55 #define MY_RS485_DE_PIN 2
58 #define MY_RS485_BAUD_RATE 9600
65 uint32_t SLEEP_TIME = 120000;
66 #define DIGITAL_INPUT_SENSOR 3 // The digital input you attached your motion sensor. (Only 2 and 3 generates interrupt!)
67 #define CHILD_ID 1 // Id of the sensor child
74 pinMode(DIGITAL_INPUT_SENSOR, INPUT);
89 bool tripped = digitalRead(DIGITAL_INPUT_SENSOR) ==
HIGH;
91 Serial.println(tripped);
95 sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), CHANGE, SLEEP_TIME);
