Orientation Actuator (pan/tilt)
This project complements the "Orientation Sensor" by reading the "Yaw" and "Pitch" values from the V_ORIENTATION (= V_TEXT) values and positioning two servo's in a pan/tilt setup accordingly.
The sketch includes the functionality to receive the V_ORIENTATION type and extract the Yaw and Pitch values. As an addition the position can be set with a "V_PERCENTAGE" from the controller (and PWM LED control).
Images
Source Code
NameSize# Downloads
AWI_pan_tilt_servo.ino6.57 kB2732
Bill of Material
QtyValueDevicePackagePartsDescriptionMFMPNAliexpress or ebay link
1CustomBattery based atmega328p sensor board, populatedCustom boardGertSanders board or any MySensors Board with radiohttps://www.openhardware.io/view/5/Battery-based-atmega328p-...
1PanTilt SetPan Tilt construction with 2 servo'sPan Tilthttps://www.aliexpress.com/item//32622494781.html
Gateways
Sensors & Actuators
Related Content
Comments
