It's possible to build a WIFI enabled gateway running directly on an ESP8266 module. The porting has been done by Yveaux and has been documented here.
The easiest build option is probably to use the NodeMcu Devkit v.10 (by the NodeMcu Team). Schematics and layout can be found here. This board has the ESP-12 module mounted. Just connect the radio, install gateway software and you're good to go.
Installing Gateway Software
The standard ESP8266 Gateway sketch can be used without modification (except for SSID & password).
Setting things up
- Install Arduino IDE 1.6.5+
- Add support for ESP8266 to Arduino, see Installing with Boards Manager NOTE: Make sure you use the version that is marked as supported in the MySensors release notes.
- Install the latest MySensors library from the Library Manager.
Install CP2102 drivers from here.(not needed anymore)- Connect NodeMCU board.
Compiling and uploading the gateway sketch
- Open the WiFi gateway in the Arduino IDE (File -> Sketchbook -> Libraries -> MySensors -> Esp8266Gateway
- Save it, to allow editing
- Enter your SSID and WiFi password in the 'ssid' and 'pass' variables
- Select the ESP8266 board you're targeting in Tools -> Board. Use an ESP12 module, which is a 'NodeMCU 1.0 (ESP 12E module)' board target.
- Verify your sketch. It should compile without errors.
- Now upload the sketch. This NodeMCU board normally can be flashed automatically and shouldn't need bootload/reset buttons to be pressed. If you see error, try changing baudrate from from 9600 to 57600. Still problems? Hold flash and press reset. Start upload in IDE while keeping flash-button pressed until upload starts.
- Open the serial console and watch the board connecting to your WiFi network.
- Note the IP address assigned to it. Optionally, enable a static ip in your DHCP server if you prefer to keep same ip at the next startup.
- Any application capable of communicating with the regular MySensors Ethernet gateway should be able to communicate with the ESP Gateway
- Enjoy!
To verify things you can connect a telnet session (e.g. putty) to the IP address mentioned in the serial output, port 5003 and send some serial commands!
Wiring for "barebone" ESP8266
The "barebone" ESP modules, like ESP-12E, require a certain pin configuration to download code, and another one to run code.
- Connect REST (reset) via 10K pullup resistor to VCC, and via switch to GND ('reset switch')
- Connect GPIO15 via 10K pulldown resistor to GND
- Connect CH_PD via 10K resistor to VCC
- Connect GPIO2 via 10K resistor to VCC
- Connect GPIO0 via 10K resistor to VCC, and via switch to GND ('bootload switch')
Configuration
See advanced build options for more about inclusion button and leds.
ESP8266Gateway Example
* Created by Henrik Ekblad <[email protected]>
* REVISION HISTORY
* Version 1.0 - Henrik Ekblad
* Contribution by a-lurker and Anticimex,
* Contribution by Norbert Truchsess <[email protected]>
* Contribution by Ivo Pullens (ESP8266 support)
* The EthernetGateway sends data received from sensors to the WiFi link.
* The gateway also accepts input on ethernet interface, which is then sent out to the radio network.
* VERA CONFIGURATION:
* Enter "ip-number:port" in the ip-field of the Arduino GW device. This will temporarily override any serial configuration for the Vera plugin.
* E.g. If you want to use the default values in this sketch enter: 192.168.178.66:5003
* LED purposes:
* - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs in your sketch, only the LEDs that is defined is used.
* See https://www.mysensors.org/build/connect_radio for wiring instructions.
* If you are using a "barebone" ESP8266, see
* https://www.mysensors.org/build/esp8266_gateway#wiring-for-barebone-esp8266
* Inclusion mode button:
* - Connect GPIO5 (=D1) via switch to GND ('inclusion switch')
// Use a bit lower baudrate for serial prints on ESP8266 than default in MyConfig.h
#define MY_BAUD_RATE 9600
#define MY_GATEWAY_ESP8266
#define MY_WIFI_SSID "MySSID"
// Enable UDP communication
//#define MY_USE_UDP // If using UDP you need to set MY_CONTROLLER_IP_ADDRESS or MY_CONTROLLER_URL_ADDRESS below
// it will pass to the DHCP server if not static.
#define MY_HOSTNAME "ESP8266_GW"
// The port to keep open on node server mode
#define MY_PORT 5003
// How many clients should be able to connect to this gateway (default 1)
#define MY_GATEWAY_MAX_CLIENTS 2
//#define MY_CONTROLLER_IP_ADDRESS 192, 168, 178, 68
//#define MY_CONTROLLER_URL_ADDRESS "my.controller.org"
// Enable inclusion mode
//#define MY_INCLUSION_MODE_DURATION 60
//#define MY_INCLUSION_MODE_BUTTON_PIN D1
// Set blinking period
//#define MY_DEFAULT_LED_BLINK_PERIOD 300
// Flash leds on rx/tx/err
// Led pins used if blinking feature is enabled above
