Building a Serial Gateway
written by hek
The Serial gateway is pretty simple to build. You will do exactly the same radio connection maneuver when building your sensors. If you are a proud Vera owner you should use an Arduino Nano for the Serial Gateway.
Demonstration
IMAGE ALT TEXT HERE
Wiring Things Up
Just follow the instructions in connecting the radio module.
Upload the Serial/USB Gateway Sketch
Finally, compile and upload the gateway sketch using the Arduino IDE on your computer.
SerialGateway Example
This is a fully working example sketch called 'SerialGateway.ino'.
/mysensors/MySensors/examples/GatewaySerial/GatewaySerial.ino
Last updated by tekka007, 1 Jan 2026, "Prepare 2.4.0 release (#1587)"
* Created by Henrik Ekblad <[email protected]>
* The ArduinoGateway prints data received from sensors on the serial link.
* The gateway accepts input on serial which will be sent out on radio network.
* The GW code is designed for Arduino Nano 328p / 16MHz
* Wire connections (OPTIONAL):
* - Inclusion button should be connected between digital pin 3 and GND
* - RX/TX/ERR leds need to be connected between +5V (anode) and digital pin 6/5/4 with resistor 270-330R in a series
* LEDs (OPTIONAL):
* - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs
//#define MY_RADIO_NRF5_ESB
// Set LOW transmit power level as default, if you have an amplified NRF-module and
// power your radio separately with a good regulator you can turn up PA level.
#define MY_RF24_PA_LEVEL RF24_PA_LOW
// Enable serial gateway
#define MY_GATEWAY_SERIAL
// Define a lower baud rate for Arduinos running on 8 MHz (Arduino Pro Mini 3.3V & SenseBender)
#if F_CPU == 8000000L
#define MY_BAUD_RATE 38400
// Enable inclusion mode
// Inverses behavior of inclusion button (if using external pullup)
//#define MY_INCLUSION_BUTTON_EXTERNAL_PULLUP
// Set blinking period
// Inverses the behavior of leds
//#define MY_WITH_LEDS_BLINKING_INVERSE
// Flash leds on rx/tx/err
//#define MY_DEFAULT_ERR_LED_PIN 4  // Error led pin
//#define MY_DEFAULT_RX_LED_PIN  6  // Receive led pin
//#define MY_DEFAULT_TX_LED_PIN  5  // the PCB, on board LED
    // Present locally attached sensors
    // Send locally attached sensor data here
See Advanced build options for more about inclusion button and leds.
Gateways
Sensors & Actuators
Comments
