Water Meter Pulse Sensor
written by hek
In some cases, newer water meters are equipped with a pulse output. However if you have an older power meter without a pulse output, then you might be able to use one of the options below to sense your water consumption.
Use the TCRT5000 IR Barrier Line Track sensor. It emits an infrared light and detects the reflection. If you aim it at the fastest turning hand on your meter, you can detect pulses or a rate.
Some water meters emit a fluctuating magnetic field that can be detected by using a Hall effect sensor. Instructions are available here.
The sensor example sketch counts the pulses from your attached sensor and converts it into liters or gallons per minute and the cummulative water volume.
There are a few parameters that need to be tuned to your water meter. Set the PULSE_FACTOR to the number of revolutions per cubic-meters (or gallons) of water.
You can also set the frequency that the sensor will report the water consumption by updating the SEND_FREQUENCY. The default frequency 3 times per minute (every 20 seconds). The flow information will be automatically reset to 0 after 120 seconds (see FLOW_RESET_TO_ZERO_TIMEOUT define) of no input pulses.
The sensor has two modes of operation:
SLEEP_MODE = true
Use this mode if you power the sensor with a battery. In this mode the sensor will sleep most of the time and only report the cumulative water volume. Unfortunately the sensor cannot report the current water flow rate because the sensor can not track time while sleeping; the elapsed time between two blinks is required to calculate the current flow rate.
SLEEP_MODE = false
In this mode the sensor will not sleep and will report the current water flow rate and the cumulative water consumption to the gateway. This mode requires constant power so you will need to connect the sensor to an electrical outlet.
Usage with Home Assistant Controller
The sensor automatically register itself to home assistant controller which will release a NODE_ID to this sensor (through the gateway). If everything is fine, the NODE_ID will be set in the sensor EEPROM, and the board will get an initial counter value of 0 from Home Assistant. At this point, the sensor and Home Assistant are paired. The initial provisioning writes a flag in the sensor EEPROM indicating that the counter has been correctly provisioned to the sensor by Home Assistant, so that the board will start to use the counter incrementing on received pulses just after this event. The effect of this procedure is also that if you provision another sensor setting the same NODE_ID, you will get the current counter value from Home Assistant on the first startup.
Factory Reset
Just in case you want to register the sensor using another NODE_ID, you will need to factory reset this sensor. For user convenience, in the source code you will find a FORCE_FACTORY_RESET define that will allow you (uncommenting the line) to factory reset the board on startup (resetting NODE_ID and also the pulse counter provisioning flag). Once you started the board with this definition, you will see in the serial log that the board has been reset, so you can comment again this line in order to proper run the board as usual. Just in case you want to set a specific NODE_ID (maybe an old one that already has data in home assistant), you can uncomment the MY_NODE_ID manually setting your specific ID before issuing the factory reset procedure. After that you can comment back again this line.
Setting a specific Volume counter value
Should be the case where you want your volume counter to start from a specific value (e.g. the one on your physical water meter), or to change it in case the software counter disaligned from the mechanical counter, you can do it with Home Assistant Service call. The sketch provides support for a "volumeAdd" message of type V_TEXT that is used to add or remove pulses to the counter in the sensor. In order to do that you will go to Home Assistant service call helper (in the developer tools), go in yaml mode and use these: service: notify.mysensors data: message: VALUE_TO_ADD target: Water Meter NODE_ID 2
you will need to set:
VALUE_TO_ADD to a numeric (positive or negative) integer value that will be added to the existing counter. Mind that currently this may go in overflow if you use too big values. The number is expressed as "pulses" units, so if you want to add 1.234 m3 to the current value of volume (e.g. 1000 m3) you will set here 1234 and just after some seconds you will find 2.234 m3 in the volume shown by Home Assistant.
NODE_ID to the one assigned to your sensor. 2 is the child entity and will correspond to the text of S_INFO entity attached to this device (you see this in the entities)
Wiring Things Up
Start by connecting the radio module.
Sensor Arduino Comment
GND GND Black
VCC VCC (3.3 - 5V) Red
DO (digital out) Digital pin 3 (D3) Green
Example
/mysensors/MySensors/examples/WaterMeterPulseSensor/WaterMeterPulseSensor.ino
Last updated by tekka007, 1 Jan 2026, "Prepare 2.4.0 release (#1587)"
 * Created by Henrik Ekblad <[email protected]>
 * REVISION HISTORY
 * Version 1.0 - Henrik Ekblad
 * Version 1.1 - GizMoCuz
 * Use this sensor to measure volume and flow of your house water meter.
 * You need to set the correct pulsefactor of your meter (pulses per m3).
 * The sensor starts by fetching current volume reading from gateway (VAR 1).
 * Reports both volume and flow back to gateway.
 * Unfortunately millis() won't increment when the Arduino is in
 * sleepmode. So we cannot make this sensor sleep if we also want
 * to calculate/report flow.
 * http://www.mysensors.org/build/pulse_water
//#define MY_RADIO_NRF5_ESB
#define DIGITAL_INPUT_SENSOR 3                  // The digital input you attached your sensor.  (Only 2 and 3 generates interrupt!)
#define PULSE_FACTOR 1000                       // Number of blinks per m3 of your meter (One rotation/liter)
#define SLEEP_MODE false                        // flowvalue can only be reported when sleep mode is false.
#define MAX_FLOW 40                             // Max flow (l/min) value to report. This filters outliers.
#define CHILD_ID 1                              // Id of the sensor child
uint32_t SEND_FREQUENCY =
    30000;           // Minimum time between send (in milliseconds). We don't want to spam the gateway.
MyMessage flowMsg(CHILD_ID,V_FLOW);
MyMessage volumeMsg(CHILD_ID,V_VOLUME);
MyMessage lastCounterMsg(CHILD_ID,V_VAR1);
double ppl = ((double)PULSE_FACTOR)/1000;        // Pulses per liter
volatile uint32_t pulseCount = 0;
volatile uint32_t lastBlink = 0;
volatile double flow = 0;
bool pcReceived = false;
uint32_t oldPulseCount = 0;
double oldflow = 0;
double oldvolume =0;
uint32_t lastSend =0;
uint32_t lastPulse =0;
#if defined(ARDUINO_ARCH_ESP8266) || defined(ARDUINO_ARCH_ESP32)
#define IRQ_HANDLER_ATTR ICACHE_RAM_ATTR
#else
void IRQ_HANDLER_ATTR onPulse()
    if (!SLEEP_MODE) {
        uint32_t newBlink = micros();
        uint32_t interval = newBlink-lastBlink;
        if (interval!=0) {
            lastPulse = millis();
            if (interval<500000L) {
                // Sometimes we get interrupt on RISING,  500000 = 0.5 second debounce ( max 120 l/min)
                return;
            flow = (60000000.0 /interval) / ppl;
        lastBlink = newBlink;
    pulseCount++;
    // initialize our digital pins internal pullup resistor so one pulse switches from high to low (less distortion)
    pinMode(DIGITAL_INPUT_SENSOR, INPUT_PULLUP);
    pulseCount = oldPulseCount = 0;
    // Fetch last known pulse count value from gw
    request(CHILD_ID, V_VAR1);
    lastSend = lastPulse = millis();
    attachInterrupt(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), onPulse, FALLING);
    sendSketchInfo("Water Meter", "1.1");
    // Register this device as Water flow sensor
    present(CHILD_ID, S_WATER);
    uint32_t currentTime = millis();
    // Only send values at a maximum frequency or woken up from sleep
    if (SLEEP_MODE || (currentTime - lastSend > SEND_FREQUENCY)) {
        lastSend=currentTime;
        if (!pcReceived) {
            //Last Pulsecount not yet received from controller, request it again
            return;
        if (!SLEEP_MODE && flow != oldflow) {
            oldflow = flow;
            Serial.print("l/min:");
            Serial.println(flow);
            // Check that we don't get unreasonable large flow value.
            // could happen when long wraps or false interrupt triggered
            if (flow<((uint32_t)MAX_FLOW)) {
                send(flowMsg.set(flow, 2));                   // Send flow value to gw
        // No Pulse count received in 2min
        if(currentTime - lastPulse > 120000) {
            flow = 0;
        // Pulse count has changed
        if ((pulseCount != oldPulseCount)||(!SLEEP_MODE)) {
            oldPulseCount = pulseCount;
            Serial.print("pulsecount:");
            Serial.println(pulseCount);
            send(lastCounterMsg.set(pulseCount));                  // Send  pulsecount value to gw in VAR1
            double volume = ((double)pulseCount/((double)PULSE_FACTOR));
            if ((volume != oldvolume)||(!SLEEP_MODE)) {
                oldvolume = volume;
                Serial.print("volume:");
                Serial.println(volume, 3);
                send(volumeMsg.set(volume, 3));               // Send volume value to gw
    if (SLEEP_MODE) {
        sleep(SEND_FREQUENCY, false);
    if (message.getType()==V_VAR1) {
        uint32_t gwPulseCount=message.getULong();
        pulseCount += gwPulseCount;
        flow=oldflow=0;
        Serial.print("Received last pulse count from gw:");
        pcReceived = true;
Datasheets
NameSize# Downloads
tcrt5000.pdf309.61 kB10111
Gateways
Sensors & Actuators
Comments
