup. Note that it is not necessary to include BCM2835_PAD_PASSWRD in the mask as this is automatically included. |
◆ bcm2835_gpio_set_pud()
void bcm2835_gpio_set_pud |
uint8_t |
pin, |
uint8_t |
pud |
Sets the Pull-up/down mode for the specified pin. This is more convenient than clocking the mode in with bcm2835_gpio_pud() and bcm2835_gpio_pudclk().
- Parameters
[in] | pud | The desired Pull-up/down mode. One of BCM2835_GPIO_PUD_* from bcm2835PUDControl |
◆ bcm2835_gpio_write()
void bcm2835_gpio_write |
uint8_t |
pin, |
uint8_t |
on |
Sets the output state of the specified pin
- Parameters
[in] | on | HIGH sets the output to HIGH and LOW to LOW. |
◆ bcm2835_gpio_write_mask()
void bcm2835_gpio_write_mask |
uint32_t |
value, |
uint32_t |
mask |
Sets the first 32 GPIO output pins specified in the mask to the value given by value
- Parameters
[in] | value | values required for each bit masked in by mask, eg: (1 << RPI_GPIO_P1_03) | (1 << RPI_GPIO_P1_05) |
◆ bcm2835_gpio_write_multi()
void bcm2835_gpio_write_multi |
uint32_t |
mask, |
uint8_t |
on |
Sets any of the first 32 GPIO output pins specified in the mask to the state given by on
- Parameters
