Light Level Sensor - BH1750
written by mfalkvidd
The BH1750 ambient light intensity sensor breakout board has a 16-bit A2D converter built-in that can directly output a digital signal. The output from the sensor is in Lux (Lx) and does not require advanced calculations in the sketch. The BH1750 communicates using I2C Protocol
Wiring Things Up
Start by connecting the radio module.
Sensor Arduino Comment
GND GND Black
VCC VCC (3.3-5V) Red
ADDR GND Black
SCL Analog input 5 (A5) Blue
SDA Analog input 4 (A4) Green
Example
This example uses the external BH1750 library found here. Please install it and restart the Arduino IDE before trying to compile.
/mysensors/MySensorsArduinoExamples/examples/LightLuxSensor/LightLuxSensor.ino
Last updated by mfalkvidd, 6 Mar 2019, "Remove unnecessary SPI includes"
 * Created by Henrik Ekblad <[email protected]>
 * REVISION HISTORY
 * Version 1.0 - idefix
 * Arduino BH1750FVI Light sensor
 * communicate using I2C Protocol
 * this library enable 2 slave device addresses
 * Main address  0x23
 * secondary address 0x5C
 * connect the sensor as follows :
 *   VCC  >>> 5V
 *   Gnd  >>> Gnd
 *   ADDR >>> NC or GND
 *   SCL  >>> A5
 *   SDA  >>> A4
 * https://www.mysensors.org/build/light-bh1750
#include <BH1750.h>
#include <Wire.h>
#define CHILD_ID_LIGHT 0
unsigned long SLEEP_TIME = 30000; // Sleep time between reads (in milliseconds)
BH1750 lightSensor;
// V_LIGHT_LEVEL should only be used for uncalibrated light level 0-100%.
// If your controller supports the new V_LEVEL variable, use this instead for
// transmitting LUX light level.
MyMessage msg(CHILD_ID_LIGHT, V_LIGHT_LEVEL);
// MyMessage msg(CHILD_ID_LIGHT, V_LEVEL);
uint16_t lastlux;
  lightSensor.begin();
void presentation()  {
  sendSketchInfo("Light Lux Sensor", "1.0");
  // Register all sensors to gateway (they will be created as child devices)
  present(CHILD_ID_LIGHT, S_LIGHT_LEVEL);
  uint16_t lux = lightSensor.readLightLevel();// Get Lux value
  Serial.println(lux);
  if (lux != lastlux) {
      send(msg.set(lux));
      lastlux = lux;
  sleep(SLEEP_TIME);
Datasheets
NameSize# Downloads
bh1750fvi-e.pdf545.46 kB8857
Gateways
Sensors & Actuators
Comments
