Building a MQTT Gateway
written by hek
The MQTT gateway is basically a Ethernet Gateway with modified software which makes it act as a MQTT client. Start by building the physical gateway by following ethernet gateway instructions.
The W5100 MQTT gateway sends radio network (or locally attached sensors) data to your MQTT broker. The node also listens to MY_MQTT_TOPIC_PREFIX and sends out those messages to the radio network.
NOTE: No controller supports dynamic ID assignment through MQTT. All nodes must have MY_NODE_ID defined in the sketch to work with MQTT. If you don't set MY_NODE_ID, nodes will complain with the message "!TSM:ID:FAIL".
Configuration
The MQTT gateway sketch contains some static configuration like ip- and port number. Please update these values to fit your needs before uploading it.
// Enable these if your MQTT broker requires usenrame/password
//#define MY_MQTT_PASSWORD "password"
#define MY_IP_ADDRESS 192,168,178,87
// If using static ip you need to define Gateway and Subnet address as well
#define MY_IP_GATEWAY_ADDRESS 192,168,178,1
#define MY_IP_SUBNET_ADDRESS 255,255,255,0
// MQTT broker ip address or url. Define one or the other.
//#define MY_CONTROLLER_URL_ADDRESS "m20.cloudmqtt.com"
#define MY_CONTROLLER_IP_ADDRESS 192, 168, 178, 68
// The MQTT broker port to to open
#define MY_PORT 1883
MQTTGateway Example
This is a fully working example sketch.
/mysensors/MySensors/examples/GatewayW5100MQTTClient/GatewayW5100MQTTClient.ino
Last updated by tekka007, 1 Jan 2026, "Prepare 2.4.0 release (#1587)"
 * Created by Henrik Ekblad <[email protected]>
 * REVISION HISTORY
 * Version 1.0 - Henrik Ekblad
 * The W5100 MQTT gateway sends radio network (or locally attached sensors) data to your MQTT broker.
 * The node also listens to MY_MQTT_TOPIC_PREFIX and sends out those messages to the radio network
 * LED purposes:
 * - To use the feature, uncomment WITH_LEDS_BLINKING in MyConfig.h
 * See http://www.mysensors.org/build/esp8266_gateway for wiring instructions.
 * nRF24L01+  ESP8266
 * VCC        VCC
 * CE         GPIO4
 * CSN/CS     GPIO15
 * SCK        GPIO14
 * MISO       GPIO12
 * MOSI       GPIO13
 * Not all ESP8266 modules have all pins available on their external interface.
 * This code has been tested on an ESP-12 module.
 * The ESP8266 requires a certain pin configuration to download code, and another one to run code:
 * - Connect REST (reset) via 10K pullup resistor to VCC, and via switch to GND ('reset switch')
 * - Connect GPIO15 via 10K pulldown resistor to GND
 * - Connect CH_PD via 10K resistor to VCC
 * - Connect GPIO2 via 10K resistor to VCC
 * - Connect GPIO0 via 10K resistor to VCC, and via switch to GND ('bootload switch')
  * Inclusion mode button:
 * - Connect GPIO5 via switch to GND ('inclusion switch')
// Set this node's subscribe and publish topic prefix
// Set MQTT client id
// W5100 Ethernet module SPI enable (optional if using a shield/module that manages SPI_EN signal)
//#define MY_W5100_SPI_EN 4
// Enable Soft SPI for NRF radio (note different radio wiring is required)
// The W5100 ethernet module seems to have a hard time co-operate with
// radio on the same spi bus.
#if !defined(MY_W5100_SPI_EN) && !defined(ARDUINO_ARCH_SAMD)
#define MY_SOFTSPI
#define MY_SOFT_SPI_SCK_PIN 14
#define MY_SOFT_SPI_MISO_PIN 16
#define MY_SOFT_SPI_MOSI_PIN 15
// When W5100 is connected we have to move CE/CSN pins for NRF radio
#ifndef MY_RF24_CE_PIN
#define MY_RF24_CE_PIN 5
#ifndef MY_RF24_CS_PIN
#define MY_RF24_CS_PIN 6
// Enable these if your MQTT broker requires username/password
// Enable inclusion mode
// Set blinking period
// Flash leds on rx/tx/err
//#define MY_DEFAULT_ERR_LED_PIN 16  // Error led pin
//#define MY_DEFAULT_RX_LED_PIN  16  // Receive led pin
//#define MY_DEFAULT_TX_LED_PIN  16  // the PCB, on board LED
#include <Ethernet.h>
MQTT Gateway can also be build on a ESP8266 module. Please see comments in MQTTClient.ino code.
 * REVISION HISTORY
 * The ESP8266 MQTT gateway sends radio network (or locally attached sensors) data to your MQTT broker.
 * LED purposes:
 * - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs in your sketch
 * See https://www.mysensors.org/build/connect_radio for wiring instructions.
 * If you are using a "barebone" ESP8266, see
 * https://www.mysensors.org/build/esp8266_gateway#wiring-for-barebone-esp8266
 * - Connect GPIO5 (=D1) via switch to GND ('inclusion switch')
// Use a bit lower baudrate for serial prints on ESP8266 than default in MyConfig.h
#define MY_BAUD_RATE 9600
#define MY_GATEWAY_ESP8266
// Set WIFI SSID and password
#define MY_WIFI_SSID "MySSID"
// passed to the DHCP server if not static.
#define MY_HOSTNAME "ESP8266_MQTT_GW"
// MQTT broker ip address.
//MQTT broker if using URL instead of ip address.
// #define MY_CONTROLLER_URL_ADDRESS "test.mosquitto.org"
//#define MY_INCLUSION_MODE_DURATION 60
//#define MY_INCLUSION_MODE_BUTTON_PIN D1
//#define MY_DEFAULT_LED_BLINK_PERIOD 300
See Advanced build options for more about inclusion button and leds.
Setup and test gateway
You can run the MQTT gateway on an Arduino+W5100 ethernet module or the ESP8266. Connect radio and ethernet module exactly like for the normal gateway.
The topic resembles the serial protocol. You must define you preferred subscribe and publish prefix in the sketch. The topic is build like this: MY_MQTT_PUBLISH_TOPIC_PREFIX/FROM-NODE-ID/SENSOR-ID/CMD-TYPE/ACK-FLAG/SUB-TYPE
Read more about the serial protocol here. An example topic for data received from your gateway could look like this:
mygateway1-out/2/1/1/0/49
If you want to send data to your sensors use MY_MQTT_SUBSCRIBE_TOPIC_PREFIX defined in your sketch. Should be looking like this (using default sketch):
mygateway1-in/2/1/1/0/49
You can test your gateway using mosquitto as broker.
Make sure to set MY_IP_GATEWAY_ADDRESS in gateway pointing to you computers ip-number (on the same lan).
Start the broker (leave this running): > mosquitto
Now start your gateway and you should see something like this in the gateway log. Note that I have a GPS sensor running in my radio network which send data to the gateway all the time:
0;0;3;0;9;gateway started, id=0, parent=0, distance=0
0;0;3;0;9;Attempting MQTT connection...
0;0;3;0;9;MQTT connected
0;0;3;0;9;read: 2-2-0 s=1,c=1,t=49,pt=0,l=22,sg=0:55.722519;13.018120
0;0;3;0;9;Sending message on topic: mygateway1-out/2/1/1/0/49
0;0;3;0;9;read: 2-2-0 s=1,c=1,t=49,pt=0,l=22,sg=0:55.722519;13.018121
Subscribe to messages (in another shell on your computer) > mosquitto_sub -v -t 'mygateway1-out/#'
You should see the messages like you saw in the gateway-log showing up like this:
mygateway1-out/2/1/1/0/49 55.722519;13.018121;13
mygateway1-out/2/1/1/0/49 55.722519;13.018114;12
mygateway1-out/2/1/1/0/49 55.722527;13.018120;11
mygateway1-out/2/1/1/0/49 55.722534;13.018122;10
Sending (publishing) messages to your sensor network: > mosquitto_pub -t 'mygateway1-in/2/1/1/0/49' -m '0,29'
Gateways
Sensors & Actuators
Comments
