Classes | Macros | Typedefs | Enumerations | Functions
RFM69_new.h File Reference
#include "RFM69registers_new.h"
+ Include dependency graph for RFM69_new.h:
Classes
struct  __attribute__
 FW config structure, stored in eeprom. More...
struct  rfm69_internal_t
 RFM69 internal variables. More...
#define RFM69_SPI   hwSPI
 default SPI
#define DEFAULT_RFM69_IRQ_PIN   (2)
 DEFAULT_RFM69_IRQ_PIN.
#define DEFAULT_RFM69_CS_PIN   (SS)
 DEFAULT_RFM69_CS_PIN.
#define RFM69_SPI_DATA_ORDER   MSBFIRST
 SPI data order.
#define RFM69_SPI_DATA_MODE   SPI_MODE0
 SPI mode.
#define RFM69_SYNCVALUE1   (0x2D)
 Make this compatible with sync1 byte of RFM12B lib.
#define RFM69_VERSION_HW
 HW version.
#define RFM69_MIN_POWER_LEVEL_DBM   ((rfm69_powerlevel_t)-2)
 min. power level, -2dBm
#define RFM69_MAX_POWER_LEVEL_DBM   ((rfm69_powerlevel_t)20)
 max. power level, +20dBm
#define RFM69_FIFO_SIZE   (0xFFu)
 Max number of bytes the Rx/Tx FIFO can hold.
#define RFM69_MAX_PACKET_LEN   static_cast<size_t>(0x40u)
 This is the maximum number of bytes that can be carried.
#define RFM69_ATC_TARGET_RANGE_DBM   (2u)
 ATC target range +/- dBm.
#define RFM69_PACKET_HEADER_VERSION   (1u)
 RFM69 packet header version.
#define RFM69_MIN_PACKET_HEADER_VERSION   (1u)
 Minimal RFM69 packet header version.
#define RFM69_RETRIES   (5u)
 Retries in case of failed transmission.
#define RFM69_RETRY_TIMEOUT_MS   (200ul)
 Timeout for ACK, adjustments needed if modem configuration changed (air time different)
#define RFM69_MODE_READY_TIMEOUT_MS   (50ul)
 Timeout for mode ready.
#define RFM69_ACK_REQUESTED   (7u)
 RFM69 header, controlFlag, bit 7.
#define RFM69_ACK_RECEIVED   (6u)
 RFM69 header, controlFlag, bit 6.
#define RFM69_ACK_RSSI_REPORT   (5u)
 RFM69 header, controlFlag, bit 5.
#define RFM69_BROADCAST_ADDRESS   (255u)
 Broadcasting address.
#define RFM69_TARGET_RSSI_DBM   (-75)
 RSSI target.
#define RFM69_HIGH_POWER_DBM   (18u)
 High power threshold, dBm.
#define MY_RFM69_TX_TIMEOUT_MS   (2*1000ul)
 Timeout for packet sent.
#define MY_RFM69_CSMA_LIMIT_DBM   (-95)
 upper RX signal sensitivity threshold in dBm for carrier sense access
#define MY_RFM69_CSMA_TIMEOUT_MS   (500ul)
 CSMA timeout.
#define RFM69_POWERUP_DELAY_MS   (100ul)
 Power up delay, allow VCC to settle, transport to become fully operational.
#define RFM69_315MHZ   (315000000ul)
 RFM69_315MHZ.
#define RFM69_433MHZ   (433920000ul)
 RFM69_433MHZ, center frequency 433.92 MHz.
#define RFM69_865MHZ   (865500000ul)
 RFM69_865MHZ, center frequency 865.5 MHz.
#define RFM69_868MHZ   (868000000ul)
 RFM69_868MHZ.
#define RFM69_915MHZ   (915000000ul)
 RFM69_915MHZ.
#define RFM69_COURSE_TEMP_COEF   (-90)
 puts the temperature reading in the ballpark, user can fine tune the returned value
#define RFM69_FXOSC   (32*1000000ul)
 OSC freq, 32MHz.
#define RFM69_FSTEP   (RFM69_FXOSC / 524288.0f)
 FXOSC / 2^19 = 32MHz / 2^19 (p13 in datasheet)
#define RFM69_getACKRequested(__value)   ((bool)bitRead(__value,RFM69_ACK_REQUESTED))
 getACKRequested
#define RFM69_setACKRequested(__value, __flag)   bitWrite(__value,RFM69_ACK_REQUESTED,__flag)
 setACKRequested
#define RFM69_getACKReceived(__value)   ((bool)bitRead(__value,RFM69_ACK_RECEIVED))
 getACKReceived
#define RFM69_setACKReceived(__value, __flag)   bitWrite(__value,RFM69_ACK_RECEIVED,__flag)
 setACKReceived
#define RFM69_setACKRSSIReport(__value, __flag)   bitWrite(__value,RFM69_ACK_RSSI_REPORT,__flag)
 setACKRSSIReport
#define RFM69_getACKRSSIReport(__value)   ((bool)bitRead(__value,RFM69_ACK_RSSI_REPORT))
 getACKRSSIReport
#define RFM69_READ_REGISTER   (0x7Fu)
 reading register
#define RFM69_WRITE_REGISTER   (0x80u)
 writing register
#define RFM69_CONFIG_FSK   (RFM69_DATAMODUL_DATAMODE_PACKET | RFM69_DATAMODUL_MODULATIONTYPE_FSK | RFM69_DATAMODUL_MODULATIONSHAPING_00)
 RFM69_CONFIG_FSK.
#define RFM69_CONFIG_GFSK   (RFM69_DATAMODUL_DATAMODE_PACKET | RFM69_DATAMODUL_MODULATIONTYPE_FSK | RFM69_DATAMODUL_MODULATIONSHAPING_10)
 RFM69_CONFIG_GFSK.
#define RFM69_CONFIG_OOK   (RFM69_DATAMODUL_DATAMODE_PACKET | RFM69_DATAMODUL_MODULATIONTYPE_OOK | RFM69_DATAMODUL_MODULATIONSHAPING_00)
 RFM69_CONFIG_OOK.
#define RFM69_CONFIG_NOWHITE   (RFM69_PACKET1_FORMAT_VARIABLE | RFM69_PACKET1_DCFREE_OFF | RFM69_PACKET1_CRC_ON | RFM69_PACKET1_CRCAUTOCLEAR_ON | RFM69_PACKET1_ADRSFILTERING_NODEBROADCAST)
 RFM69_CONFIG_NOWHITE.
#define RFM69_CONFIG_WHITE   (RFM69_PACKET1_FORMAT_VARIABLE | RFM69_PACKET1_DCFREE_WHITENING | RFM69_PACKET1_CRC_ON | RFM69_PACKET1_CRCAUTOCLEAR_ON | RFM69_PACKET1_ADRSFILTERING_NODEBROADCAST)
 RFM69_CONFIG_WHITE.
#define RFM69_CONFIG_MANCHESTER   (RFM69_PACKET1_FORMAT_VARIABLE | RFM69_PACKET1_DCFREE_MANCHESTER | RFM69_PACKET1_CRC_ON | RFM69_PACKET1_CRCAUTOCLEAR_ON | RFM69_PACKET1_ADRSFILTERING_NODEBROADCAST)
 RFM69_CONFIG_MANCHESTER.
#define RFM69_RXBW_111_24_4   (RFM69_RXBW_DCCFREQ_111 | RFM69_RXBW_MANT_24 | RFM69_RXBW_EXP_4)
 RFM69_RXBW_111_24_4.
#define RFM69_RXBW_111_24_3   (RFM69_RXBW_DCCFREQ_111 | RFM69_RXBW_MANT_24 | RFM69_RXBW_EXP_3)
 RFM69_RXBW_111_24_3.
#define RFM69_RXBW_111_24_2   (RFM69_RXBW_DCCFREQ_111 | RFM69_RXBW_MANT_24 | RFM69_RXBW_EXP_2)
 RFM69_RXBW_111_24_2.
#define RFM69_RXBW_111_16_2   (RFM69_RXBW_DCCFREQ_111 | RFM69_RXBW_MANT_16 | RFM69_RXBW_EXP_2)
 RFM69_RXBW_111_16_2.
#define RFM69_RXBW_111_16_1   (RFM69_RXBW_DCCFREQ_111 | RFM69_RXBW_MANT_16 | RFM69_RXBW_EXP_1)
 RFM69_RXBW_111_16_1.
#define RFM69_RXBW_111_16_0   (RFM69_RXBW_DCCFREQ_111 | RFM69_RXBW_MANT_16 | RFM69_RXBW_EXP_0)
 RFM69_RXBW_111_16_0.
#define RFM69_RXBW_010_16_2   (RFM69_RXBW_DCCFREQ_010 | RFM69_RXBW_MANT_16 | RFM69_RXBW_EXP_2)
 RFM69_RXBW_010_16_2.
#define RFM69_FSK_BR2_FD5   RFM69_CONFIG_FSK, RFM69_BITRATEMSB_2000, RFM69_BITRATELSB_2000, RFM69_FDEVMSB_5000, RFM69_FDEVLSB_5000, RFM69_RXBW_111_24_4, RFM69_CONFIG_WHITE
 RFM69_FSK_BR2_FD5.
#define RFM69_FSK_BR2_4_FD4_8   RFM69_CONFIG_FSK, RFM69_BITRATEMSB_2400, RFM69_BITRATELSB_2400, RFM69_FDEVMSB_4800, RFM69_FDEVLSB_4800, RFM69_RXBW_111_24_4, RFM69_CONFIG_WHITE
 RFM69_FSK_BR2_4_FD4_8.
#define RFM69_FSK_BR4_8_FD9_6   RFM69_CONFIG_FSK, RFM69_BITRATEMSB_4800, RFM69_BITRATELSB_4800, RFM69_FDEVMSB_9600, RFM69_FDEVLSB_9600, RFM69_RXBW_111_24_4, RFM69_CONFIG_WHITE
 RFM69_FSK_BR4_8_FD9_6.
#define RFM69_FSK_BR9_6_FD19_2   RFM69_CONFIG_FSK, RFM69_BITRATEMSB_9600, RFM69_BITRATELSB_9600, RFM69_FDEVMSB_19200, RFM69_FDEVLSB_19200, RFM69_RXBW_111_24_4, RFM69_CONFIG_WHITE
 RFM69_FSK_BR9_6_FD19_2.
#define RFM69_FSK_BR19_2_FD38_4   RFM69_CONFIG_FSK, RFM69_BITRATEMSB_19200, RFM69_BITRATELSB_19200, RFM69_FDEVMSB_38400, RFM69_FDEVLSB_38400, RFM69_RXBW_111_24_3, RFM69_CONFIG_WHITE
 RFM69_FSK_BR19_2_FD38_4.
#define RFM69_FSK_BR38_4_FD76_8   RFM69_CONFIG_FSK, RFM69_BITRATEMSB_38400, RFM69_BITRATELSB_38400, RFM69_FDEVMSB_76800, RFM69_FDEVLSB_76800, RFM69_RXBW_111_24_2, RFM69_CONFIG_WHITE
 RFM69_FSK_BR38_4_FD76_8.
#define RFM69_FSK_BR55_5_FD50   RFM69_CONFIG_FSK, RFM69_BITRATEMSB_55555, RFM69_BITRATELSB_55555, RFM69_FDEVMSB_50000, RFM69_FDEVLSB_50000, RFM69_RXBW_111_16_2, RFM69_CONFIG_WHITE
 RFM69_FSK_BR55_5_FD50.
#define RFM69_FSK_BR57_6_FD120   RFM69_CONFIG_FSK, RFM69_BITRATEMSB_57600, RFM69_BITRATELSB_57600, RFM69_FDEVMSB_120000, RFM69_FDEVLSB_120000, RFM69_RXBW_111_16_1, RFM69_CONFIG_WHITE
 RFM69_FSK_BR57_6_FD120.
#define RFM69_FSK_BR125_FD125   RFM69_CONFIG_FSK, RFM69_BITRATEMSB_125000, RFM69_BITRATELSB_125000, RFM69_FDEVMSB_125000, RFM69_FDEVLSB_125000, RFM69_RXBW_010_16_2, RFM69_CONFIG_WHITE
 RFM69_FSK_BR125_FD125.
#define RFM69_FSK_BR250_FD250   RFM69_CONFIG_FSK, RFM69_BITRATEMSB_250000, RFM69_BITRATELSB_250000, RFM69_FDEVMSB_250000, RFM69_FDEVLSB_250000, RFM69_RXBW_111_16_0, RFM69_CONFIG_WHITE
 RFM69_FSK_BR250_FD250.
#define RFM69_GFSK_BR2_FD5   RFM69_CONFIG_GFSK, RFM69_BITRATEMSB_2000, RFM69_BITRATELSB_2000, RFM69_FDEVMSB_5000, RFM69_FDEVLSB_5000, RFM69_RXBW_111_24_4, RFM69_CONFIG_WHITE
 RFM69_GFSK_BR2_FD5.
#define RFM69_GFSK_BR2_4_FD4_8   RFM69_CONFIG_GFSK, RFM69_BITRATEMSB_2400, RFM69_BITRATELSB_2400, RFM69_FDEVMSB_4800, RFM69_FDEVLSB_4800, RFM69_RXBW_111_24_4, RFM69_CONFIG_WHITE
 RFM69_GFSK_BR2_4_FD4_8.
#define RFM69_GFSK_BR4_8_FD9_6   RFM69_CONFIG_GFSK, RFM69_BITRATEMSB_4800, RFM69_BITRATELSB_4800, RFM69_FDEVMSB_9600, RFM69_FDEVLSB_9600, RFM69_RXBW_111_24_4, RFM69_CONFIG_WHITE
 RFM69_GFSK_BR4_8_FD9_6.
#define RFM69_GFSK_BR9_6_FD19_2   RFM69_CONFIG_GFSK, RFM69_BITRATEMSB_9600, RFM69_BITRATELSB_9600, RFM69_FDEVMSB_19200, RFM69_FDEVLSB_19200, RFM69_RXBW_111_24_4, RFM69_CONFIG_WHITE
 RFM69_GFSK_BR9_6_FD19_2.
#define RFM69_GFSK_BR19_2_FD38_4   RFM69_CONFIG_GFSK, RFM69_BITRATEMSB_19200, RFM69_BITRATELSB_19200, RFM69_FDEVMSB_38400, RFM69_FDEVLSB_38400, RFM69_RXBW_111_24_3, RFM69_CONFIG_WHITE
 RFM69_GFSK_BR19_2_FD38_4.
#define RFM69_GFSK_BR38_4_FD76_8   RFM69_CONFIG_GFSK, RFM69_BITRATEMSB_38400, RFM69_BITRATELSB_38400, RFM69_FDEVMSB_76800, RFM69_FDEVLSB_76800, RFM69_RXBW_111_24_2, RFM69_CONFIG_WHITE
 RFM69_GFSK_BR38_4_FD76_8.
#define RFM69_GFSK_BR55_5_FD50   RFM69_CONFIG_GFSK, RFM69_BITRATEMSB_55555, RFM69_BITRATELSB_55555, RFM69_FDEVMSB_50000, RFM69_FDEVLSB_50000, RFM69_RXBW_111_16_2, RFM69_CONFIG_WHITE
 RFM69_GFSK_BR55_5_FD50.
#define RFM69_GFSK_BR57_6_FD120   RFM69_CONFIG_GFSK, RFM69_BITRATEMSB_57600, RFM69_BITRATELSB_57600, RFM69_FDEVMSB_120000, RFM69_FDEVLSB_120000, RFM69_RXBW_111_16_1, RFM69_CONFIG_WHITE
 RFM69_GFSK_BR57_6_FD120.
#define RFM69_GFSK_BR125_FD125   RFM69_CONFIG_GFSK, RFM69_BITRATEMSB_125000, RFM69_BITRATELSB_125000, RFM69_FDEVMSB_125000, RFM69_FDEVLSB_125000, RFM69_RXBW_010_16_2, RFM69_CONFIG_WHITE
 RFM69_GFSK_BR125_FD125.
#define RFM69_GFSK_BR250_FD250   RFM69_CONFIG_GFSK, RFM69_BITRATEMSB_250000, RFM69_BITRATELSB_250000, RFM69_FDEVMSB_250000, RFM69_FDEVLSB_250000, RFM69_RXBW_111_16_0, RFM69_CONFIG_WHITE
 RFM69_GFSK_BR250_FD250.
#define RFM69_OOK_BR2_FD5   RFM69_CONFIG_OOK, RFM69_BITRATEMSB_2000, RFM69_BITRATELSB_2000, RFM69_FDEVMSB_5000, RFM69_FDEVLSB_5000, RFM69_RXBW_111_24_4, RFM69_CONFIG_WHITE
 RFM69_OOK_BR2_FD5.
#define RFM69_OOK_BR2_4_FD4_8   RFM69_CONFIG_OOK, RFM69_BITRATEMSB_2400, RFM69_BITRATELSB_2400, RFM69_FDEVMSB_4800, RFM69_FDEVLSB_4800, RFM69_RXBW_111_24_4, RFM69_CONFIG_WHITE
 RFM69_OOK_BR2_4_FD4_8.
#define RFM69_OOK_BR4_8_FD9_6   RFM69_CONFIG_OOK, RFM69_BITRATEMSB_4800, RFM69_BITRATELSB_4800, RFM69_FDEVMSB_9600, RFM69_FDEVLSB_9600, RFM69_RXBW_111_24_4, RFM69_CONFIG_WHITE
 RFM69_OOK_BR4_8_FD9_6.
#define RFM69_OOK_BR9_6_FD19_2   RFM69_CONFIG_OOK, RFM69_BITRATEMSB_9600, RFM69_BITRATELSB_9600, RFM69_FDEVMSB_19200, RFM69_FDEVLSB_19200, RFM69_RXBW_111_24_4, RFM69_CONFIG_WHITE
 RFM69_OOK_BR9_6_FD19_2.
#define RFM69_OOK_BR19_2_FD38_4   RFM69_CONFIG_OOK, RFM69_BITRATEMSB_19200, RFM69_BITRATELSB_19200, RFM69_FDEVMSB_38400, RFM69_FDEVLSB_38400, RFM69_RXBW_111_24_3, RFM69_CONFIG_WHITE
 RFM69_OOK_BR19_2_FD38_4.
#define RFM69_OOK_BR38_4_FD76_8   RFM69_CONFIG_OOK, RFM69_BITRATEMSB_38400, RFM69_BITRATELSB_38400, RFM69_FDEVMSB_76800, RFM69_FDEVLSB_76800, RFM69_RXBW_111_24_2, RFM69_CONFIG_WHITE
 RFM69_OOK_BR38_4_FD76_8.
#define RFM69_OOK_BR55_5_FD50   RFM69_CONFIG_OOK, RFM69_BITRATEMSB_55555, RFM69_BITRATELSB_55555, RFM69_FDEVMSB_50000, RFM69_FDEVLSB_50000, RFM69_RXBW_111_16_2, RFM69_CONFIG_WHITE
 RFM69_OOK_BR55_5_FD50.
#define RFM69_OOK_BR57_6_FD120   RFM69_CONFIG_OOK, RFM69_BITRATEMSB_57600, RFM69_BITRATELSB_57600, RFM69_FDEVMSB_120000, RFM69_FDEVLSB_120000, RFM69_RXBW_111_16_1, RFM69_CONFIG_WHITE
 RFM69_OOK_BR57_6_FD120.
#define RFM69_OOK_BR125_FD125   RFM69_CONFIG_OOK, RFM69_BITRATEMSB_125000, RFM69_BITRATELSB_125000, RFM69_FDEVMSB_125000, RFM69_FDEVLSB_125000, RFM69_RXBW_010_16_2, RFM69_CONFIG_WHITE
 RFM69_OOK_BR125_FD125.
#define RFM69_OOK_BR250_FD250   RFM69_CONFIG_OOK, RFM69_BITRATEMSB_250000, RFM69_BITRATELSB_250000, RFM69_FDEVMSB_250000, RFM69_FDEVLSB_250000, RFM69_RXBW_111_16_0, RFM69_CONFIG_WHITE
 RFM69_OOK_BR250_FD250.
#define MY_RFM69_MODEM_CONFIGURATION   RFM69_FSK_BR55_5_FD50
 default setting, RFM69_FSK_BR55_5_FD50
#define RFM69_HEADER_LEN   sizeof(rfm69_header_t)
 Size header inside payload.
#define RFM69_MAX_PAYLOAD_LEN   (RFM69_MAX_PACKET_LEN - RFM69_HEADER_LEN)
 Max payload length.
#define LOCAL   static
 static
Typedefs
typedef uint8_t rfm69_sequenceNumber_t
 Sequence number data type.
typedef uint8_t rfm69_RSSI_t
 RSSI data type.
typedef int8_t rfm69_SNR_t
 SNR data type.
typedef uint8_t rfm69_controlFlags_t
 Control flag data type.
typedef int8_t rfm69_powerlevel_t
 Power level in dBm.
Enumerations
enum  rfm69_radio_mode_t {
  RFM69_RADIO_MODE_RX = 0, RFM69_RADIO_MODE_TX = 1, RFM69_RADIO_MODE_CAD = 2, RFM69_RADIO_MODE_SLEEP = 3,
  RFM69_RADIO_MODE_STDBY = 4, RFM69_RADIO_MODE_SYNTH = 5, RFM69_RADIO_MODE_LISTEN = 6
 Radio modes. More...
LOCAL void RFM69_handler (void)
 RFM69_handler.
LOCAL void RFM69_clearFIFO (void)
 Clear flags and FIFO.
LOCAL bool RFM69_channelFree (void)
 Check for channel activity. More...
LOCAL void RFM69_interruptHandling (void)
 RFM69_interruptHandling.
LOCAL bool RFM69_initialise (const uint32_t frequencyHz)
 Initialise the driver transport hardware and software. More...
LOCAL void RFM69_setAddress (const uint8_t addr)
 Set the driver/node address. More...
LOCAL uint8_t RFM69_getAddress (void)
 Get driver/node address. More...
LOCAL bool RFM69_available (void)
 Tests whether a new message is available. More...
LOCAL uint8_t RFM69_receive (uint8_t *buf, const uint8_t maxBufSize)
 If a valid message is received, copy it to buf and return length. 0 byte messages are permitted. More...
LOCAL bool RFM69_sendFrame (rfm69_packet_t *packet, const bool increaseSequenceCounter=true)
 RFM69_sendFrame. More...
LOCAL bool RFM69_send (const uint8_t recipient, uint8_t *data, const uint8_t len, const rfm69_controlFlags_t flags, const bool increaseSequenceCounter=true)
 RFM69_send. More...
LOCAL void RFM69_setFrequency (const uint32_t frequencyHz)
 Sets the transmitter and receiver center frequency. More...
LOCAL bool RFM69_setTxPowerLevel (rfm69_powerlevel_t newPowerLevel)
 Sets the transmitter power output level, and configures the transmitter pin. More...
LOCAL rfm69_powerlevel_t RFM69_getTxPowerLevel (void)
 Reports the transmitter power output level in dBm. More...
LOCAL uint8_t RFM69_getTxPowerPercent (void)
 Reports the transmitter power output level in percents. More...
LOCAL bool RFM69_sleep (void)
 Sets the radio into low-power sleep mode. More...
LOCAL bool RFM69_standBy (void)
 Sets the radio to standby mode. More...
LOCAL void RFM69_powerDown (void)
 Power down radio (HW)
LOCAL void RFM69_powerUp (void)
 Power up radio (HW)
LOCAL void RFM69_sendACK (const uint8_t recipient, const rfm69_sequenceNumber_t sequenceNumber, const rfm69_RSSI_t RSSI)
 RFM69_sendACK. More...
LOCAL bool RFM69_sendWithRetry (const uint8_t recipient, const void *buffer, const uint8_t bufferSize, const bool noACK)
 RFM69_sendWithRetry. More...
LOCAL bool RFM69_setRadioMode (const rfm69_radio_mode_t newRadioMode)
 RFM69_setRadioMode. More...
LOCAL void RFM69_interruptHandler (void)
 Low level interrupt handler.
LOCAL int16_t RFM69_getSendingRSSI (void)
 RFM69_getSendingRSSI. More...
LOCAL int16_t RFM69_getReceivingRSSI (void)
 RFM69_getReceivingRSSI. More...
LOCAL bool RFM69_executeATC (const rfm69_RSSI_t currentRSSI, const rfm69_RSSI_t targetRSSI)
 RFM69_executeATC. More...
LOCAL void RFM69_setConfiguration (void)
 RFM69_setConfiguration Set general radio register configuration TODO temp use setmodemregisters.
LOCAL bool RFM69_isModeReady (void)
 RFM69_isModeReady. More...
LOCAL bool RFM69_sanityCheck (void)
 RFM69_sanityCheck detect HW defect, configuration errors or interrupted SPI line. More...
LOCAL void RFM69_encrypt (const char *key)
 RFM69_encrypt Set encryption mode. More...
LOCAL void RFM69_setHighPowerRegs (const bool onOff)
 RFM69_setHighPowerRegs. More...
LOCAL rfm69_RSSI_t RFM69_readRSSI (const bool forceTrigger=false)
 RFM69_readRSSI. More...
LOCAL void RFM69_ATCmode (const bool onOff, const int16_t targetRSSI=RFM69_TARGET_RSSI_DBM)
 RFM69_ATCmode. More...
LOCAL void RFM69_readAllRegs (void)
 RFM69_readAllRegs Read and display all RFM69 register contents. More...
