LogOTANode.ino
21  * DESCRIPTION
22  *
23  * Example for sending debug messages over the air (OTA).
24  *
25  */
27 // Enable debug
28 #define MY_DEBUG
30 // Enable OTA debugging to Node 0
31 #define MY_DEBUG_OTA (0)
33 // Allow sending logs without MY_DEBUG_OTA enabled
34 #define MY_OTA_LOG_SENDER_FEATURE
36 // Disable echoing of debug messages
37 //#define MY_DEBUG_OTA_DISABLE_ECHO
39 // Enable and select radio type attached
40 #define MY_RADIO_RF24
41 //#define MY_RADIO_NRF5_ESB
42 //#define MY_RADIO_RFM69
43 //#define MY_RADIO_RFM95
45 #include <MySensors.h>
47 void setup()
48 {
49 }
52 {
53  // Send the sketch version information to the gateway and Controller
54  sendSketchInfo("DebugSensor", "1.0");
55 }
57 // Arduino loop
58 int c=0;
59 void loop()
60 {
61  // Wait some time
62  if (sleep(3000)==MY_SLEEP_NOT_POSSIBLE) {
63  delay(3000);
64  }
66  // Count loops
67  c++;
69  // A debug message
70  DEBUG_OUTPUT(PSTR("DEBUG\nc=%" PRId16 "\nmillis=%" PRId32 "\n"), c, hwMillis());
72  // Send a log message to a node, requesting that the message is echoed back to this node
73  OTALog(0, true, PSTR("LOG\nc=%" PRId16 "\nmillis=%" PRId32 "\n"), c, hwMillis());
74 }
Definition: LogOTANode.ino:59
OTALog
void OTALog(uint8_t logNode, bool echo, const char *fmt,...)
Send a log message to a node.
DEBUG_OUTPUT
#define DEBUG_OUTPUT(x,...)
debug NULL
Definition: MyConfig.h:2707
Definition: LogOTANode.ino:51
Definition: LogOTANode.ino:47
sleep
#define MY_SLEEP_NOT_POSSIBLE
Sleeping not possible.
Definition: MySensorsCore.h:83
