MySensors Library & Examples  2.3.2-91-gc4565708
VibrationSensor.ino
21  * DESCRIPTION
22  *
23  * Vibration Sensor
24  *
25  * connect the sensor as follows :
26  *
27  * VCC >>> 5V
28  * S >>> D3
29  * GND >>> GND
30  *
31  * Based on: http://www.dfrobot.com/wiki/index.php/DFRobot_Digital_Vibration_Sensor_V2_SKU:DFR0027
32  * Contributor: epierre
33  */
35 // Enable debug prints to serial monitor
36 #define MY_DEBUG
38 // Enable and select radio type attached
39 #define MY_RADIO_RF24
40 //#define MY_RADIO_NRF5_ESB
41 //#define MY_RADIO_RFM69
42 //#define MY_RADIO_RFM95
43 //#define MY_PJON
45 #include <MySensors.h>
46 #include <Wire.h>
48 #define CHILD_ID_VIBRATION 0
49 #define VIBRATION_SENSOR_DIGITAL_PIN 3
50 #define SensorLED 13
52 uint32_t SLEEP_TIME = 10*1000; // Sleep time between reads (in seconds)
54 //VARIABLES
55 int val = 0; // variable to store the value coming from the sensor
56 float valVIBRATION =0.0;
57 float lastVIBRATION =0.0;
58 unsigned char state = 0;
60 MyMessage vibrationMsg(CHILD_ID_VIBRATION, V_LEVEL);
62 void setup()
63 {
64  pinMode(VIBRATION_SENSOR_DIGITAL_PIN, INPUT);
65  attachInterrupt(digitalPinToInterrupt(VIBRATION_SENSOR_DIGITAL_PIN), blink,
66  FALLING); // Trigger the blink function when the falling edge is detected
67  pinMode(SensorLED, OUTPUT);
68 }
71 {
72  // Send the sketch version information to the gateway and Controller
73  sendSketchInfo("VIBRATION Sensor", "1.0");
75  // Register all sensors to gateway (they will be created as child devices)
76  present(CHILD_ID_VIBRATION, S_VIBRATION);
77 }
79 void loop()
80 {
82  if(state>=40) { // basically below 40 so ignire basic level
83  send(vibrationMsg.set(int16_t(state)));
84  state = 0;
85  digitalWrite(SensorLED,HIGH);
86  } else {
87  state = 0;
88  digitalWrite(SensorLED,LOW);
89  }
92  // Power down the radio. Note that the radio will get powered back up
93  // on the next write() call.
94  delay(1000); //delay to allow serial to fully print before sleep
96  sleep(SLEEP_TIME); //sleep for: sleepTime
97 }
99 void blink()//Interrupts function
100 {
101  state++;
102 }
HIGH
#define HIGH
Definition: bcm2835.h:572
Definition: VibrationSensor.ino:79
LOW
#define LOW
Definition: bcm2835.h:574
Definition: VibrationSensor.ino:70
MyMessage::set
send
present
Definition: VibrationSensor.ino:62
sleep
Definition: MyMessage.h:291
