See this comparison for in-depth information on accuracy of different sensors.
Wiring Things Up
Start by connecting the radio module.
The native sensor's operating range is 1.9 to 3.6V. Therefore two common variants of breakout boards can be found on the internet: one containing its own voltage regulator and level conversion to make it compatible with 5V Arduino's, and another variant that lacks a voltage regulator and level conversion making it **only **compatible with 3.3V Arduino's.
The 5V compatible modules are often marked 'GY-21' and can be identified by the extra components on the bottom of their circuit board. Examples of 5V Arduinos's are Uno, Nano and Pro Mini 5V.
5V Sensor | Arduino |
GND | GND |
VIN | VCC or 5V |
SDA | A4 |
SCL | A5 |
The SCL & SDA pins mentioned are available at A5 & A4 on Arduino Uno, Nano and Pro Mini. Other boards use different mappings, see here.
The 3.3V compatible modules usually contain no extra components on the bottom of their circuit board, and seem to be knowns also as 'GY-213v'. An example of a 3.3V Arduino is the Pro Mini 3.3V.
3.3V Sensor | Arduino |
GND or - | GND |
3.3V or + | VCC or 3.3V |
SDA or DA | A4 |
SCL or CL | A5 |
Example
This example uses the Si7021 library, which is included in the MySensors external examples. If you choose to report battery level to the gateway (by defining REPORT_BATTERY_LEVEL at the top of the sketch) the Vcc library is also required. Please install the librarie(s) and restart the Arduino IDE before trying to compile.
* Created by Henrik Ekblad <[email protected]>
* REVISION HISTORY
* Version 1.0: Yveaux
* This sketch provides an example of how to implement a humidity/temperature
* sensor using a Si7021 sensor.
* For more information, please visit:
* http://www.mysensors.org/build/humiditySi7021
// Enable debug prints
// Enable REPORT_BATTERY_LEVEL to measure battery level and send changes to gateway
//#define REPORT_BATTERY_LEVEL
//#define MY_RS485
#define CHILD_ID_HUM 0
#define CHILD_ID_TEMP 1
static bool metric = true;
// Sleep time between sensor updates (in milliseconds)
static const uint64_t UPDATE_INTERVAL = 60000;
#include <SI7021.h>
static SI7021 sensor;
#ifdef REPORT_BATTERY_LEVEL
#include <Vcc.h>
static uint8_t oldBatteryPcnt = 200; // Initialize to 200 to assure first time value will be sent.
const float VccMin = 1.8; // Minimum expected Vcc level, in Volts: Brownout at 1.8V -> 0%
const float VccMax = 2.0*1.6; // Maximum expected Vcc level, in Volts: 2xAA fresh Alkaline -> 100%
const float VccCorrection = 1.0; // Measured Vcc by multimeter divided by reported Vcc
static Vcc vcc(VccCorrection);
// Send the sketch info to the gateway
sendSketchInfo("TemperatureAndHumidity", "1.0");
// Present sensors as children to gateway
present(CHILD_ID_HUM, S_HUM, "Humidity");
present(CHILD_ID_TEMP, S_TEMP, "Temperature");
metric = getControllerConfig().isMetric;
while (not sensor.begin())
Serial.println(F("Sensor not detected!"));
delay(5000);
// Read temperature & humidity from sensor.
const float temperature = float( metric ? sensor.getCelsiusHundredths() : sensor.getFahrenheitHundredths() ) / 100.0;
const float humidity = float( sensor.getHumidityBasisPoints() ) / 100.0;
#ifdef MY_DEBUG
Serial.print(F("Temp "));
Serial.print(temperature);
Serial.print(metric ? 'C' : 'F');
Serial.print(F("\tHum "));
Serial.println(humidity);
static MyMessage msgHum( CHILD_ID_HUM, V_HUM );
static MyMessage msgTemp(CHILD_ID_TEMP, V_TEMP);
send(msgTemp.set(temperature, 2));
send(msgHum.set(humidity, 2));
const uint8_t batteryPcnt = static_cast<uint8_t>(0.5 + vcc.Read_Perc(VccMin, VccMax));
#ifdef MY_DEBUG
Serial.print(F("Vbat "));
Serial.print(vcc.Read_Volts());
Serial.print(F("\tPerc "));
Serial.println(batteryPcnt);
// Battery readout should only go down. So report only when new value is smaller than previous one.
if ( batteryPcnt < oldBatteryPcnt )
sendBatteryLevel(batteryPcnt);
oldBatteryPcnt = batteryPcnt;
// Sleep until next update to save energy
sleep(UPDATE_INTERVAL);
Battery powering
This sensor can be turned into a 2xAA battery powered sensor. Start with 3.3V Pro Mini, optimized for battery powering. Measurement of the remaining battery life can simply be enabled by defining REPORT_BATTERY_LEVEL at the top of the sketch, which does not require two resisors as described here. Choose the 3.3V Si7021 sensor described above, as the Pro Mini runs on 3.3V.
Images
Datasheets
Name | Size | # Downloads |
Si7021-A20.pdf | 1.56 MB | 2097 |
