BinarySwitchSleepSensor.ino
21  * DESCRIPTION
22  *
23  * Interrupt driven binary switch example with dual interrupts
24  * Author: Patrick 'Anticimex' Fallberg
25  * Connect one button or door/window reed switch between
26  * digital I/O pin 3 (BUTTON_PIN below) and GND and the other
27  * one in similar fashion on digital I/O pin 2.
28  * This example is designed to fit Arduino Nano/Pro Mini
29  *
30  */
33 // Enable debug prints to serial monitor
34 #define MY_DEBUG
36 // Enable and select radio type attached
37 #define MY_RADIO_RF24
38 //#define MY_RADIO_NRF5_ESB
39 //#define MY_RADIO_RFM69
40 //#define MY_RADIO_RFM95
41 //#define MY_PJON
43 #include <MySensors.h>
45 #define SKETCH_NAME "Binary Sensor"
46 #define SKETCH_MAJOR_VER "1"
47 #define SKETCH_MINOR_VER "0"
49 #define PRIMARY_CHILD_ID 3
50 #define SECONDARY_CHILD_ID 4
52 #define PRIMARY_BUTTON_PIN 2 // Arduino Digital I/O pin for button/reed switch
53 #define SECONDARY_BUTTON_PIN 3 // Arduino Digital I/O pin for button/reed switch
55 #if (PRIMARY_BUTTON_PIN < 2 || PRIMARY_BUTTON_PIN > 3)
56 #error PRIMARY_BUTTON_PIN must be either 2 or 3 for interrupts to work
57 #endif
58 #if (SECONDARY_BUTTON_PIN < 2 || SECONDARY_BUTTON_PIN > 3)
59 #error SECONDARY_BUTTON_PIN must be either 2 or 3 for interrupts to work
60 #endif
61 #if (PRIMARY_BUTTON_PIN == SECONDARY_BUTTON_PIN)
62 #error PRIMARY_BUTTON_PIN and BUTTON_PIN2 cannot be the same
63 #endif
64 #if (PRIMARY_CHILD_ID == SECONDARY_CHILD_ID)
65 #error PRIMARY_CHILD_ID and SECONDARY_CHILD_ID cannot be the same
66 #endif
69 // Change to V_LIGHT if you use S_LIGHT in presentation below
70 MyMessage msg(PRIMARY_CHILD_ID, V_TRIPPED);
71 MyMessage msg2(SECONDARY_CHILD_ID, V_TRIPPED);
73 void setup()
74 {
75  // Setup the buttons
76  pinMode(PRIMARY_BUTTON_PIN, INPUT_PULLUP);
77  pinMode(SECONDARY_BUTTON_PIN, INPUT_PULLUP);
78 }
81 {
82  // Send the sketch version information to the gateway and Controller
83  sendSketchInfo(SKETCH_NAME, SKETCH_MAJOR_VER "." SKETCH_MINOR_VER);
85  // Register binary input sensor to sensor_node (they will be created as child devices)
86  // You can use S_DOOR, S_MOTION or S_LIGHT here depending on your usage.
87  // If S_LIGHT is used, remember to update variable type you send in. See "msg" above.
88  present(PRIMARY_CHILD_ID, S_DOOR);
89  present(SECONDARY_CHILD_ID, S_DOOR);
90 }
92 // Loop will iterate on changes on the BUTTON_PINs
93 void loop()
94 {
95  uint8_t value;
96  static uint8_t sentValue=2;
97  static uint8_t sentValue2=2;
99  // Short delay to allow buttons to properly settle
100  sleep(5);
102  value = digitalRead(PRIMARY_BUTTON_PIN);
104  if (value != sentValue) {
105  // Value has changed from last transmission, send the updated value
106  send(msg.set(value==HIGH));
107  sentValue = value;
108  }
110  value = digitalRead(SECONDARY_BUTTON_PIN);
112  if (value != sentValue2) {
113  // Value has changed from last transmission, send the updated value
114  send(msg2.set(value==HIGH));
115  sentValue2 = value;
116  }
118  // Sleep until something happens with the sensor
119  sleep(PRIMARY_BUTTON_PIN-2, CHANGE, SECONDARY_BUTTON_PIN-2, CHANGE, 0);
120 }
HIGH
#define HIGH
Definition: bcm2835.h:572
Definition: BinarySwitchSleepSensor.ino:93
Definition: BinarySwitchSleepSensor.ino:80
MyMessage::set
send
present
Definition: BinarySwitchSleepSensor.ino:73
sleep
Definition: MyMessage.h:291
