MySensors Library & Examples  2.3.2-87-gb8f8b6e2
CO2Sensor.ino
21  * DESCRIPTION
22  *
23  * MH-Z14 CO2 sensor
24  *
25  * Wiring:
26  * Pad 1, Pad 5: Vin (Voltage input 4.5V-6V)
27  * Pad 2, Pad 3, Pad 12: GND
28  * Pad 6: PWM output ==> pin 6
29  *
30  * From: http://davidegironi.blogspot.fr/2014/01/co2-meter-using-ndir-infrared-mh-z14.html
31  * MH-Z14 has a PWM output, with a sensitivity range of 0ppm to 2000ppm CO2, an accuracy of ±200ppm.
32  * The cycle is 1004ms±5%, given the duty cicle Th (pulse high), Tl is 1004-Th, we can convert it to CO2 value using the formula:
33  * CO2ppm = 2000 * (Th - 2ms) /(Th + Tl - 4ms)
34  * From: http://airqualityegg.wikispaces.com/Sensor+Tests
35  * - response time is less than 30 s
36  * - 3 minute warm up time
37  * datasheet: http://www.futurlec.com/Datasheet/Sensor/MH-Z14.pdf
38  * Contributor: epierre
39  */
41 // Enable debug prints to serial monitor
42 #define MY_DEBUG
44 // Enable and select radio type attached
45 #define MY_RADIO_RF24
46 //#define MY_RADIO_NRF5_ESB
47 //#define MY_RADIO_RFM69
48 //#define MY_RADIO_RFM95
49 //#define MY_PJON
51 #include <MySensors.h>
53 #define CHILD_ID_AIQ 0
54 #define AIQ_SENSOR_ANALOG_PIN 6
56 uint32_t SLEEP_TIME = 30*1000; // Sleep time between reads (in milliseconds)
58 float valAIQ =0.0;
59 float lastAIQ =0.0;
61 MyMessage msg(CHILD_ID_AIQ, V_LEVEL);
62 MyMessage msg2(CHILD_ID_AIQ, V_UNIT_PREFIX);
64 void setup()
65 {
66  pinMode(AIQ_SENSOR_ANALOG_PIN, INPUT);
67 }
70 {
71  // Send the sketch version information to the gateway and Controller
72  sendSketchInfo("AIQ Sensor CO2 MH-Z14", "1.0");
74  // Register all sensors to gateway (they will be created as child devices)
75  present(CHILD_ID_AIQ, S_AIR_QUALITY);
76  send(msg2.set("ppm"));
77 }
79 void loop()
80 {
82  //uint32_t duration = pulseIn(AIQ_SENSOR_ANALOG_PIN, HIGH);
83  while(digitalRead(AIQ_SENSOR_ANALOG_PIN) == HIGH) {
84  ;
85  }
86  //wait for the pin to go HIGH and measure HIGH time
87  uint32_t duration = pulseIn(AIQ_SENSOR_ANALOG_PIN, HIGH);
89  //Serial.print(duration/1000); Serial.println(" ms ");
90  //from datasheet
91  //CO2 ppm = 2000 * (Th - 2ms) / (Th + Tl - 4ms)
92  // given Tl + Th = 1004
93  // Tl = 1004 - Th
94  // = 2000 * (Th - 2ms) / (Th + 1004 - Th -4ms)
95  // = 2000 * (Th - 2ms) / 1000 = 2 * (Th - 2ms)
96  long co2ppm = 2 * ((duration/1000) - 2);
97  //Serial.print(co2ppm);
98  if ((co2ppm != lastAIQ)&&(abs(co2ppm-lastAIQ)>=10)) {
99  send(msg.set((int32_t)ceil(co2ppm)));
100  lastAIQ = ceil(co2ppm);
101  }
103  //Serial.println();
105  // Power down the radio. Note that the radio will get powered back up
106  // on the next write() call.
107  sleep(SLEEP_TIME); //sleep for: sleepTime
108 }
HIGH
#define HIGH
Definition: bcm2835.h:572
Definition: CO2Sensor.ino:79
Definition: CO2Sensor.ino:69
MyMessage::set
send
present
Definition: CO2Sensor.ino:64
sleep
Definition: MyMessage.h:291
