ClearEepromConfig.ino
21  * DESCRIPTION
22  *
23  * This sketch clears radioId, relayId and other routing information in EEPROM back to factory default
24  *
25  */
26 // load core modules only
27 #define MY_CORE_ONLY
29 #include <MySensors.h>
31 void setup()
32 {
33  Serial.begin(MY_BAUD_RATE);
34  Serial.println("Started clearing. Please wait...");
35  for (uint16_t i=0; i<EEPROM_LOCAL_CONFIG_ADDRESS; i++) {
36  hwWriteConfig(i,0xFF);
37  }
38  Serial.println("Clearing done.");
39 }
41 void loop()
42 {
43  // Nothing to do here...
44 }
MY_BAUD_RATE
#define MY_BAUD_RATE
Serial output baud rate (debug prints and serial gateway speed).
Definition: MyConfig.h:179
Definition: ClearEepromConfig.ino:41
#define EEPROM_LOCAL_CONFIG_ADDRESS
First free address for sketch static configuration.
Definition: MyEepromAddresses.h:92
Definition: ClearEepromConfig.ino:31
