The LM393 is a simple photo-resistor light sensor that has both analog and digital outputs. The digital output has a trim potentiometer that can be used to set a trigger light level.
In the following example we will use the analog output to measure light level. If you are interested in reading the digital output, please refer to the pulse sensor example sketch.
Wiring Things Up
Start by connecting the radio module.
Sensor | Arduino | Comment |
GND | GND | Black |
VCC | VCC (3.3-5V) | Red |
A0 (analog out) | Analog input 0 (A0) | Green |
Example
* Created by Henrik Ekblad <[email protected]>
* REVISION HISTORY
* Version 1.0 - Henrik EKblad
* Example sketch showing how to measure light level using a LM393 photo-resistor
* http://www.mysensors.org/build/light
//#define MY_RADIO_NRF5_ESB
#define CHILD_ID_LIGHT 0
#define LIGHT_SENSOR_ANALOG_PIN 0
uint32_t SLEEP_TIME = 30000; // Sleep time between reads (in milliseconds)
MyMessage msg(CHILD_ID_LIGHT, V_LIGHT_LEVEL);
int lastLightLevel;
sendSketchInfo("Light Sensor", "1.0");
// Register all sensors to gateway (they will be created as child devices)
present(CHILD_ID_LIGHT, S_LIGHT_LEVEL);
int16_t lightLevel = (1023-analogRead(LIGHT_SENSOR_ANALOG_PIN))/10.23;
Serial.println(lightLevel);
if (lightLevel != lastLightLevel) {
send(msg.set(lightLevel));
lastLightLevel = lightLevel;
sleep(SLEEP_TIME);
