2.3.2-96-g79dfe0a1
41 #define MY_REPEATER_FEATURE
45 #define RELAY_PIN 4 // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
46 #define NUMBER_OF_RELAYS 1 // Total number of attached relays
47 #define RELAY_ON 1 // GPIO value to write to turn on attached relay
48 #define RELAY_OFF 0 // GPIO value to write to turn off attached relay
86 if (message.
getType()==V_STATUS) {
88 digitalWrite(message.
getSensor()-1+RELAY_PIN, message.
getBool()?RELAY_ON:RELAY_OFF);
92 Serial.print(
"Incoming change for sensor:");
94 Serial.print(
", New status: ");
95 Serial.println(message.
getBool());
uint8_t getSensor(void) const
Get sensor ID of message.
uint8_t sensor
void before()
Called before node initialises.
uint8_t getType(void) const
Get message type.
bool getBool(void) const
Get bool payload.
