41 uint32_t SLEEP_TIME = 120000;
42 #define DIGITAL_INPUT_SENSOR 3 // The digital input you attached your motion sensor. (Only 2 and 3 generates interrupt!)
43 #define CHILD_ID 1 // Id of the sensor child
50 pinMode(DIGITAL_INPUT_SENSOR, INPUT);
65 bool tripped = digitalRead(DIGITAL_INPUT_SENSOR) ==
HIGH;
67 Serial.println(tripped);
71 sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), CHANGE, SLEEP_TIME);
