MotionSensor.ino
21  * REVISION HISTORY
22  * Version 1.0 - Henrik Ekblad
23  *
24  * DESCRIPTION
25  * Motion Sensor example using HC-SR501
26  * http://www.mysensors.org/build/motion
27  *
28  */
30 // Enable debug prints
31 // #define MY_DEBUG
33 // Enable and select radio type attached
34 #define MY_RADIO_RF24
35 //#define MY_RADIO_NRF5_ESB
36 //#define MY_RADIO_RFM69
37 //#define MY_RADIO_RFM95
38 //#define MY_PJON
40 #include <MySensors.h>
42 uint32_t SLEEP_TIME = 120000; // Sleep time between reports (in milliseconds)
43 #define DIGITAL_INPUT_SENSOR 3 // The digital input you attached your motion sensor. (Only 2 and 3 generates interrupt!)
44 #define CHILD_ID 1 // Id of the sensor child
46 // Initialize motion message
47 MyMessage msg(CHILD_ID, V_TRIPPED);
49 void setup()
50 {
51  pinMode(DIGITAL_INPUT_SENSOR, INPUT); // sets the motion sensor digital pin as input
52 }
55 {
56  // Send the sketch version information to the gateway and Controller
57  sendSketchInfo("Motion Sensor", "1.0");
59  // Register all sensors to gw (they will be created as child devices)
60  present(CHILD_ID, S_MOTION);
61 }
63 void loop()
64 {
65  // Read digital motion value
66  bool tripped = digitalRead(DIGITAL_INPUT_SENSOR) == HIGH;
68  Serial.println(tripped);
69  send(msg.set(tripped?"1":"0")); // Send tripped value to gw
71  // Sleep until interrupt comes in on motion sensor. Send update every two minute.
72  sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), CHANGE, SLEEP_TIME);
73 }
HIGH
#define HIGH
Definition: bcm2835.h:572
Definition: MotionSensor.ino:63
Definition: MotionSensor.ino:54
MyMessage::set
send
present
Definition: MotionSensor.ino:49
sleep
Definition: MyMessage.h:303
